Wired FM Modulator - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-21-2013, 12:03 PM   #1
dardack
Fan#: 114151
What I Drive: 2003 Red SE Wagon PZEV 2.3L engine
Points 656, Level 13
Points: 656, Level: 13 Points: 656, Level: 13 Points: 656, Level: 13
Level Up 12% Completed
FF Reputation: 3 dardack Good Standing Member
Wired FM Modulator
As I've decided the $90 is too much than I want to spend for the FRDW_Aux with Blaupunkt cable (see my post http://www.focusfanatics.com/forum/showthread.php?t=316690 trying to see if any other way).
I decided $20 for a FM WIRED Modulator is worth the chance. It's a FMMOD02 Scosche. It comes with a switch.
AFAIK only 2 stations in the US use the 87.9 are in Cali and Wisconsin. Neither affects me. So if I leave this on (I never listen to AM) will it affect other FM stations? So can I just bypass the switch? If you look in previous thread I've posted my prep work on receiving this. I found a pin on the back of the radio that gives 12v when radio is powered, no other time, even if key is on it doesn't. So was going to wire it to that so it powers when the radio is on.
But if this interfere's with other FM stations, may not be an option.
Thanks for any information.
dardack is offline
Old 05-21-2013, 12:22 PM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,726, Level 76
Points: 13,726, Level: 76 Points: 13,726, Level: 76 Points: 13,726, Level: 76
Level Up 19% Completed
Forum Activity 13%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
Any FM modulator will have interference at times. thats why you have several station options to chose from. And I have yet to hear an FM Modulator that sounds decent..
Honestly you best option is to replace your stock HU with aftermarket. Even the cheap Dual headunits will sound better, look better, and offer you an aux port. If your going through all the trouble to wire up a FM modulator, drill holes and mount the thing. You could have gone aftermarket and got an all around cleaner better looking, and Much better sounding system.
You can buy a lightning audio HU on crutchfield for $59.99 and $15 for the install gear it has an aux jack and 2 usb ports all for $75! But buy a HU over $119.99 and the install gear is free! Check it out
SkyPilot is offline
Old 05-21-2013, 01:42 PM   #3
dardack
Fan#: 114151
If i'm going to spend $75 for lighting audio HU i'd just stick with my current HU and get the direct Aux over CDC for $90.
Wanted to do something cheap. I understand it's not the best sounding. I'm not an audiophile and reviews vary on how much hum there is.
There are only 2 channels it comes with 87.9 and 88.3, 88.3 is my local college's thing. But i'm pretty sure 87.9 is not allowed by use by the FCC except for thsoe 2 channels that are like grandfathered in, 1 in cali and 1 in wisconsin.
And my question isn't about interference on the channel it broadcasts over, but on other FM channels while it's turned on.
dardack is offline
Old 05-21-2013, 04:56 PM   #4
dardack
Fan#: 114151
Oh and I'm not drilling holes. The blaupunkt has room under it. They put this spacer thing behind the front. So I have those E-Zpass mounting things. I'll just use them. No holes, no mess.
dardack is offline
