'03 SVT - leaned out in 6th gear, melted piston - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-07-2013, 12:56 PM   #11
SuperStockAMX
Fan#: 89501
What I Drive: 2003 Comp Orange EAP SVT
Points 715, Level 14
Points: 715, Level: 14 Points: 715, Level: 14 Points: 715, Level: 14
Level Up 15% Completed
FF Reputation: 1 SuperStockAMX Good Standing Member
I suppose you could take out the oil squirters but I'm of the opinion squirters are a good idea so we're limiting them.
These are SVT (aftermarket forged) Pistons that fit the SVT rod (same compression height / pin, etc).
SuperStockAMX is offline
Old 08-23-2013, 10:42 PM   #12
SuperStockAMX
Fan#: 89501
Pistons coated. The coatings are by Tech-Line. The piston crown is a reflective coating which keeps is to keep the heat in the combustion chamber. The coating on the skirts is an anti-friction coating.
Should have the SVT back next few days.
Old 08-23-2013, 10:47 PM   #13
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Pressed or floating pins?
iminhell is offline
Old 08-23-2013, 11:20 PM   #14
LOADED
LOADED's Avatar
Fan#: 81895
What I Drive: 2003 Sonic Blue SVT Focus
Points 1,922, Level 26
Points: 1,922, Level: 26 Points: 1,922, Level: 26 Points: 1,922, Level: 26
Level Up 22% Completed
FF Reputation: 1 LOADED Good Standing Member
Just out of curiosity, what spark plugs where you running when this incident occurred? I have a buddy on the other forum with a thread about how the SVT can not use some plugs, as some SVT owners had similar experiences as you. He has a whole thread on it with great info on the other fourm. Let me know If you want me to pm you a link to his thread.
2003 Sonic Blue SVT Focus #524
LOADED is offline
Old 08-23-2013, 11:29 PM   #15
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
^You have friends.
THIS IS NEWS!
iminhell is offline
Old 08-23-2013, 11:34 PM   #16
SuperStockAMX
Fan#: 89501
Floating piston pins and the shop clearanced the pins.
Was and will still use factory OEM spark plugs. I never had a problem with them.
Old 08-23-2013, 11:40 PM   #17
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,525, Level 100
Points: 52,525, Level: 100 Points: 52,525, Level: 100 Points: 52,525, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
I would go to the SP463 plugs they are colder then the stock plug and are much cheaper
If those are the SVT pistons that Diamond makes for the Eagle rods (didnt know of any for the stock SVT rod which is longer then the Zetec rod) then your pistons will come just above the deck of the block and compression will be very high , have you checked the compression height against the stock SVT piston , I think you will find them taller
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-23-2013, 11:42 PM   #18
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
The floating pin and lack of oil is what worries me ...
iminhell is offline
Old 08-23-2013, 11:50 PM   #19
SuperStockAMX
Fan#: 89501
I've stated it a few times, I had these pistons custom made for stock SVTF rods. Same compression height as OEM. Deck height will be the same as OEM. The only difference is use of a more readily available 1mm top ring land so I can get rings from Total Seal which will be a barrel face top ring and napier face second ring. V-groove between the top and second ring. Also the crown was dished with a 8* taper instead of OEM 5* taper. Possibly a +1/4 point in compression. Piston / pin assembly is only about 14 grams lighter than OEM.
Old 08-23-2013, 11:55 PM   #20
SuperStockAMX
Fan#: 89501
Why is a floating pin a problem and why would there be a lack of oil? A floating pin and a pressed pin get the same amount of oil, just the pin hole and pin have different clearances.
