Intermittent Engine Power Reduction - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-03-2013, 11:57 AM   #1
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
Points 1,361, Level 20
Points: 1,361, Level: 20 Points: 1,361, Level: 20 Points: 1,361, Level: 20
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 1 Borski Good Standing Member
Hey guys!
Let me know if this is the wrong spot for this post.
I was driving my 2012 home from work on the highway when I noticed a decrease in engine power, I wasn't able to accelerate on the highway (going 70). I got off the exit for my house, and went to accelerate on to the road and noticed it was insanely sluggish. It felt like the car was running at half power. I turned off the AC just to verify. This continued on the local roads all the way home. I parked the car, and then attempted to "rev up" the engine with the car in neutral. I noticed it was still very sluggish to accelerate even without load on the engine. Pedal to the floor, it probably took 10 seconds to hit 4k RPM, in netural.
I turned off the car to go inside and get my tools out to check what I initially suspected could have been a spark plug issue. I restarted the car, just to ensure that I could recreate the problem, and the car runs fine. It's been a week now - car still running fine.
What could have been the root cause of this?
Details of Car:
-2012 SE
-42k miles
-Manual Transmission
-Up to date on all maintenance and oil change
-No previous engine or electrical problems
Thanks guys!
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
Old 06-03-2013, 12:10 PM   #2
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,426, Level 97
Points: 26,426, Level: 97 Points: 26,426, Level: 97 Points: 26,426, Level: 97
Level Up 8% Completed
FF Reputation: 9 TORQUERULES Good Standing Member
Check your coolant first of all then report back. Others can chime in.
There are many things that could cause this, but the ECU is programmed with a limp home mode in case the engine exceeds safe normal operating temperature.
Not saying this is the cause, just one of the possible ones.
TORQUERULES is offline
Old 06-03-2013, 12:27 PM   #3
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
I had that too after driving relatively hard, took like 15 minutes to restore
Tjrommel is offline
Old 06-03-2013, 02:34 PM   #4
cheekedave
Fan#: 103448
What I Drive: 2012 Focus SEL Silver
FF Reputation: 1 cheekedave Good Standing Member
I know this doesn't help but I figure I should mention my "problem" I had.. Driving down the highway about 110km/hr (~70mph) and the car wouldn't accelerate over 2000rpm. Car started to slow down and I managed to cut over onto the shoulder. Turned the car off and back on and it went fine after that. Hasn't happened since and I didn't get any errors/warnings during or after.
One downside to having your car riddled with electronics.
cheekedave is offline
Old 06-03-2013, 04:45 PM   #5
TORQUERULES
The Professor
Fan#: 1083
This sounds interesting since it is happening to a few people. Get or borrow an OBD2 code scanner and see what it gives you. Places like Advance Auto Parts will run your codes for free.
Old 06-03-2013, 04:46 PM   #6
TORQUERULES
The Professor
Fan#: 1083
This sounds similar to the issue some people are reporting with the EcoBoost F-150 and SHO Taurus.
Old 06-03-2013, 05:37 PM   #7
Borski
Borski's Avatar
Fan#: 100013
Interesting. I suspect it was an accidental "limp home" mode then.
I wasn't driving hard, if was about 90F out. There were no temperature exceedences.
Just checked the coolant, everything is perfectly normal.
Sounds like an error with a sensor or something triggered "limp home" in the engine.
Sent from my HTC One X using FF Mobile
Borski is offline
Old 06-04-2013, 10:18 AM   #8
cheekedave
Fan#: 103448
I think the same happened with me. I keep my ODB reader in my car and I plugged it in when was safe to do so and I had no codes at all given. Has not happened ever since... x-files weird!
Old 06-11-2013, 04:56 PM   #9
yoshi1015
yoshi1015's Avatar
Fan#: 115360
What I Drive: 2013 Black Ford Focus Hatch SE
Points 117, Level 2
Points: 117, Level: 2 Points: 117, Level: 2 Points: 117, Level: 2
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 1 yoshi1015 Good Standing Member
my 2013 Ford Focus Hatch SE did this a couple of times but when it was happening my temp was normal and no engine light. What i did notice is that the ambient temp outside both times was over 95o so what I was thinking is my injen cold air was no longer cold air and with outside temps being almost 100o it must have been over 130o under the hood because when the car cooled down and I drove it when it was cooler the car drove perfect. Just my experiance
Daniel Young
yoshi1015 is offline
Old 06-20-2013, 02:49 PM   #10
olek101
Fan#: 90534
What I Drive: 2012 Silver Ford Focus SE
FF Reputation: 1 olek101 Good Standing Member
I also had this happen to me but it was not hot outside ~20 deg C. Would would rev super slow.
-2012 SE HB
-30000 km
-Manual trans
-No mods
olek101 is offline
