Steeda vs. K&N CAI - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2013, 09:22 PM   #51
Vanquished
Vanquished's Avatar
Fan#: 114099
What I Drive: 2013 Dodge Charger R/T Plus
Points 886, Level 15
Points: 886, Level: 15 Points: 886, Level: 15 Points: 886, Level: 15
Level Up 86% Completed
FF Reputation: 1 Vanquished Good Standing Member
Originally Posted by Tigeo View Post
I don't understand why they don't make full use of both intake pipes...I see they utilize the lower but why not plumb the upper one over and into the heat shield?
I don't understand that either. Maybe it's too tight to get the other one around to the other side? I mean, it is REALLY tight getting this thing in/out. It's good that they include the plug because otherwise that other intake tube would be completely useless.
Vanquished is offline
Old 06-11-2013, 10:20 PM   #52
yoshi1015
yoshi1015's Avatar
Fan#: 115360
What I Drive: 2013 Black Ford Focus Hatch SE
Points 117, Level 2
Points: 117, Level: 2 Points: 117, Level: 2 Points: 117, Level: 2
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 1 yoshi1015 Good Standing Member
Originally Posted by Vanquished View Post
Very nice, so shiny :)
Here is my Steeda (pretty bad pic I know, I took it at night)
man that is sweet! i need a heat shield like that! very nice!
Daniel Young
yoshi1015 is offline
Old 06-11-2013, 10:34 PM   #53
Vanquished
Vanquished's Avatar
Fan#: 114099
Probably wouldn't be too hard to make one, could even use rivets lol.
I really like the pipe that came on your Injen, wish mine (the stock one) wasn't so restrictive
Old 06-12-2013, 12:35 AM   #54
yoshi1015
yoshi1015's Avatar
Fan#: 115360
Points 117, Level 2
Forum Activity 4%
yes i will try and make one and send you some pics if it turns out good
Daniel Young
Old 06-12-2013, 07:03 PM   #55
ProjectCommuter
ProjectCommuter's Avatar
Fan#: 105046
What I Drive: 2012 Oxford White Focus SE 5MT
Points 602, Level 12
Points: 602, Level: 12 Points: 602, Level: 12 Points: 602, Level: 12
Level Up 4% Completed
FF Reputation: 2 ProjectCommuter Good Standing Member
You can see that Steeda made a box but had to use the rubber stock hose to the TB because of space restrictions. Injen used a smoother and arguably more precise tube for better flow and safe AFRs (as they say). I don't think heat is such a big issue. I mean if it is a hot day out there is no such thing as a "cold air" intake, heat shield or not. I personally like Injen's products. They are very well made and for the most part affordable. So I go with them. Also, rotate your shield so that the two Injens line up. That way the air is drawn from behind the headlight and grill and not from up under the hood. I believe that is the way it was designed.
ProjectCommuter is offline
Old 06-13-2013, 03:57 PM   #56
tj@steeda
FF Affiliate
tj@steeda's Avatar
Fan#: 93195
What I Drive: 2011 Red Steed Focus
Points 1,498, Level 21
Points: 1,498, Level: 21 Points: 1,498, Level: 21 Points: 1,498, Level: 21
Level Up 98% Completed
FF Reputation: 2 tj@steeda Good Standing Member
The reason we didn’t use a custom hose from the Mass air to the TB on the 2012 Focus is because there is nothing to be gained by changing it. It’s an Naturally aspirated application and that 6” section of tube will do nothing for the performance.
The air fuel ratio is calculated by the amount of air to pass by the mass air meter, that’s what it does. It meters the air and adds the correct amount of fuel. Our Mass air meter is made out of BILLET aluminum and is highly precise holding a tolerance of +/- .0005. It will be much more accurate then the Injen tube, which is just exhaust tubing shined up. So the Steeda CAI will maintain a better AFR then the Injen kit, period.
Lastly, if you look at their kit there are no provisions for the factory cold air feeds, on the Steeda there is. We rely on the OEM feeds to give you the most cold air possible. Can’t tell me Ford didn’t know what they were doing, just like the intake tube. If there was an issue with “safe” AFR then they wouldn’t have gone into production with that tube (from the mass air to the TB).
Best Regards,
TJ
Steeda Autosports - American Made Parts For An American Icon
954-960-0774 - Worldwide Sales/Installation Appointments/Tech Support
Installation locations in Pompano Beach Florida and Valdosta Georgia
tj@steeda is offline
Old 06-13-2013, 06:31 PM   #57
yoshi1015
yoshi1015's Avatar
Fan#: 115360
Points 117, Level 2
Forum Activity 4%
oh great advice! I was looking at the photo and see what you are talking about. I will align the two logos
thanks,
Daniel Young
Old 06-13-2013, 07:03 PM   #58
Tigeo
Tigeo's Avatar
Fan#: 113481
What I Drive: 2013 Ignot Silver Focus HB
Points 3,507, Level 37
Points: 3,507, Level: 37 Points: 3,507, Level: 37 Points: 3,507, Level: 37
Level Up 5% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 2 Tigeo Good Standing Member
Originally Posted by tj@steeda View Post
The reason we didnít use a custom hose from the Mass air to the TB on the 2012 Focus is because there is nothing to be gained by changing it. Itís an Naturally aspirated application and that 6Ē section of tube will do nothing for the performance.
The air fuel ratio is calculated by the amount of air to pass by the mass air meter, thatís what it does. It meters the air and adds the correct amount of fuel. Our Mass air meter is made out of BILLET aluminum and is highly precise holding a tolerance of +/- .0005. It will be much more accurate then the Injen tube, which is just exhaust tubing shined up. So the Steeda CAI will maintain a better AFR then the Injen kit, period.
Lastly, if you look at their kit there are no provisions for the factory cold air feeds, on the Steeda there is. We rely on the OEM feeds to give you the most cold air possible. Canít tell me Ford didnít know what they were doing, just like the intake tube. If there was an issue with ďsafeĒ AFR then they wouldnít have gone into production with that tube (from the mass air to the TB).
Best Regards,
TJ
It looks like you only use 1 of the factory cold air feeds from the radiator support - why didn't you plumb the other one to the box?
If its not grown it's mined!
2013 Ingot Silver Focus SE HB manual, 201a, winter pkg, moonroof. Snorkel delete/K&N drop/ST inlet. FSWerks RMM poly insert.
Tigeo is online now
Old 06-14-2013, 09:58 AM   #59
tj@steeda
FF Affiliate
tj@steeda's Avatar
Fan#: 93195
In order to run both factory CAI feeds we would have needed to incorporate a top into the Steeda CAI kit. We also would need to have a much more complicated, and expensive base to line up with the top factory CAI feed because the OEM air box is not square as seen here. In our testing we found that by plugging the top feed and relying on the just the bottom feed to supply cold air to the underside of our open air filter worked very good. Then we looked at the cost verse performance and found our current option to be the best design to achieve both.
Best Regards,
TJ
Old 06-14-2013, 10:11 AM   #60
Vanquished
Vanquished's Avatar
Fan#: 114099
Hey TJ,
Is the Steeda C.A.R.B certified? I live in MA and would really love not having to take out my intake when I pull the car in for inspection every year.
I have the Steeda (as pictured)
