Head questions??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 05-25-2013, 02:54 AM   #1
2011 FOCUS SE
2011 FOCUS SE's Avatar
Fan#: 108409
What I Drive: 2011 FORD FOCUS SE
FF Reputation: 1 2011 FOCUS SE Good Standing Member
Head questions???
Ok guys i have everything planned out.. So i am ordering a 2.3 head from ebay here is the item number 170913248841. Will this work? I called.the guy and he asked for the cast number i told.him what i was doing he said thats crazy and he asked.if.i had vvt? So i need some help does the cast number matter and do i order a head with vvt? And does any body know what.the stock compression ratio is for my 2011 2.0? And one last question when i get the 2.3 head after i get some feedback on what matters and what options to get then i am going to send the.head to machine shop to mill how much do i take off to raise the compression ratio to where i dont hit piston and with spray dont unload the bottom end? And as for cams i have heard alot about the crane 224-0010 i am planning to do aftermarket cams on the 2.3 head these 224-0010 still the way to go? If i can go bigger will it effect hp/tq? Just looking fir the right cams for my set up so any input will be great thanx...
2011 FOCUS SE is offline
Old 05-25-2013, 03:21 AM   #2
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
None 2.3 head has vvt have to check out cause the head of the 2.3 from the ranger truck is the 2.0 head Rhe stock compression on ur car is 10.1.0
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 05-25-2013, 07:41 PM   #3
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
If you mill the head you'll raise the compression. The crane 0010's are a mid range. For you going a 20 motor w/ a 23 head, I'd use those. You could add the 0012's, but you'd lose some bottom end grunt. 1st you have a 20 & then 2nd installing a 23 head on a 20. I like spray too, I just don't like running out & dealing w/ refilling the bottles. I'd cc the chambers & compare the 2 heads.
felixthecat is offline
Old 05-26-2013, 12:41 PM   #4
2011 FOCUS SE
Fan#: 108409
Ok so i now have my cams chosen and now with the head does the cast number matter since im not putting the head on a 2.3? And i am planning on spraying mabey a 25 shot i so want to raise the compression ratio so i need to findout what do i raise it to for street driving with cams intake exhaust and tune to know how much i need to mill the head?.?.
Old 05-26-2013, 01:47 PM   #5
koke'sfocus
Fan#: 69779
25 shot is nothing do. 50 at least
team duratec #94
D23 crew #9.
Old 05-26-2013, 02:04 PM   #6
2011 FOCUS SE
Fan#: 108409
Aight 50 it is no more though.. Dont want to blow bottem end.lol. I am also going to arp stud the head.
Old 05-26-2013, 04:32 PM   #7
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Why would you need to raise the compression ratio to run nos?
Old 05-26-2013, 05:02 PM   #8
2011 FOCUS SE
Fan#: 108409
I dont need to raise to run nos i just want to raise to creat more hp.
Old 05-27-2013, 06:07 AM   #9
jugglethese
jugglethese's Avatar
Fan#: 108852
What I Drive: 2007 focus gloss black SAP zx3
Points 1,619, Level 23
Points: 1,619, Level: 23 Points: 1,619, Level: 23 Points: 1,619, Level: 23
Level Up 19% Completed
FF Reputation: 1 jugglethese Good Standing Member
post pics and videos when you get started on the swap :) im sure were all curious on how this is going to go
jugglethese is offline
Old 05-27-2013, 04:35 PM   #10
Fernando_221
Fan#: 79468
What I Drive: '06 ZX4 2.0L Dtec, '11 MK2.5 2.0L
Points 1,863, Level 25
Points: 1,863, Level: 25 Points: 1,863, Level: 25 Points: 1,863, Level: 25
Level Up 63% Completed
FF Reputation: 3 Fernando_221 Good Standing Member
You should look for a PN on the exhaust ports side of the head.
RF 1S7G is stock 2.0 head (and Ranger 2.3).
RF 3S4G is the one with better flow.
felixthecat, for the crane 0012, do we need upgraded valve springs?
Fernando_221 is online now
