1500rpm idle? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-22-2013, 08:01 PM   #1
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
1500rpm idle?
What's the purpose of that option with the Injected Engineering tune?
Tjrommel is offline
Old 05-22-2013, 08:11 PM   #2
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,257, Level 67
Points: 10,257, Level: 67 Points: 10,257, Level: 67 Points: 10,257, Level: 67
Level Up 52% Completed
Forum Activity 36%
Activity: 36% Activity: 36% Activity: 36%
FF Reputation: 26 suss6052 Great Standing Member
the elevated idle is developed to allow you to run some sort of cleaner through the intake without having a second person to monitor the throttle/ actuate it.
suss6052 is online now
Old 05-22-2013, 08:13 PM   #3
Tjrommel
Tjrommel's Avatar
Fan#: 114674
Ohhhhhhhh I forgot all about the magical substance called seafoam. I'm assuming that'll be the only way to clean the valves
Tjrommel is offline
Old 05-22-2013, 08:29 PM   #4
FocusTi
FocusTi's Avatar
Fan#: 102567
What I Drive: Black 2012 Ford Focus Titanium
FF Reputation: 1 FocusTi Good Standing Member
I am not sure if it is sea foam that injected is using but it is probably something close.
Current Mods: Snorkel Delete with ITG Filter and newmission intake, Rear Sway-Bar, Magnaflow Exhaust, RMM and Hitch
Future Mods: Coilovers, End-Links, Tune, and Brakes
FocusTi is offline
Old 05-22-2013, 09:20 PM   #5
Aric@Injected
FF Affiliate
Aric@Injected's Avatar
Fan#: 113187
What I Drive: '13 Sonic Blue test pig
Points 12,833, Level 73
Points: 12,833, Level: 73 Points: 12,833, Level: 73 Points: 12,833, Level: 73
Level Up 96% Completed
FF Reputation: 10 Aric@Injected Great Standing Member
No its not seafoam. Ill see if I can get some pictures posted up tomorrow.
Injected Engineering, LLC
3605 Kennesaw North Ind Pkwy
Kennesaw, Ga 30144
678-449-6871 Office
678-581-6200 Fax
Want the best tuning available for your MK3 2.0L GDI Focus? Order here http://injectedstore.com/
Coming soon Injected ST Tuning!
Last edited by Aric@Injected; 05-22-2013 at 09:21 PM. Reason: smart phone + stupid fat fingers........
Aric@Injected is offline
Old 05-24-2013, 04:01 PM   #6
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
It will be interesting to see how dirty the valves actually get. On my MS6, they got dirty FAST. Was in part because compression/leak down wasn't great (most likely the fuel injector seals, AGAIN :S) but this is also mainly made worse by returned exhaust gasses (EGR). Since our car has dual variable intake and exhaust cams, I believe that is how they have eliminated the need for one.
The only way to tell is for someone who has kept the stock intake and has a couple miles on the engine. Take intake manifold off (easy) and take pictures. The reason I ended up going with this Ford engine was that it had the least amount of items to dirty up the valves for a DI engine.
For as long as I own this car, I'll be keeping the stock airbox and filter but change openings. Having proper airflow back to the valve cover from tube just before the throttle body is paramount.
Best thing to do once in a while? Good gas and do a few WOT runs, letting the car cool a little between runs.
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 05-24-2013, 05:33 PM   #7
Aric@Injected
FF Affiliate
Fan#: 113187
Kennesaw, Ga 30144
678-449-6871 Office
678-581-6200 Fax
Old 05-24-2013, 08:58 PM   #8
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What's the volatility of those? Will they go in through the vacuum block like seafoam?
Tjrommel is offline
Old 05-24-2013, 09:43 PM   #9
Aric@Injected
FF Affiliate
Fan#: 113187
Yes it will.
Kennesaw, Ga 30144
678-449-6871 Office
678-581-6200 Fax
Old 05-24-2013, 10:07 PM   #10
havok6927
Fan#: 113248
What I Drive: 2012 Focus se hatchback 5spd black
FF Reputation: 1 havok6927 Good Standing Member
They tested the cleaner on my car and it definitely helped. I have almost 50k on my car that I got may 2011. After the clean the car blew blue smoke till at least 5 WOT's.
havok6927 is offline
