Need help! Hid conversion with eagle eye projectors - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-29-2013, 01:00 PM   #1
pjsm88
Fan#: 115192
What I Drive: 2009 black se
FF Reputation: 1 pjsm88 Good Standing Member
I have recently installed eagle eye projectors in my 2009 ford focus, and i am looking to install an hid conversion kit. After doing some research, i am having a hard time figuring out what i need so that i have high beam/low beam.. It seems that all of the h9 conversion kits ive come across are either high beam OR low beam... If anyone could provide some direction as to what i would need to make this happen it would be greatly appreciated. Bulbs are h9 and i'd like to go to for a 6000k conversion kit of some sort. Thanks in advance.
pjsm88 is offline
Old 05-29-2013, 03:54 PM   #2
Gadabout
Gadabout's Avatar
Fan#: 114774
What I Drive: 2006 Vermillion Red ZX4 SE
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 4 Gadabout Good Standing Member
The reason HID come the way you have been seeing, is because 1) you are never going to use the High Beam, due to the HID being so brilliant already, and 2) HID take a bit to 'warm up', so therefore, in theory, if you were to hit your High Beam you wouldn't get any light until it has had sufficient time to 'warm up'.
“Things work out best for those who make the best of the way things work out.” - J Wooden
Team Duratec #42
Gadabout is offline
Old 05-29-2013, 05:01 PM   #3
SESRob
Fan#: 84340
What I Drive: 2009 Black Focus SES
Points 16, Level 1
Points: 16, Level: 1 Points: 16, Level: 1 Points: 16, Level: 1
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 1 SESRob Good Standing Member
The Eagle Eye Projectors use a H9 HID bulb and have a "flip up" shield built in. So when you activate your high beams the cut off shield is moved out of the way, giving you the "full power" of the bulb and effectively high beams. I have it and it is very bright when the "high beams" are activated. There are several threads here on how to set these lights up.
SESRob is offline
Old 05-29-2013, 06:47 PM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
Moved you. You should get more response here in the MK2 exterior chat area.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 05-29-2013, 07:53 PM   #5
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
Sesrob got it, It has a shield inside so your light never shuts off to change from high beam to low beam. It's the same as my retrofitted headlights, just the eagle eyes are a more narrow and less focused projector.
The shield inside just flips down and allows more light out. Shown on the bottom right here
If you had highs and low separate you would have next to no light while the high beam warmed up and same thing when you switched back to low.
Instead you have your low beam
And as soon as you hit high beam, your shield flips down letting more light out
Then the shield flips back up, so you have a cutoff so you do not blind people.
A7xschecter6661 is offline
Old 05-29-2013, 08:28 PM   #6
pjsm88
Fan#: 115192
Thank you for the info! So, if I'm using a relay harness to install my conversion kit, should I get a single beam relay since they are single beam bulbs? Or a dual beam relay since I want to have the high beam/low beam shield effect with my projectors?
pjsm88 is offline
Old 05-30-2013, 12:17 PM   #7
A7xschecter6661
Fan#: 98263
the h9 or whatever is a single beam, the whole point to the shield is the same bulb is always on for high and low so there is no warm up period except when you first turn them on.
The shield just directs the light for high and low and you don't have to worry about it
Old 06-01-2013, 02:54 AM   #8
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,424, Level 21
Points: 1,424, Level: 21 Points: 1,424, Level: 21 Points: 1,424, Level: 21
Level Up 24% Completed
FF Reputation: 2 Miztaken1312 Good Standing Member
And don't use the crappy halogens that come in them! I thought I would be okay and get away with using them for one night. Both bulbs failed at the same time. It's just about 3am, and I just got down thoroughly testing both housings and the cars harness to make sure nothing was wrong with them, and both bulbs refuse to light and fail continuity tests.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is online now
Old 06-01-2013, 03:52 PM   #9
pjsm88
Fan#: 115192
Duely noted! Thanks for the input. I am still wondering about whether or not i will need a single beam relay harness or a dual beam relay harness if i still want to activate my "shield" for the high beam/low beam option for my projectors once i install a conversion kit. Any ideas?
pjsm88 is offline
Old 08-01-2013, 07:14 AM   #10
iamwreckless
Fan#: 114929
What I Drive: 2008 Black Focus
FF Reputation: 1 iamwreckless Good Standing Member
SIngle beam
Posted via FF Mobile
iamwreckless is offline
