2.5 head question/observation - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 06-05-2013, 02:24 PM   #21
MainiaxMotorsports
Fan#: 84528
What I Drive: 2002 Rally-Spec SVT w/ 2.5L swap
Points 1,049, Level 17
Points: 1,049, Level: 17 Points: 1,049, Level: 17 Points: 1,049, Level: 17
Level Up 49% Completed
FF Reputation: 2 MainiaxMotorsports Good Standing Member
i did some compression calculations using my 2.5L block with 2.3L head - not sure it is perfect
looks like we should do 11:1 - however will be at the sake of that larger intake port bank - dang those are big ports....
next project is 2.5L head with 2.3L cams - Sporadic might have it done already??
MainiaxMotorsports is offline
Old 06-05-2013, 02:48 PM   #22
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,621, Level 73
Points: 12,621, Level: 73 Points: 12,621, Level: 73 Points: 12,621, Level: 73
Level Up 43% Completed
Forum Activity 2%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I'll be using 2.0 cams in the 2.5 head. (I still think I have two 2.0 heads on my bench, so I'm not sure I even have a 2.3 head. MainiaxMotorsports are you sure that was a 2.3? All measurements are the same as a 2.0)
Since the 2.5 combustion chamber is the same size as a 2.0 head, I see no reason why the compression ratio would be altered. As long as the cylinder bores are good I'll be using P4-DU875-N2 Supertech 10.4:1 pistons. I actually have two sets of these at the moment after being duped by another member into thinking I was buying 88mm Supertechs. That's another story.
The 2.0 block I'm using is from my original motor that blew a ring landing. Amazingly there is no apparent damage to the cylinder walls or valves. All the loose aluminum bits were in the oil pickup tube, and probably the oil filter.
As far as progress, I'm still gathering last-minute parts. I'm focusing on house remodeling at the moment and will come back to this soon.
2006 sonic blue zx5 GT2871r turbo.
sporadic is offline
Old 06-05-2013, 03:24 PM   #23
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,271, Level 100
Points: 51,271, Level: 100 Points: 51,271, Level: 100 Points: 51,271, Level: 100
Level Up 0% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Buy-Sell-Trade Rating: (28)
MM go no smaller then the 2.3 cams , In my opinion I would do a set of stg 3 cams for what your doing
Your not going to get much from the 2.5 head doing small 2.0 or 2.3 cams , you need the extra flow to keep the velocity up or the larger head is worthless if you only going to flow the amount of a stock 2.3 cams capability
Just my opinion
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-05-2013, 04:14 PM   #24
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Du have 2 sets? 88mm?
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 06-05-2013, 04:16 PM   #25
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 2%
I have 2 sets of 87.5mm, 10.5:1 CR on a 2.0, 11.6:1 on a 2.3. See chart HERE
sporadic is offline
Old 06-05-2013, 08:18 PM   #26
koke'sfocus
Fan#: 69779
That's to high for fi :( lol daaammm
team duratec #94
D23 crew #9.
Old 06-12-2013, 08:43 PM   #27
xr4ti
Fan#: 115267
What I Drive: 1989 White XR4Ti
FF Reputation: 1 xr4ti Good Standing Member
May I ask if anyone of you guys have tried running a 2.5 Duratec bottom end with the 2.3 Duratec head and cams, and what was the results like as far as dyno'd power and reliability.. Also any problem with the blocked oil feed in the block?
xr4ti is offline
Old 06-12-2013, 10:59 PM   #28
MainiaxMotorsports
Fan#: 84528
Hey Bud - yeah - i am running the 2.5L bottom with a 2.3L head - 2.3Cams, oil pickup, etc.
Not dyno'd yet but with the Coswroth style IM - port polished head, and smoothed out TB i suspect she will do 180hp at the crank on race gas. Compression calculates at 11:1 or so - hence will only be running race gas to try to eliminate detonation.
Axles go back on this weekend - will post some road test / BUTT DYNO vids
sounds amazing to be honest
ps. NOT first start - ran it before i got the camera on
http://www.youtube.com/watch?v=vK3Wq7Y9Nuw
Old 06-12-2013, 10:59 PM   #29
MainiaxMotorsports
Fan#: 84528
2.5L w/ 2.3L stock head/valves/cams
YouTube Video
Old 06-12-2013, 11:00 PM   #30
MainiaxMotorsports
Fan#: 84528
Ps. Sporadic - did we find the specs on the 2 vs 2.3L head intake ports? I have been on the road and have not measured yet. If you find the answer first just PM me and i iwll get the other head shipped out stat!
