Blown engine at 35000 miles - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-31-2013, 09:29 AM   #81
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Originally Posted by 2013TitaniumHatch View Post
My best GUESS is the engine was run low on oil to begin with. Engine ran hot, the variable valve timing system, which needs oil pressure to operate, was not getting the oil so the valve timing was off (I believe the variable cam timing, intake and exhaust can vary 30 degrees on this engine) and made contact with piston.
IMO, this guess could explain the tapping and bent valves. It would not explain a "burned" piston though, if that was truly the case.
Hatch Nation #90
TboneZX3 is offline
Old 05-31-2013, 09:33 AM   #82
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,071, Level 50
Points: 6,071, Level: 50 Points: 6,071, Level: 50 Points: 6,071, Level: 50
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 9 Deftmetal Good Standing Member
Originally Posted by TboneZX3 View Post
I don't believe your case is related to the OP's burned piston. A broken piston skirt causing oil control ring leakage is nothing like a piston with a hole burned through it, and far less catastrophic.
I told my expierience because the person I quoted seemed sceptical about an engine burning so much oil. They never showed me my broken piston and I was told different things by different people with no conclusive explanation for cause
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is online now
Old 05-31-2013, 09:41 AM   #83
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
See below (bold emphasis added by me):
My engine was replaced at 22766km or regular not very agressive driving for a hole melted threw one of the pistons. I started noticing oil loss at 12000km so it happened before then. Not sure exactly when because I didn't check oil after initial delivery until then.
OK, I understand that you don't truly know what happened. But, you are willing to state in one place that the bottom of the piston was broken, and yet in another you tell us a hole was melted through your piston. Were you not trying to relate your case to the OP's when you stated that a hole was burned through your piston?
Hatch Nation #90
TboneZX3 is offline
Old 05-31-2013, 10:56 AM   #84
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
I was told both and didn't see it
Josh
Old 05-31-2013, 01:03 PM   #85
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,554, Level 100
Points: 52,554, Level: 100 Points: 52,554, Level: 100 Points: 52,554, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (28)
Your right Tom never check your oil. There is in no way any benifiet to doing so, it certainly wouldn't show potential internal engine problems. Everything you say is dogma
Will you please show me where is said to never check your oil or that is was not worth doing
dogma ? Factual would of been a better word
low oil wouldnt cause a burned piston but a burned piston can cause low oil
The 2012up Focus runs lean , add mods and in most cases it gets leaner , this is what burns the pistons
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-31-2013, 01:11 PM   #86
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,652, Level 97
Points: 26,652, Level: 97 Points: 26,652, Level: 97 Points: 26,652, Level: 97
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 9 TORQUERULES Good Standing Member
I think we can all agree to disagree. I am just glad the OP is getting his car fixed.
I believe this dead horse has been beat to a pulp...
TORQUERULES is offline
Old 06-05-2013, 07:22 PM   #87
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
I thought that is what PCM's and O2 sensors were for to maintain a 14.7:1 fuel ratio darn how lean is my 2012 when I add the 2013 ST turbo but with lower boost due to 12:1 compression I don't see aftermarket CAI or exhaust leaning a motor enough to burn a piston. For the concern about engine ticking think of how this engine is designed and works now how a modern diesel works this is just a low compression diesel with spark plugs and gives great mileage so I can live with tick, tick, tick.... LOL
Seminoles is offline
Old 06-05-2013, 10:48 PM   #88
Cruisin
Cruisin's Avatar
Fan#: 108722
What I Drive: 2013 Ruby Red Focus SE
FF Reputation: 0 Cruisin Poor Behavior Needs Improvement
Sounds like running premium fuel would be a good idea for this engine. I think you get slight hp gains (2 hp) as well, but the oil rich premium would prevent the engine from running too lean. At least that's how I understand it.
Cruisin is offline
Old 06-11-2013, 04:40 PM   #89
yoshi1015
yoshi1015's Avatar
Fan#: 115360
What I Drive: 2013 Black Ford Focus Hatch SE
Points 117, Level 2
Points: 117, Level: 2 Points: 117, Level: 2 Points: 117, Level: 2
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 1 yoshi1015 Good Standing Member
Originally Posted by tukaniSVT View Post
Wow ... I haven't heard that happen before.
But glad to hear that Ford is covering it for you. That's very nice of the warranty.
Ray
yes no kidding the dealers here are loving to document and try and decline warranty with mods like cold air even with cat back...glad it worked out for you
Daniel Young
yoshi1015 is offline
Old 06-21-2013, 10:20 AM   #90
hemetaj
Fan#: 110422
What I Drive: 2012 Red Focus SEL
FF Reputation: 1 hemetaj Good Standing Member
Originally Posted by mustang0 View Post
Does anybody know how much is stock air box costs in case I have the samething happen and have to go back to stock to get warranty coverage. I'm thinking they would try and put blame on New Mission mod.
Free if you would of kept it like I did.
Numbered Cargo
hemetaj is offline
