Will these fit a 2nd gen Focus? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-29-2013, 08:59 AM   #1
Snyper
Snyper's Avatar
Fan#: 96688
What I Drive: 2009 Black SE
Points 1,478, Level 21
Points: 1,478, Level: 21 Points: 1,478, Level: 21 Points: 1,478, Level: 21
Level Up 78% Completed
Forum Activity 3%
FF Reputation: 2 Snyper Good Standing Member
http://www.bojix.com/wheels/521-matt...x-7-4x108/100/
I see that the bolt pattern is 4x108, but I just wanted to verify with someone who knows a little bit more than I do that these do infact fit the 09 that I have.
If so, it says the rivets are removable. Is there a "cap" or something to cover them with? I'd most likely want them green to match my black /green theme that I have going on.
Snyper is offline
Old 05-29-2013, 09:49 AM   #2
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 14,968, Level 79
Points: 14,968, Level: 79 Points: 14,968, Level: 79 Points: 14,968, Level: 79
Level Up 24% Completed
Forum Activity 11%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
they should fit, looks like the ET is a bit low so you might get some fender rub but i think the 2nd gen focus has a lower et anyway so you should be fine.
cant help with the rivet issue. if i were you i would simply remove them all before even putting them on the car and have them powder coated to match the theme
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 05-29-2013, 10:01 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,833, Level 73
Points: 12,833, Level: 73 Points: 12,833, Level: 73 Points: 12,833, Level: 73
Level Up 96% Completed
Forum Activity 99%
From the description it sounds like the rivets are "removeable" so you can paint then reinstall...
Spring for the hub-centric rings as well, i see they sell them separately.
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 05-29-2013, 11:52 AM   #4
YellowJellyBean
Love CA / Hate CARB
YellowJellyBean's Avatar
Fan#: 69030
What I Drive: MÜSTÄRD
FF Reputation: 13 YellowJellyBean Great Standing Member
ET38 might be a problem for a 8" wide wheel, but on a 7" wide it'll be fine.
As for the rivets, I personally wouldn't buy a fake 3-piece wheel because those fake bolts look tacky, and I don't think there's really anything you can do to make them or the holes look any better. That's just my personal opinion, though.
"My yellow, in this case, is not so mellow" -Jimi Hendrix
Focus Fanatics
Extremely helpful people
I made a haiku
YellowJellyBean is offline
Old 05-29-2013, 01:27 PM   #5
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
I had no clue that they were fake. I know little about this stuff. Thanks for the knowledge.
Snyper is offline
Old 05-29-2013, 04:20 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
If you like the style, don't worry about it. As YellowJellyBean said, it's a personal preference (I share it, 'cause I like a simpler style wheel myself).
3-piece wheels were made for racing to get an ultralight wheel. They aren't recommended for street use, and with the advent of better wheel technology they have less of a weight advantage than when first designed.
Cast center section bolted to spun aluminum side pieces (the light part) allowed swapping pieces to get different widths & offsets with the same center section. Getting them bolted up right without leaks was always "fun" (O-ring seal is typical). Tire changing a bit tedious, but done without a tire machine so easier at a track.
The thin rim sections can get bent quite easily (though replaceable), and the lack of safety bead on the rim on many makes them non-compliant with street standards.
That'll give you a general idea what the style is mimicing, and trying to look like something they're not is one reason some folks don't like the look.
Cheers!
"Rubber Side Down"
Old 05-29-2013, 04:33 PM   #7
YellowJellyBean
Love CA / Hate CARB
Fan#: 69030
I guess I should clarify what I said. The bolts are real in the sense that they are actually bolts threaded into nuts. They do not, however, have anything to do with holding the wheel together (like in a true 2-piece or 3-piece wheel) and are purely cosmetic.
XXR makes a lot of replica-ish wheels, which is why these are an inexpensive copy of BBS LM wheels. A legit set of 2-piece LMs (like the ones below) would cost you up into the thousands of dollars for a set.
Focus Fanatics
I made a haiku
Old 05-29-2013, 05:58 PM   #8
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
I liked the BBS wheels but the price was just a bit too much for my liking. That's why I liked the XXR's. I think what I liked the most was the ability to take those bolts out and paint 'em green to match my theme.
Snyper is offline
