1st gear issues? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-23-2013, 07:30 PM   #1
StealthGray
StealthGray's Avatar
Fan#: 19017
What I Drive: '04 Liquid Gray ZX3
FF Reputation: 12 StealthGray Great Standing Member
Buy-Sell-Trade Rating: (6)
Unhappy 1st gear issues?
Okay, been a long time since I've been on here... I need to know if this is the beginning of the end of the Focus.
'04 2.3L ZX3, manual five-speed, fluid changed every 50k with Royal Purple, 157K on the car.
Everything normal up to leaving work today in heavy rain. NO prior symptoms, and then first gear goes out. Push the clutch in and go into first gear, and it doesn't feel like it's going all the way in. Let the clutch out and it grinds and then immediately kicks out of gear. No better if you it try putting it in first with the ignition off and starting with the clutch depressed. Clutch/brake fluid at normal level. NO other gears effected.
I'm thinking it's not syncro related because trying with the engine off doesn't change anything. I'm thinking it's not cable related because it's only first gear.
So I'm afraid I might be into the big $$$ range here, and running it from 2nd gear until it drops. I'd love to hear some ideas about what's gone wrong...
You know what a learning experience is? A learning experience is one of those things that says, 'You know that thing you just did? Don't do that.' - Douglas Adams
StealthGray is offline
Old 06-15-2013, 02:58 PM   #2
StealthGray
Fan#: 19017
So the answer from the tranny guru at work is the dog gear for first went.
I suspect the cost benefit calculation for a car with 160K on it and rust starting in is to just keep running it until the clutch fails or the wheels fall off.
But to feed my curiosity, if I were to look for a used tranny to install, would the only one that would fit have to come from another 2.3 liter engine?
Thanks!
Old 06-15-2013, 03:25 PM   #3
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 955, Level 16
Points: 955, Level: 16 Points: 955, Level: 16 Points: 955, Level: 16
Level Up 55% Completed
Forum Activity 2%
FF Reputation: 3 CotyM Good Standing Member
AFIAK there are only 2 manual trans, 1 is for the SPI, and the other is for the rest. So long as you get it from a duratac or zetec engine you should be fine, dating back to even many ZX2s and ford contour...
Very common trannies, They've been made since I think 1992 to still to this day, so I think it won't be hard :D
...and fix your rust... Letting your wheels fall off is not recommended...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
Old 06-30-2014, 07:29 AM   #4
StealthGray
Fan#: 19017
I should have updated this long ago, just in case somebody else runs into this.
I kept the coin tray in the dash full of quarters. One day the tranny started shifting normally again. Shortly after that I found a quarter on the drivers side floor? Was that the problem? Pretty sure the quarter bounced down through the dash to someplace it shouldn't have been, and that caused the problem. Tranny's been shifting fine ever since!
(173K on the car now)
Old 06-30-2014, 07:16 PM   #5
Mandroid
Mandroid's Avatar
Fan#: 150610
What I Drive: 2003 light tundra metalic SE 5spd
Points 1,108, Level 18
Points: 1,108, Level: 18 Points: 1,108, Level: 18 Points: 1,108, Level: 18
Level Up 8% Completed
FF Reputation: 1 Mandroid Good Standing Member
25 cents almost cost you your car lol. That's the best story ever
Mandroid is offline
Old 07-02-2014, 06:31 AM   #6
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 591, Level 11
Points: 591, Level: 11 Points: 591, Level: 11 Points: 591, Level: 11
Level Up 82% Completed
Forum Activity 3%
FF Reputation: 1 BrApple Good Standing Member
Just as a side note, The MTX-75 has a different bolt pattern, gear ratio and input shaft length between the Duartac V6 and Zetec that where available in the Contour/Mystique/Cougar. So it would have to come from a Zetec equipped car.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
