Luggage area lighting in hatchbacks - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 05-22-2013, 08:01 PM   #1
garyd9
Fan#: 114024
What I Drive: '13 Dark Gray Focus Titanium Hatch
FF Reputation: 1 garyd9 Good Standing Member
(Please pardon the lack of photo's - I'm trying to be as descriptive as possible)
In our hatchbacks, there are two interior lights for the luggage area immediately behind the upper area of the back seats. Both lights are... pathetic.
Opening the lights is very easy: there's a thin slot on the front edge of the lens that can be used to gently pry the lens out. The bulb holder is attached to the lens, and a wire (cable) with about 6 inches of slack is attached the bulb holder.
Actually, the bulbs inside aren't really that bad. They appear to be the same lights used in the puddle lights (if your vehicle has that option): simple 168/194 wedge style bulbs. If you replace the bulbs with brighter LED's, it increases the light, but not really by much.
The biggest problem with this arrangement is that there is NOTHING behind those bulbs to reflect the light towards the lens. In fact, the majority of the light from those bulbs is actually lighting up the empty space between the wall of your luggage area and the metal side of your car. (In other words, it's completely wasted.)
If you are going to spend the 30 seconds to replace the bulbs in there, bring some aluminum foil with you as well, and use it to create a pocket behind the bulb to reflect the light towards the lens (and into your luggage area.) The foil shouldn't actually touch the bulb, and should be wrapped in such a way that it's held in place when the lens is replaced in the car's trim.
(Be careful not to drop the aluminum foil "pocket" inside the trim of the car when putting everything back together!)
I wouldn't suggest doing this with the regular incandescent bulbs, however, as those things can get VERY hot. With LED's, it should be fine. I did it using these: http://www.amazon.com/gp/product/B009YKQR2C
Adding the aluminum foil "pocket" behind those LED's to reflect more light into the luggage area made a dramatic difference for me.
If you have the resources/time/ability, something much less fragile could be made. Even if made with a non-reflective material, it could always be lined with the same foil...
garyd9 is offline
Old 05-22-2013, 09:46 PM   #2
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,785, Level 24
Points: 1,785, Level: 24 Points: 1,785, Level: 24 Points: 1,785, Level: 24
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 16 ShoOff Great Standing Member
The bulbs you linked are those the size we need for reaplcement in the hatch?
ShoOff is offline
Old 05-22-2013, 09:50 PM   #3
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,360, Level 75
Points: 13,360, Level: 75 Points: 13,360, Level: 75 Points: 13,360, Level: 75
Level Up 28% Completed
Forum Activity 3%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (17)
I opted for a strip of 117 LED's instead
Hatch cover is still 100% completely removable.
SkyPilot is offline
Old 05-22-2013, 09:56 PM   #4
garyd9
Fan#: 114024
There's some flexibility in there.. that specific bulb works, as should any 168 or 194 "wedge" style that isn't too long.
Being it's so easy to access the bulb, I'd suggest popping it open and taking a look at how much room is there.
garyd9 is offline
Old 05-22-2013, 11:05 PM   #5
Slo86GT
Slo86GT's Avatar
Fan#: 88885
What I Drive: 2013 Sterling Gray Focus SE
Points 3,087, Level 34
Points: 3,087, Level: 34 Points: 3,087, Level: 34 Points: 3,087, Level: 34
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 2 Slo86GT Good Standing Member
Mind.... Blown. Awesome installation idea.
2013 Focus SE 5M Daily Driver
2003 Mustang GT V8/Auto Wife's Daily
1986 Mustang GT V8/5M Toy
- Jody -
Slo86GT is offline
Old 05-23-2013, 12:24 AM   #6
aperson9923
aperson9923's Avatar
Fan#: 90061
What I Drive: 2012 SGM Ti Hatch
Points 1,748, Level 24
Points: 1,748, Level: 24 Points: 1,748, Level: 24 Points: 1,748, Level: 24
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 aperson9923 Good Standing Member
How did you get power to the LEDs?
Where did you buy the strip?
2012 Sterling Grey Metallic Ford Focus Titanium Hatch
401A, Navi, MFT, Rain Sensing Wipers
Built: 11/28/11 Arrived: 12/16/11 (4 Miles)
Mods: Tint 20/5, LockPick & Backup Camera, K&N Drop In
aperson9923 is offline
Old 05-23-2013, 01:14 AM   #7
Now534
Now534's Avatar
Fan#: 76549
What I Drive: 2013 Tuxedo Black ST2
Points 1,740, Level 24
Points: 1,740, Level: 24 Points: 1,740, Level: 24 Points: 1,740, Level: 24
Level Up 40% Completed
FF Reputation: 6 Now534 Good Standing Member
I'm assuming he taped into the wiring behind those light panels.
Sent from my Rooted Galaxy S3 using FF Mobile
Now534 is online now
Old 05-23-2013, 06:02 AM   #8
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 23,764, Level 94
Points: 23,764, Level: 94 Points: 23,764, Level: 94 Points: 23,764, Level: 94
Level Up 42% Completed
Forum Activity 12%
FF Reputation: 49 dyn085 Great Standing Member
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 05-23-2013, 10:10 PM   #9
AeR0_84
Fan#: 89717
What I Drive: 12,Focus,Black,Hatch,5spd,sport pkg
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 1 AeR0_84 Good Standing Member
Buy-Sell-Trade Rating: (10)
where did you get the led light strip from?
AeR0_84 is offline
Old 05-24-2013, 07:57 AM   #10
Anthony14
Fan#: 105866
What I Drive: 13 Focus Ti Plat
FF Reputation: 1 Anthony14 Good Standing Member
http://www.amazon.com/LEDwholesalers...dp/B002QQ48TK/
Something similar to these.
Anthony14 is offline
