Blown engine at 35000 miles - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-27-2013, 12:04 PM   #41
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,652, Level 97
Points: 26,652, Level: 97 Points: 26,652, Level: 97 Points: 26,652, Level: 97
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 9 TORQUERULES Good Standing Member
This^^^^
TORQUERULES is offline
Old 05-27-2013, 12:19 PM   #42
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
Originally Posted by 1turbofocus View Post
I know of WAY more then 2 of these engine going , way way way more lol
The order has come down like stated , NO WARRANTY on modded anything under the hood of the MKIII
You even go to colored hoses ... good luck
Good thing I didn't buy your tune and a wideband.
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 05-27-2013, 12:30 PM   #43
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2014 Tuxedo Black SE Sport
Points 1,751, Level 24
Points: 1,751, Level: 24 Points: 1,751, Level: 24 Points: 1,751, Level: 24
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
Forum Activity 30%
FF Reputation: 5 StingRay Good Standing Member
I just looked at the dyno thread again and I only saw 2 cars that the AFRs seemed wacky on. But it looks like sonic_hedgehog and craigsfocus had almost perfect AFRs, and like I said mine always read around 12.5.
And I'd also like to know where you're hearing about these popped engines, as you always seem to have so much exclusive information, Tom.
StingRay is offline
Old 05-27-2013, 01:29 PM   #44
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 550, Level 10
Points: 550, Level: 10 Points: 550, Level: 10 Points: 550, Level: 10
Level Up 50% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
Originally Posted by Deesiel678 View Post
+1
I keep seeing people suggest that this engine runs lean, but the dyno's with wideband readings in the MK3 dyno thread suggest that the car runs on the rich side. Where does this belief that the Mk3 runs lean come from? Maybe the target AFR during partial throttle open loop fueling is above stoich?
Oops... meant closed loop.
You may want to go back and look at those dynos again , everyone of them is 13 or above , this engine like most NA Foci should be in the 12.8 range and closer to the 12.5 for racing it on track
Maybe if you try to decipher the information on the graph without reading through the accompanying thread, one may assume that these cars are running relatively lean...
BUT if one actually reads the thread, they will find that:
1. 2012+ Focus uses a wideband front o2 sensor
2. The car remains in closed loop at WOT
3. The commanded and actual AFR was about 12.5 at WOT (this was on a car with no modifications)
Even the owner of the dynoed car mentioned that his AFRs were actually in the ~12 range at WOT.
(This thread)
StingRay saw the same results, as well as the other owners he mentioned...
I will datalog my car later as well when I have time.
Again, I don't see where people get the notion that the car runs lean stock when the data shows otherwise.
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 05-27-2013, 02:08 PM   #45
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,718, Level 94
Points: 23,718, Level: 94 Points: 23,718, Level: 94 Points: 23,718, Level: 94
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 12%
Originally Posted by electricbeach View Post
I know BMW had an issue with carbon on the v8s, causing a costly head cleaning to properly fix the buildup.
And good point about the oil. I should look into it, as well as any other owner. I do doubt that ford or any other manufacturer would require a specific oil because we all know many owners will not bring their vehicles to the dealer for oil changes.
I bet ford's "faces" would be red when in a few years tons of engines blow.
They do have factory oil specs... GM has about 6 different types, ford about 5 etc. Now I'm interested in making a thread again, but my point is that even from the same manufacturer, one 5w-30 may be thinner or thicker than the other. The idea is to use oil with the same properties as factory fill, as it is designed by the engineers to match the characteristics of an engine. If you use the wrong stuff, your warranty can be denied. This is their way around having red faces. I have heard of engine failure on an engine with only 500 miles because of improper oil.
Ever wondered why they offer maintenance packages now? That's kind of their way around wasting millions on replacement engines.
I just thought it was interesting... we have always been taught that all we need to know is if it has the API and ILSAC labels, it's good. They're meaningless. Go look at a bottle of Castrol edge, for example. See how it meets specific ACEA ratings that say, SuperTech, doesn't.
If you want to look into it more, I would like to make a thread on it... in the meantime, check out the data sheets for your favorite oil. Specifically the "cSt at 100°" number. a lower number indicates a thinner oil. Factory Toyota specifies 10w30 for my engine, but I went with 5w30 Castrol Edge because it had the closest cSt to the factory oil. their 10w30 was far too thick.
whoops off topic... oh well.
mikebontoft is online now
Old 05-27-2013, 03:35 PM   #46
FocusTi
FocusTi's Avatar
Fan#: 102567
What I Drive: Black 2012 Ford Focus Titanium
FF Reputation: 1 FocusTi Good Standing Member
I find this hard to believe that if you have any mods on your MKIII, that you warranty is void. I went to the dealer with an issue with my transmission acting a little off and they had no problem with my intake and exhaust. If your statement was true, they would have turned me away. And there is no way that they did not see them. They updated my software and the trans has been great since.
Current Mods: Snorkel Delete with ITG Filter and newmission intake, Rear Sway-Bar, Magnaflow Exhaust, RMM and Hitch
Future Mods: Coilovers, End-Links, Tune, and Brakes
FocusTi is offline
Old 05-27-2013, 04:16 PM   #47
Deesiel678
Deesiel678's Avatar
Fan#: 105147
+1
Obviously isn't true... after all, the OP got his engine replaced under warranty and the car had mods...
Old 05-27-2013, 04:23 PM   #48
MG_MK3
MG_MK3's Avatar
Fan#: 114522
What I Drive: 2013 Blue Candy Focus Hatchback SE
Points 500, Level 9
Points: 500, Level: 9 Points: 500, Level: 9 Points: 500, Level: 9
Forum Activity 4%
FF Reputation: 0 MG_MK3 Newbie
I didn't know warranty work was up to Ford to decide... I always thought it was the mechanics at said dealership to determine weather or not modification caused said problem to occur and if this can not be proven then Ford will pay said dealership to repair/replace problem.
Bottom line is; Ford pays the dealership to fix the problem. I don't think they would want to turn someone away.
If I am wrong do not shoot me.
2013 "Blue Candy" Focus Hatchback SE/DCT
AEM CAI | Steeda RMM | ST wing | TTR UMM
2.5 inch straight pipe | 3SDM 0.05 18"x8.5J | KSport Kontrol Pro's
Instagram @miKeyGilmore #MK3SLöCUS
MG_MK3 is offline
Old 05-27-2013, 04:33 PM   #49
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,525, Level 100
Points: 52,525, Level: 100 Points: 52,525, Level: 100 Points: 52,525, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
Some is exclusive some isnt , all you have to do is look , ask and know people , I am in the Focus business it wouldnt be wise for me not to know whats happening so I stay in contact with people in Ford and many many dealerships that I do work for or friends or Family in
Need to look through those dynos again there all lean in my opinion, Mine is as well and the few I have had on my dyno ... all lean
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 05-27-2013, 04:38 PM   #50
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 55%
No one is going to shoot you , "Ford" has control over what gets covered not the dealership ,
You take your car in with a blown engine , the dealer does the work it is a area warranty rep (traveling rep) that makes the final decision who gets what warranty on major parts , the mechanic has little to no say so at all when it comes to warranty
Ford dealerships can actually get in some trouble if they do "to much" warranty work
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
