2013 Focus TI "disabling" one touch power windows - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-24-2013, 09:50 AM   #1
sportage
sportage's Avatar
Fan#: 113131
What I Drive: 2013 Blk FORD FOCUS TITANIUM
Points 457, Level 9
Points: 457, Level: 9 Points: 457, Level: 9 Points: 457, Level: 9
Level Up 14% Completed
FF Reputation: 1 sportage Good Standing Member
I can't seem to disable this feature. I see a lot of threads on how to enable one touch, but I wanted to disable it. Tried the power-down, hold button 5 seconds, power-up, hold 5 seconds as well as attempted other versions of the sequence all with no success. Can't one-touch be disabled via a button sequence?
Thanks fanatics!
sportage is offline
Old 05-24-2013, 09:57 AM   #2
XlarXlar
XlarXlar's Avatar
Fan#: 111735
What I Drive: 2013 PB Ford Focus
Points 246, Level 4
Points: 246, Level: 4 Points: 246, Level: 4 Points: 246, Level: 4
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 2 XlarXlar Good Standing Member
I've never heard of anyone doing that. Mine has only stopped working by itself and I've then had to fix it...
I don't know how you would go about doing this. There must be some way to trick the switch into forgetting where the extreme positions of the switch are so that even when it is fully depressed or pulled it doesn't think it has gone far enough to activate the one touch. Maybe if you try just pulling/pushing it in one direction for 5 seconds?
Also, because I'm curious, why do you want to do this?
XlarXlar is offline
Old 05-24-2013, 10:02 AM   #3
kevinxb
kevinxb's Avatar
Fan#: 96008
What I Drive: 2012 Blue Candy Ti Hatch
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 2 kevinxb Good Standing Member
Buy-Sell-Trade Rating: (4)
It gets disabled when the battery is disconnected. So I'd just remove the ground for a minute and don't do the sequence to restore it.
kevinxb is offline
Old 05-24-2013, 10:04 AM   #4
sportage
sportage's Avatar
Fan#: 113131
Points 457, Level 9
Don't care for one touch. I prefer the window only react while I depress the button. I mess with the button(s) and windows constantly trying to get just the opening I want. Finally I give up. The one touch control buttons are just too touchy. (no pun)
I don't mind one touch on the drivers window, maybe, sometimes, but the other windows? Nope.
sportage is offline
Old 05-24-2013, 10:06 AM   #5
sportage
sportage's Avatar
Fan#: 113131
Points 457, Level 9
yeah I read that battery thing in other threads but didn't want to mess with the battery since Im not sure what else that might mess-up considering the high techy-ness of the TI focus.
PS. I might have to call the dealer. They assigned a tech guy to the car after purchase to demonstrate the features, set things up for you, and answer any questions.
When you buy a car that needs a tech guy assigned to it, you know this is not your typical automobile. :D
sportage is offline
Old 05-24-2013, 10:07 AM   #6
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,070, Level 67
Points: 10,070, Level: 67 Points: 10,070, Level: 67 Points: 10,070, Level: 67
Level Up 5% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
If you only want the window to go down a certain point don't just push the button once, hold it down until it gets to where you want to stop it and then pull up slightly, or while it's going down automatically pull up to stop it from completely opening.
I can't see a need or desire to remove the functionality, but there are always work arounds.
suss6052 is online now
Old 05-24-2013, 10:13 AM   #7
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,361, Level 57
Points: 7,361, Level: 57 Points: 7,361, Level: 57 Points: 7,361, Level: 57
Level Up 6% Completed
Forum Activity 11%
FF Reputation: 13 kam327 Great Standing Member
Why even do that? The button has two engagement levels. Just push it down halfway and window movement will stop when you release the button. One-touch down only works if you push the button all the way down.
Least that's how it is on mine.
Which brings up the question - why is it disabled when the battery is disconnected? Mine's been in the shop twice recently, battery disconnected both times, and both times I have to go through the annoying process to reset it.
kam327 is offline
Old 05-24-2013, 10:15 AM   #8
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 11%
Dude just disconnect the battery as suggested. Mine's been disconnected numerous times and all it does, besides screw up the one-touch feature, is reset your trip computer and date/time.
Strangely, though it resets your trip computer information, it doesn't delete your radio presets. Why would that be?
kam327 is offline
Old 05-24-2013, 10:37 AM   #9
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 509, Level 10
Points: 509, Level: 10 Points: 509, Level: 10 Points: 509, Level: 10
Level Up 18% Completed
FF Reputation: 1 asting Good Standing Member
The "tech guy" was just the salesman in my case. He just hooked up my phone, and when I say, "he just hooked up my phone" I mean that he fumbled around for 5-10minutes while I guided him through setting up my phone.
Just read the manual. It'll have more than the "tech guy" will know.
2012 SE Hatch - 5 Speed - Tuxedo Black
Engine: K&N Typhoon CAI, Magnaflow 2.25 exhaust 15072
Suspension: MS3 Springs, Focus electric RMM.
Audio: LC6i, Polk Audio db6501 front, db651s rear, db1040DVC sub, Rockford R600-5 Prime, Fatmat
asting is offline
Old 05-24-2013, 10:44 AM   #10
GoldenHour
GoldenHour's Avatar
Fan#: 103427
What I Drive: 2014 Tuxedo Black ST
Points 1,148, Level 18
Points: 1,148, Level: 18 Points: 1,148, Level: 18 Points: 1,148, Level: 18
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 2%
FF Reputation: 3 GoldenHour Good Standing Member
I can't stand it either on any window but I just live with it .
GoldenHour is offline
