2005 Ford Focus 2.0 SES, passenger side engine noise. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-25-2013, 04:21 PM   #1
dingoqing
Fan#: 109818
What I Drive: 2005 ford focus zxw
FF Reputation: 1 dingoqing Good Standing Member
Recently, after two and half highway drive and 10 days long-term park in airport, I have found an aperiodic ticking noise come from the passenger side of the engine( i.e. the time chain side). It is not the periodic ticking noise from injector for sure, which is also on my engine. It does like something is knocking the engine.
In addition, the noise comes only when I put to 'D' or 'R' with the car stopped by brake pedal (like stopping at the traffic light) . If I put to 'P' or 'N', the noise disappears. If I start to drive, the noise disappears too. I also noticed when braked at 'D' or 'R', the rpm is pretty low (like about 750), otherwise it has a idle rpm of 800 at 'P' or 'N'. This has make me feel that the noise only occurs at very low rmp but I'm still not quit sure if my feel is right.
The detail can be found in following video taken under the engine:
http://www.youtube.com/watch?v=RYrpihiO0gI.
YouTube Video
My wife is in the driving cabin to control the engine. In the first several second, the transmission is put in 'D' without braking. You can see the transmission axle is rotating, with no strange noise. When braking occurs, the rotation stops of course, and the noise comes out from the passenger side of the engine.
Anybody has any idea what should I do. Thanks
dingoqing is offline
Old 05-25-2013, 09:04 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Probably tumble flaps. It will get worse. Most shade trees think it's caused by bad valve adjustment. Real diagnostics reveal the noise to be in the intake not the valve cover.
I don't suggest you do that since it's not making noise unless you have it in gear with someone's foot on the brake. That seems to be an unsafe time to be in front of the car, touching the car, or anything else except watching the car. If it's tumble flaps, and you mileage is low, like 60k or 80k, it will get worse. Mine has 150k, the sound started around 100k.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 05-25-2013, 09:13 PM   #3
dingoqing
Fan#: 109818
My focus only have 78k on it.
So what I should do is just leave it until it is more serious?
By the way, I have change the valve cover gasket one month ago, but I don't think if I have left something in it.
Should I open the valve cover to check or directly go to to mechanist immediately?
Thanks.
Old 05-26-2013, 12:24 PM   #4
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
Mine made knocking noises under those conditions and it turned out to be one of the engine mounts had gone away allowing the engine to move to far and cause engine vibrations to be transferred directly into the cabin area. So if I were you I would make sure it's actually the engine and not the lower engine mount under the car allowing metal on metal contact against part of the cars structure.
don627 is offline
Old 05-26-2013, 08:20 PM   #5
dingoqing
Fan#: 109818
Thanks. However I'm pretty sure it come from inside of the engine . Anyway, I will keep an eye on it and update the status here.
