Dropped valve seat. Chances of bending a connecting rod? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > SPI Performance (2000-2004)
Old 05-26-2013, 06:41 PM   #1
ImBillT
Fan#: 114943
What I Drive: 2001 Red SPI
FF Reputation: 1 ImBillT Good Standing Member
So my wife's focus just wouldn't start when she tried to start it last. Did a comp check and found out it dropped a valve seat. The engine hasn't been run since. I started it twice and it sputterd, coughed and died. Most of the ones i read about get driven a little before they are diagnosed. Since the thing has probably been cranked for less than 60 seconds total since it happened, is there any chance the rod is still good?
ImBillT is offline
Old 05-26-2013, 07:09 PM   #2
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
Points 13,120, Level 74
Points: 13,120, Level: 74 Points: 13,120, Level: 74 Points: 13,120, Level: 74
Level Up 68% Completed
Forum Activity 2%
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
I highly doubt a valve could do any damage to a rod. There might be some carnage to the top of the piston, but most likely still useable.
04 ZX3 Mostly Stock ["Best Non-SVT" FITF '12][3/13 ROTM][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 05-30-2013, 07:47 PM   #3
p58ff
p58ff's Avatar
Fan#: 25247
What I Drive: 2010 Red 4-Door SES
FF Reputation: 1 p58ff Good Standing Member
I spoke with some longtime friends and Ford mechanics. Their procedure is to replace the rod and piston in the damaged valves cylinder. Three mechanics, all pros, same opinion.
If the piston has been whacked, even a little, chances are the piston and rod are toast.
I am going through the process right now as my Focus lost #4 cylinder last week. Read the other thread about this.
Take care!
p58ff is offline
Old 05-31-2013, 01:42 PM   #4
ImBillT
Fan#: 114943
Thanks man. It seems rare, but mine dropped a seat on #1. Ordered one rod. Now that the head is off I wonder if my wife cranked on it more than I realized. Cylinders #3 and #4 have some chunks in them as well.
ImBillT is offline
Old 05-31-2013, 09:07 PM   #5
p58ff
p58ff's Avatar
Fan#: 25247
One thing that was really emphasized to me was to clean out all of the passages in the intake, the vacuum lines, the lines to the EGR, etc. Also clean the bottom of the intake below the throttle body. They tell me that if there is junk in those places, metal bits, it gets sucked into the cylinders again and *POOF* another head bites the dust. Clean it all, be anal about it to save yourself future grief.
p58ff is offline
Old 06-02-2013, 05:29 AM   #6
amc49
Fan#: 96610
Points 2,941, Level 33
Points: 2,941, Level: 33 Points: 2,941, Level: 33 Points: 2,941, Level: 33
Level Up 28% Completed
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
FF Reputation: 23 amc49 Great Standing Member
Depends on the piston/head damage. More means rod bent. If pieces of ring land came loose then by all means change it.
'I highly doubt a valve could do any damage to a rod.'
And at 8600 posts, too. Lost, oh so lost.......................
amc49 is offline
Old 08-15-2013, 01:58 PM   #7
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
ANY nicks (unless very very VERY minor) require a piston AND rod change, period, why chance it?
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
Old 08-18-2013, 10:06 PM   #8
amc49
Fan#: 96610
Forum Activity 41%
Yes, they need to be pretty small nicks...............
amc49 is offline
Old 08-20-2013, 03:50 PM   #9
rnewscates
Fan#: 97162
What I Drive: 2000 Focus SPI, 1978 Lotus Esprit
FF Reputation: 1 rnewscates Good Standing Member
Hello, I recently bought a 2000 SPI (Craigslist for $800), it had dropped a #1 seat, I got it from a shop and the head was off and missing. I pulled the engine and rebuilt it on a stand, with new (standard) pistons and rings, new (standard) bearings (at 115K still looked new), lightly honed the cylinders, and rebuilt / corrected head - in the process I am glad I did the pistons, because #1 was broken in two about the pin, and also the rod was bent at the pin so I had to replace that too (rebuilt, $28). The engine rebuild went very well, I am very impressed with the block. I only have about $600 in it, it is back in the car already and should be ready to start in a few days - my first Focus, I have never even been in one before! So, don't gamble when doing an SPI with a dropped seat - it is not that hard to drop the oil pan and undo a rod and pull a piston to inspect and make sure when putting on a rebuilt head or you may have to pull the head again! Plus new pistons and rings were only $170, well worth it. Bob Scates, Virginia
rnewscates is offline
Old 08-20-2013, 08:54 PM   #10
amc49
Fan#: 96610
Forum Activity 41%
With that kind of a break I'da been looking VERY close at the cylinder wall there, not impossible to crack a wall out too.
And yes, with cast pistons people often look at piston top and then make the judgement the piston/rod are fine, of course they're not. Cast pistons are brittle and can look pretty good on top and be garbage at the ring lands or skirts.
amc49 is offline
