200 N/A hp? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-04-2013, 01:54 PM   #21
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
Originally Posted by Pb-foot View Post
Why do you think Ford used stronger forged rods with bigger wrist pins in the SVT?
Because the SVT started life as the FR200 and was suppose to be turbocharged , when this changed they kept the rods because they were already built as well as the SVT head , cams , VCT etc
Even with ITB , 11-1 compression and all the other goodies in your list it still wouldnt hit 200HP
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-04-2013, 06:39 PM   #22
Pb-foot
Pb-foot's Avatar
Fan#: 62873
What I Drive: 2004 Silver 3dr SVTF w/EAP
Points 294, Level 5
Points: 294, Level: 5 Points: 294, Level: 5 Points: 294, Level: 5
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 2%
FF Reputation: 1 Pb-foot Good Standing Member
I'm pretty sure it would be close enough so you'd just be splitting hairs.
VCT was clearly intended for NA to compliment the adjustable intake. Cams are NA grind for VCT. But I accept that the rods and head could work for either one, as long as the piston design/CR was changed... or maybe they just shaved all the heads for the NA version and accepted the valve interference that resulted.
Stockholm Getaway - 465 hp Cosworth vs Supra - see it on YouTube
Pb-foot is offline
Old 06-04-2013, 08:32 PM   #23
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 28,017, Level 98
Points: 28,017, Level: 98 Points: 28,017, Level: 98 Points: 28,017, Level: 98
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
IIRC, Topspeed did a complete NA build on the SVT head and pulled 190s on pump fuel. but thats the highest i've heard with alot of custom parts. I don't know if there is a cam made for the focus (not even the crower 4's can make reasonable power @ 8500 rpm. I had a reasonably high hp focus NA @ 164 whp, and the only things i could have done more were raising compression to 11:1 +, ,but then you can't dd it on pump fuel. I could have gone to an SVT head w/ Tom porting the snot out of it and Kent Cams instead of a custom ported FR and Crower custom grinds, perhaps ITBs, and a dry sump to spin higher rpm, but at that point, your low end suffers too.
Iminhell has about the best NA setup. If I still had a social life, or any free time whatsoever anymore, i may try a build similar to his, but i don't have the time or money to do so.
Iminhell, did you ever dyno ur setup? I haven't been around a while to check to see what you made
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is online now
Old 06-04-2013, 09:27 PM   #24
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 61%
Do some reading on the FR200 it was an interesting car and what the SVT should of been , I got to drive one and got to see 3 of them back in the day , trying to buy one now
I build a lot of Caterhams , and built some with the combo you talked about and there in the 185 range with a RPM range of 3600 - 7300
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 06-04-2013, 09:59 PM   #25
beatmaniac1
beatmaniac1's Avatar
Fan#: 90996
What I Drive: 2003 red svtf
Points 416, Level 8
Points: 416, Level: 8 Points: 416, Level: 8 Points: 416, Level: 8
Level Up 32% Completed
FF Reputation: 2 beatmaniac1 Good Standing Member
Buy-Sell-Trade Rating: (4)
Has anybody from the forum ever build a zetec with ITB in a focus ? ( I mean true ITB's not itb's inside a plenum to keep using MAF ). I've been looking around for a while but nobody as ever done and documented it this side of the Atlantic. In Europe they get more than 200 hp with ITB on engines that they transplant into saphire, focus , fiestas, Orions , Escort mkx, cortinas, etc... I suppose running aftermarket ECU is what is keeping us from going all-out and build monster zetec's ? CAuse I understand that the stock ECU cannot be converted to run with another signal than MAF ( Tom corect me if I'm wrong ? )
Dunnell are making 190 hp on ITb's with stock head, valvetrain, bottom end and camshafts ... That seems like a quick way to gain 60 hp IMHO :
http://www.dunnellengines.com/zetec_...tionkits_4.php
Though, it wouldnt be cheap to go that route cause you would still need custom tuning...
beatmaniac1 is offline
Old 06-05-2013, 12:09 PM   #26
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Brad,
I made 173hp on the stock SVT intake (manifold to airbox).
Haven't dyno'd with the FRIM yet.
Far as ITB's go,
You cannot compare the power to any stock ECU powered car. You are not able to know what made the extra power, or if the stock ECU is holding the car back.
Far as the FR200 goes,
They (all of them) were built with ZX2 parts. The SVT evolved from things learned with the cars. But the SVT didn't. use any of the parts used on the FR200 that I know of or have ever seen proof of.
iminhell is offline
Old 06-05-2013, 01:04 PM   #27
beatmaniac1
Fan#: 90996
Points 416, Level 8
Far as ITB's go,
I dont get your point ? What is restricting your power output when tuning on ford ecu ? I believed that SCT gave you access to all ignition and injection tables ? And I've read many times that ford has better/faster/more precise processors than most of the aftermarket ecu's... The only difference being the ability of aftermarket ecu's to calculate the amount of air via other strategies than MAF using maf...
I dont think a megasquirt/AEM/omex/whatever tuned stock focus would make more power than an SCT tuned stock focus ? ( as long as both tunes were provided by professionnal tuners, running the same level of octane ) Do you ?
Old 06-05-2013, 01:23 PM   #28
Pb-foot
Pb-foot's Avatar
Fan#: 62873
Points 294, Level 5
Forum Activity 2%
Did some reading... it looks like that car will cost you allot as a collectable, but fun to play with. Too bad all Ford ended up using it for was to test the viability of some aftermarket parts for FRPP. All three engines seem to have been tweaked a bit differently though, it looks like SVT might have learned from the developement of them and chose the more robust internals to build around.
I'm sure it's fun to build/tune Caterhams, I remember seeing a Lotus Super 7 easily pulling away from everything else in the field that had a half liter "advantage" in modified class. And youtube is full of current day examples of Chaterhams doing the same on any kind of track.
Is the 185 figure street-tuned for 93 octane, or is that race fuel tuned? It seems to me that such an engine as described should be able to carry power into 8K range at 11:1, with proper cams/gas/head work on race fuel. But then I've been wrong before, although I'm usually quite close.
Pb-foot is offline
Old 06-05-2013, 05:38 PM   #29
beatmaniac1
Fan#: 90996
Points 416, Level 8
Classic Ford, july 2013 issue : 251 hp zetec engine and 211 lbs.ft
http://www.classicfordmag.co.uk/2013...e-on-the-dyno/
When do we start building one ???
PS: that FR200 looked like a pretty quick car, too bad they didn't mass produce it :(
Old 06-05-2013, 09:15 PM   #30
Pb-foot
Pb-foot's Avatar
Fan#: 62873
Points 294, Level 5
Forum Activity 2%
Nice link, beatmaniac1! ITBs FTW NA.
Pb-foot is offline
