Adding ambient lighting to back with OEM system - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-27-2013, 08:06 PM   #1
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,448, Level 52
Points: 6,448, Level: 52 Points: 6,448, Level: 52 Points: 6,448, Level: 52
Level Up 49% Completed
Forum Activity 4%
FF Reputation: 9 SilverPony2001 Good Standing Member
Has anyone looked at the control module for the OEM ambient lighting? I know certain vehicles like a 2011 Fusion have lighting in the back as well as the front. Do all vehicles use the same ambient lighting control module? Would it be possible to add lighting to the back using OEM parts that would plug into the factory module? You would think if every vehicle used the same module, there should be a spot to plug in the one or two additional LED bars for the back seats.
SilverPony2001 is offline
Old 05-27-2013, 08:46 PM   #2
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,045, Level 50
Points: 6,045, Level: 50 Points: 6,045, Level: 50 Points: 6,045, Level: 50
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 4%
FF Reputation: 9 Deftmetal Good Standing Member
The focus buttons to control the lights is expensive. I am not sure but the bcm probably controls the lights. You may be able to tap into part of the lighting and run more lights because LEDs have such low current draw.
I'm sticking with my amazing grammar.
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
Old 05-27-2013, 09:06 PM   #3
oritpro
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
FF Reputation: 2 oritpro Good Standing Member
Adding LEDs is a little more complicated than adding incandescent bulbs.
Where one would simply add bulbs in parallel knowing that the resistant will drop and therefore the circuit will simply require more power, LEDs are more complex in that they operate within a very small window of minimum and maximum forward voltage.
I haven't looked at the control module but there's probably a limiting resistor of a specific value that was calculated to operate with a specific number of LEDs wired in a series/parallel combination with known electrical characteristics (If, Vf).
In other words, unless you know exactly what you're doing you're better off with a third party solution.
oritpro is offline
Old 05-27-2013, 09:17 PM   #4
SilverPony2001
Fan#: 27073
Forum Activity 4%
I'm asking more if the ambient control module is the same in every car. If so, you would assume there would be spots on the module to plug in the two missing lights for the rear.
If you look at this picture:
It looks like it has 2 lights in the front footwells, 2 lights per door storage bin, 2 lights per door handle, and a light in the cup holder. The Focus has all these as well. But there are also 2 more lights in the rear foot wells that the Focus lacks. If we were to assume whatever controls the ambient lighting is the same in every car, there should be a place to add those additional lights.
On a side note, did the 2011's have back ambient lighting?
Old 05-27-2013, 10:01 PM   #5
oritpro
oritpro's Avatar
Fan#: 96148
If this Ebay auction is to be believed then yes, the module is the same in quite a few Ford vehicles.
http://www.ebay.com/itm/OEM-STOCK-FO...5c46a5&vxp=mtr
oritpro is offline
Old 05-28-2013, 10:22 PM   #6
focus wht
Fan#: 49023
What I Drive: 2013 Focus TI White Platinum
FF Reputation: 1 focus wht Good Standing Member
I have added the rear ambient lights to my Ti focus . Purchased 2 new front ambient lights and installed them under each front seat to focus the on the rear footwells. Tap into each front under dash lights same polarity connections . Almost no additional electrical draw. these help brighten up the dark black rear interior and look great.
focus wht is offline
Old 05-28-2013, 10:36 PM   #7
SilverPony2001
Fan#: 27073
Forum Activity 4%
Did you wire them all the way up to the front to tap into the front OEM lights? Or is there any place in the center console they converge? Any pics?
Old 05-28-2013, 11:39 PM   #8
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,316, Level 64
Points: 9,316, Level: 64 Points: 9,316, Level: 64 Points: 9,316, Level: 64
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
Write-up? Part numbers? COME ON MAN!
Pics or it didn't happen.
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 05-29-2013, 09:56 PM   #9
focus wht
Fan#: 49023
Ok I wired them up to the front ambient lights 1 each side . Came along door sill then up through carpet under seat where factory seat wiring exsists. Bought the 2 front ambient lights and lenses along with 2 factory pigtail connectors. Just tie rapped the new lights under front seat to seat frames. Matched the wire for wire front to rear lights. They work and look great. Can be dimmed and change colours just like the fronts.
Old 05-29-2013, 10:06 PM   #10
SilverPony2001
Fan#: 27073
Forum Activity 4%
Do you have any pics of the install or part #'s you used?
From what I found out, the part number for the "Long Bar LED" is BE8Z-13E701-A.
The part number for just the single "LED with Lense" is 7S4Z-13E701-AE
Did you use the BAR style or just the single LED with Lense?
