2.5 head question/observation - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 06-12-2013, 11:36 PM   #31
xr4ti
Fan#: 115267
What I Drive: 1989 White XR4Ti
FF Reputation: 1 xr4ti Good Standing Member
Thanx much.. Looking forward to hearing what the difference is.. Also, would you know if the Focus 2.3 head has the same specs as the 2006 and later Ford Ranger with the 2.3 Duratec.. I'm planning to use the same setup N/A in a RWD configuration and would prefer to use the Ranger top end as it would already be have the necessary plumbing and accessories.. I'll be changing the cams to either Crane or Crower stage 1 units along with the associated VS kit as the car will be running ITBs and an MSNS3 for management..
xr4ti is offline
Old 06-12-2013, 11:39 PM   #32
xr4ti
Fan#: 115267
And by the way that motor sure does sound sweet.. What weight flywheel are you using?
xr4ti is offline
Old 06-13-2013, 08:05 AM   #33
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,967, Level 74
Points: 12,967, Level: 74 Points: 12,967, Level: 74 Points: 12,967, Level: 74
Level Up 30% Completed
Forum Activity 3%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by MainiaxMotorsports View Post
Ps. Sporadic - did we find the specs on the 2 vs 2.3L head intake ports? I have been on the road and have not measured yet. If you find the answer first just PM me and i iwll get the other head shipped out stat!
I can't find specs online, so I'll need to get someone with a 2.3 head to measure their intake ports. I can't interpret the castings. I'm not sure what LO 05 means on the end of the head, even though that usually represents the displacement. If you can measure the other head you have when you get back to your garage I'd appreciate it.
2006 sonic blue zx5 GT2871r turbo.
sporadic is offline
Old 06-13-2013, 03:06 PM   #34
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
What is the size of the exhaust ur using? I really think u will do more than 180 to the crank I would say easy 180 to te wheels
Hey Bud - yeah - i am running the 2.5L bottom with a 2.3L head - 2.3Cams, oil pickup, etc.
Not dyno'd yet but with the Coswroth style IM - port polished head, and smoothed out TB i suspect she will do 180hp at the crank on race gas. Compression calculates at 11:1 or so - hence will only be running race gas to try to eliminate detonation.
Axles go back on this weekend - will post some road test / BUTT DYNO vids
sounds amazing to be honest
ps. NOT first start - ran it before i got the camera on
http://www.youtube.com/watch?v=vK3Wq7Y9Nuw
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 06-13-2013, 03:10 PM   #35
koke'sfocus
Fan#: 69779
I was gonna ask u what r u gonna do with the pistons the bore in the block is 89mm and ur pistons 87.5 r u gonna sleeve the engine? I want to know cause this is what Im planning to do next year :)
Originally Posted by sporadic View Post
I'll be using 2.0 cams in the 2.5 head. (I still think I have two 2.0 heads on my bench, so I'm not sure I even have a 2.3 head. MainiaxMotorsports are you sure that was a 2.3? All measurements are the same as a 2.0)
Since the 2.5 combustion chamber is the same size as a 2.0 head, I see no reason why the compression ratio would be altered. As long as the cylinder bores are good I'll be using P4-DU875-N2 Supertech 10.4:1 pistons. I actually have two sets of these at the moment after being duped by another member into thinking I was buying 88mm Supertechs. That's another story.
The 2.0 block I'm using is from my original motor that blew a ring landing. Amazingly there is no apparent damage to the cylinder walls or valves. All the loose aluminum bits were in the oil pickup tube, and probably the oil filter.
As far as progress, I'm still gathering last-minute parts. I'm focusing on house remodeling at the moment and will come back to this soon.
team duratec #94
D23 crew #9.
Old 06-13-2013, 03:16 PM   #36
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
I think you're getting these threads crossed. I'm using a 2.0 block, not a 2.5. That would be MainiaxMotorsports.
sporadic is offline
Old 06-13-2013, 06:39 PM   #37
koke'sfocus
Fan#: 69779
I yeah I forgot lol, I would Like to build the 2.5 but there is no pistons or rods :( but maybe I could do the 2.3 block and 2.5 head I will do more research
team duratec #94
D23 crew #9.
Old 02-20-2014, 04:00 PM   #38
Hughesy27
Hughesy27's Avatar
Fan#: 84331
What I Drive: 2010 blue se
Points 1,801, Level 25
Points: 1,801, Level: 25 Points: 1,801, Level: 25 Points: 1,801, Level: 25
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 2%
FF Reputation: 1 Hughesy27 Good Standing Member
I know it's an old thread but any updates? I just got a 2.5 head in and am building a 2.0 block.
Hughesy27 is online now
Old 02-20-2014, 04:36 PM   #39
Black05
Fan#: 123169
What I Drive: 2005 Black St
Points 346, Level 6
Points: 346, Level: 6 Points: 346, Level: 6 Points: 346, Level: 6
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 3%
FF Reputation: 1 Black05 Good Standing Member
Your messurements of the 2.3 ports are right. If u flip the head upside down there is a stamping that says 2.3 on the exhaust side of cylinder 2 just below the port looking up at the bottom of the head
Black05 is online now
Old 02-21-2014, 09:12 AM   #40
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
Sorry 2013 ended up being a house project year. I'm hoping to get to this in late spring, after I renovate the bathroom.
Since I started working from home I don't have much enthusiasm for modifying a car I never drive. I think I put maybe 100 miles on it in 3 months.
sporadic is offline
