looking for always on fuse in passenger compartment - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 05-21-2013, 09:58 AM   #1
garyd9
Fan#: 114024
What I Drive: '13 Dark Gray Focus Titanium Hatch
FF Reputation: 1 garyd9 Good Standing Member
I'm trying identify an "always on" fuse in the passenger compartment fuse box (that I can piggy back on.) This is being used for the "homelink" function of a autodimming mirror. (I'm using #85 for the switched power.)
I'm currently using #81 (radio frequency receiver), but I'm wondering which specific car function that fuse is associated with... it might be the keyless entry/start RF receiver, or it might be the TPMS RF receiver, or both. I'm having odd issues with TPMS warnings, so I want to eliminate this variable in trying to diagnose.
Because several circuits stay live for a limited time after the car is turned off (as well as the fact that I don't practice yoga), I'm having a hard time identifying an always-on fuse that would be good to use. For this very low wattage device, I'd prefer not to run directly to the battery.
edit: ANSWER: fuse #65, 10A, Luggage compartment release. See post #7 below for more information.
Thanks
Gary
Last edited by garyd9; 05-21-2013 at 08:36 PM. Reason: added an answer for those searching
garyd9 is offline
Old 05-21-2013, 12:39 PM   #2
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
Try looking for the lighted vanity mirror fuse. That's where they draw power from for the homelink on the 12's and it's powered all the time
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 05-21-2013, 01:36 PM   #3
garyd9
Fan#: 114024
No luck so far finding that fuse. I've also checked both the 2013 and 2012 focus owners manuals - and neither of them reference the fuse used for homelink or the vanity mirror lights. :(
garyd9 is offline
Old 05-21-2013, 01:53 PM   #4
I Bleed Ford Blue
Fan#: 94113
Then just tap into the power lead under the headliner that feeds the mirror.
Or get a visor with the homelink built in out of a 12 Ti and swap it in. It is literally plug n play. Several members have already done it. BTW it lists for less than 100 bucks new.
L-CCC #18/HOIA #37
Old 05-21-2013, 02:24 PM   #5
garyd9
Fan#: 114024
I appreciate the suggestions - but I already have the aftermarket auto-dimming mirror w/ homelink mounted and the wires already run to the fuse panel. It's just a matter of finding a better constant power fuse to tap instead of the one I'm using.
Instead of taking random guesses as to which circuits fuse constant power (as opposed to ACC or delayed ACC power) I was hoping that someone with more experience (and knowledge) with this vehicle's electrical would save me the trial and error it would require for me to figure it out. (As well, each wrong guess involves physical pain for me as I try to reach the panel hidden behind the glove box.)
I appreciate your suggestion to use the same fuse as the vanity mirror lights, and I'm sure that would work - if I could only figure out which fuse that is.
garyd9 is offline
Old 05-21-2013, 02:48 PM   #6
I Bleed Ford Blue
Fan#: 94113
I know how you feel, I'm not a small person either, and my knees keep reminding me how old I really am.
L-CCC #18/HOIA #37
Old 05-21-2013, 08:35 PM   #7
garyd9
Fan#: 114024
Found a decent answer: fuse #65, 10A, Luggage compartment release. This appears to always be on, and maxes at 10A (so it doesn't overload the add-a-fuse.)
I also tried #60 (10A, interior light, door switch pack, etc, etc) hoping it would always be on (on the theory that it's always possible to manually turn the dome lights on), but I couldn't fit the add-a-fuse in there because there's ZERO space to the left of the fuse (and the add-a-fuse I have needs a tiny bit of space.)
garyd9 is offline
Old 06-26-2013, 04:00 AM   #8
TheHumbleGeek
TheHumbleGeek's Avatar
Fan#: 105071
What I Drive: 2012 Tuxedo Black SE
Points 2,636, Level 31
Points: 2,636, Level: 31 Points: 2,636, Level: 31 Points: 2,636, Level: 31
Level Up 24% Completed
Forum Activity 72%
Activity: 72% Activity: 72% Activity: 72%
FF Reputation: 1 TheHumbleGeek Good Standing Member
Question, is circuit 85 ignition hot or is it retained power hot? Im looking for a fuse thats ONLY live when the ignition is on, and no time else (no retained power)
Sent from SGH-I747M Via FF Mobile, Care of CSIS ;-)
Moderator for Sedan Revolution
My Cars:
2012 Tuxedo Black Ford Focus SE | Sedan Revolution #283 | Sonic's MK3 Crew #29
1984 Copper Metallic Ford Mustang LX
TheHumbleGeek is online now
Old 09-07-2013, 09:16 PM   #9
Lite12
Lite12's Avatar
Fan#: 118069
What I Drive: 2013 Race Red Focus SE 5dr
Points 118, Level 2
Points: 118, Level: 2 Points: 118, Level: 2 Points: 118, Level: 2
Level Up 36% Completed
FF Reputation: 1 Lite12 Good Standing Member
I too need a fuse that's tied to the ignition switch, to hard wire my radar detector.
The retained power is making it a difficult task.
Thanx in advance.
Lite12 is offline
Old 09-07-2013, 10:04 PM   #10
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 953, Level 16
Points: 953, Level: 16 Points: 953, Level: 16 Points: 953, Level: 16
Level Up 53% Completed
FF Reputation: 5 dbenney Good Standing Member
Thanx in advance.
sorry i cant help the OP... but here is a link for you guys looking for ignition switched power.... look at post #13. it shows the passenger fuse block and the locatino of the switched fuse.
http://www.focusfanatics.com/forum/s...=276935&page=2
dbenney is offline
