SVT turbo build - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-01-2013, 08:11 PM   #1
emgrock1
Fan#: 74349
What I Drive: 2002 Infa-red SVT focus
FF Reputation: 1 emgrock1 Good Standing Member
SVT turbo build
So i'm new to the turbo scene and have some general questions. The kit I purchased comes with most everything I need ( I think ).
Mitsubishi Turbocharger TE044 with internal wastegate
304 stainless turbo header manifold
304 stainless down pipe to cat
front mount air to air intercooler
all intercooler piping
Blitz blow off valve
all silicone couplers & clamps
oil supply line to turbo
oil return line to oil pan
air filter and conical
all hardware included
silicone vac. lines
oil pan with bung
I will need to purchase injectors and a wideband. I plan on running around 8 psi and would like to run 42 pound injectors, will these be sufficient? Also, will I need to change out the MAF?
I will also need to tune it. Any suggestions on the tune? where to go, or maybe get a handheld tuner with a TOM made tune? Like I said, i'm new to this so please add any input and suggestions.
emgrock1 is offline
Old 06-01-2013, 08:26 PM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Do not change the maf. Yesur injectors are sufficient for that amount of psi
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 06-11-2013, 10:15 AM   #3
BlkNite713
BlkNite713's Avatar
Fan#: 88254
What I Drive: 2002 Viper Blue SVT
Points 1,363, Level 20
Points: 1,363, Level: 20 Points: 1,363, Level: 20 Points: 1,363, Level: 20
Level Up 63% Completed
FF Reputation: 1 BlkNite713 Good Standing Member
Stock MAF, DiabloSport MAFia, I would highly suggest some DEI exhaust wrap for the mani, Downpipe, and a turbo blanket for the turbo. A good support mod would be 180 degree thermostat which only takes about 10mons to install and helps the car run cooler. As zxthriz said 42's will supply 8psi easy. If your planning on going higher I'd just buy 60lbs from the start so you can save money. I would just shoot him an email with any build questions if you need more help. He is very honest and the most reputable tuner on the forums IMO. Any questions shoot me a pm. I've been piecing together a turbo build for months and have done extensive research on almost every component concerning turbo/engine/drivetrain.
Good Luck with the build,
Anthony
Anthony ....The one and only GTS Blue SVT
Turbo Tuning Underway!!!!
-Built Motor(Probe/Eagle/ARP)
-Semi Built Tranny(Torsen/Clutchmaster)
-Triplex Comp CT2 Billet HF-X
BlkNite713 is offline
