Adding ambient lighting to back with OEM system - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-16-2013, 05:28 PM   #41
moocows42
Fan#: 101732
What I Drive: 2012 Tuxedo Black Titanium
Points 852, Level 15
Points: 852, Level: 15 Points: 852, Level: 15 Points: 852, Level: 15
Level Up 52% Completed
FF Reputation: 17 moocows42 Great Standing Member
Originally Posted by BlueIce View Post
Sounds like a lot of work for something I'll never really see. Unless my girlfriend is driving and I'm in the back. Which only happens after...
In which case I crawl into the back, remove the headrests (aka pillows), and .
The joys of a hatchback ! What other car owner can say he woke up in his trunk the next morning?
It really wasn't that bad. Maybe 30 minutes total to do everything. It's nice to have the back glow too instead of being so dark while the rest of the car is lit up.
moocows42 is offline
Old 07-16-2013, 05:30 PM   #42
moocows42
Fan#: 101732
Originally Posted by SilverPony2001 View Post
These are the correct part #'s. Although my invoice says BU2Z-14S411-ACA for the pigtail. The actual bag the pigtail is in has both numbers on it though.
Here is a pic as well:
Yeah that's what I got. Thanks for posting pictures of it. I didn't take any before doing everything.
Old 07-16-2013, 05:33 PM   #43
fivaldrood
Fan#: 116666
What I Drive: 2013 Ruby Red Titanium
Points 31, Level 1
Points: 31, Level: 1 Points: 31, Level: 1 Points: 31, Level: 1
Level Up 62% Completed
FF Reputation: 1 fivaldrood Good Standing Member
So the lights (13776) is just the light and the clear lens?
Moocows did you put anything around the back of the clear lens? Also are you able to get some pictures of how you mounted them under the seat and where you spliced to the lights up front?
Thanks
fivaldrood is offline
Old 07-16-2013, 06:11 PM   #44
moocows42
Fan#: 101732
Thanks
Yes the lights are the LEDs and the lens. I didn't really put anything special behind them because the LEDs face the lens.
This is where I tapped into the factory wires
Name:  ImageUploadedByFF Mobile1374012514.868683.jpg
This is where I tucked it under the front seat. So far it's stayed put.
Name:  ImageUploadedByFF Mobile1374012704.123002.jpg
I can try to take a picture later when it's dark to show what it looks like if you want.
Old 07-16-2013, 06:18 PM   #45
fivaldrood
Fan#: 116666
Points 31, Level 1
I'd appreciate a picture of how it glows at night before I decide to pull the trigger and do this myself. Thanks Moocows!
Old 07-16-2013, 06:34 PM   #46
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,428, Level 52
Points: 6,428, Level: 52 Points: 6,428, Level: 52 Points: 6,428, Level: 52
Level Up 39% Completed
Forum Activity 5%
FF Reputation: 9 SilverPony2001 Good Standing Member
Did you just run the wires from the back to the front under the rubber trim molding along the doors? I'm assuming there is some wires showing over the carpet before getting to that molding then?
SilverPony2001 is offline
Old 07-16-2013, 06:44 PM   #47
moocows42
Fan#: 101732
Yes I ran it under the plastic trim and it's exposed as it goes under the seat. Hardly noticeable and doesn't get in the way of anything. There's a spot under the seat where some wires come up but I couldn't easily get it over to that spot.
Here's where it is exposed
Name:  ImageUploadedByFF Mobile1374014699.596985.jpg
Old 07-16-2013, 06:47 PM   #48
SilverPony2001
Fan#: 27073
Forum Activity 5%
Sweet, thanks for the pics! Will have to get this done one of these cooler days.
Old 07-16-2013, 07:11 PM   #49
fivaldrood
Fan#: 116666
Points 31, Level 1
Couldn't you run it under the center console and cross over to under the seat there? Would be a bit less noticeable.
Old 07-16-2013, 07:30 PM   #50
moocows42
Fan#: 101732
You could run the wire however you'd like but the factory wiring is on the side I ran the wires so that why I ran them where I did since it is the shortest easiest route. And like I said you could run them under the carpet and bring it up under the seat if you wanted to hide it completely. It was hot when I did it so I wasn't looking to make it perfect. I may go back and run it under the carpet instead of over like I have it at some point but it's hardly noticeable an not in the way so I'm not in a hurry.
