After intake install: lean, o2 #2 circuit. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-27-2013, 09:53 PM   #1
FortWayneFocus
Fan#: 110291
What I Drive: 2002 CD Silver ZX5, 94 Honda VFR
Points 754, Level 14
Points: 754, Level: 14 Points: 754, Level: 14 Points: 754, Level: 14
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 FortWayneFocus Good Standing Member
I've read intake install problem threads with the 3" Maf housing causing a lean condition, but now it throws an o2 circuit code? Could the cat be coming apart after 172k? I'm working on the lean condition... codes thrown are p0171, p0136, and p1131 which says " lack of H02S11 SWITCHES, sensor indicates lean.
FortWayneFocus is offline
Old 05-27-2013, 10:44 PM   #2
JFrye
JFrye's Avatar
Fan#: 54896
What I Drive: 2000 ZX3, 99 Dodge 3500 w/Cummins
Points 1,684, Level 23
Points: 1,684, Level: 23 Points: 1,684, Level: 23 Points: 1,684, Level: 23
Level Up 84% Completed
Forum Activity 30%
FF Reputation: 3 JFrye Good Standing Member
Buy-Sell-Trade Rating: (6)
Is it the same MAF sensor that was in the old housing, or did you swap MAF too?
00 Silver ZX3. Zetec, ATX w/3.90 gears. 14" orange steelies. Eibach Sportlines, Massive Strut Bar, BBK 65mm TB, 4 to 1 Header followed by 2.5" into 3" exhaust.
Hatch Nation #31
JFrye is offline
Old 05-27-2013, 11:12 PM   #3
FortWayneFocus
Fan#: 110291
stock maf sensor, all the zetec motors to 04 use the same sensor, including svt's
Old 05-27-2013, 11:20 PM   #4
JFrye
JFrye's Avatar
Fan#: 54896
Forum Activity 30%
With the bigger housing, I wasnt sure if you upgraded to a larger MAF. Have you tried resetting the computer?
Hatch Nation #31
JFrye is offline
Old 05-27-2013, 11:25 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
What are you asking?
If you're using a 3" housing with a stock sensor - yes, it will throw lean codes.
And there is no reason you need that large of housing on a stock car. Hell, you don't need that big until you near the 300whp range.
iminhell is offline
Old 05-27-2013, 11:31 PM   #6
JFrye
JFrye's Avatar
Fan#: 54896
Forum Activity 30%
To my understanding, the sensors look the same, but the internals of the sensor, or the computer is different, not allowing a SVT MAF to be used on a Zetec without a tune.
Hatch Nation #31
JFrye is offline
Old 05-28-2013, 12:30 AM   #7
FortWayneFocus
Fan#: 110291
as far as my parts catalogs at work go, the sensors are the same part numbers. whether it's the running slightly lean, or the bigger housing, the car is stronger throughout the powerband WITH the bigger housing. I have no detonation, so how lean is too lean? My question is mainly for the other 2 codes, I had the lean code when experimenting with my intake before, but this is the first time for the o2 sensor codes.
Old 05-28-2013, 06:41 AM   #8
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,007, Level 74
Points: 13,007, Level: 74 Points: 13,007, Level: 74 Points: 13,007, Level: 74
Level Up 40% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 05-28-2013, 10:57 AM   #9
FortWayneFocus
Fan#: 110291
Why? This issue is directly related to an aftermarket modification, as well as discussing the performance of the zetec engine under said conditions.
Old 05-28-2013, 12:29 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
With the Title & the multiple issues, I'm betting Don thought you'd get some additional "looks" over here (General Tech.), from others who may have ideas who wouldn't see it in the "ZETEC Performance" area.
I'll toss it right back over there for you, since that's where you'd like it to stay.
Cheers!
P.S. - "Too Lean" can't be determined without a wideband 02 sensor installed to track/log the actual results. A "plug check" might give you an idea, but that's likely to just tell you what the computer is already complaining about. IMHO if you're not "tuning' it with a wideband and some help tuning the computer, you're playing with fire running lean. The "Butt Dyno" will show great improvement in many cases from a lean condition, right up to the time you hole a piston from burning too hot! I've heard many times in the past from Snowmobile customers that "it was running GREAT until it suddenly quit" in similar circumstances (those have to be tuned to air temp, and when a tune for moderate temps gets run in 0 degree temps they'll "burn down" by holing a piston). If you see "white" on a plug ground electrode when you check them it's a danger sign, and you'd want to look at the piston & return it to stock until you plan the experiment a bit more. Good Luck & tune carefully!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
