2.5 head question/observation - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 05-22-2013, 11:15 AM   #11
MainiaxMotorsports
Fan#: 84528
What I Drive: 2002 Rally-Spec SVT w/ 2.5L swap
Points 1,049, Level 17
Points: 1,049, Level: 17 Points: 1,049, Level: 17 Points: 1,049, Level: 17
Level Up 49% Completed
FF Reputation: 2 MainiaxMotorsports Good Standing Member
Hey gang - what i used to do valve spring removal / install was the socket method....super simple to take them out -= PITA to put them back
LINK: http://www.youtube.com/watch?v=aZTnODXfDvA
Also - i think we dont need to worry about that extra oil port that feeds the VCT in a 2.5L block/head
when i thnk about combustion pressure of the cylinder vs any type of oil pressure - if you have the proper torques, i think you are good to go.
MainiaxMotorsports is offline
Old 05-22-2013, 11:20 AM   #12
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,862, Level 74
Points: 12,862, Level: 74 Points: 12,862, Level: 74 Points: 12,862, Level: 74
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 4%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Entertaining, but I don't think I'll be using that method. I'd also not show my rotted-out roof if I posted a video on youtube.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 05-22-2013, 11:26 AM   #13
MainiaxMotorsports
Fan#: 84528
LOL - the tool will make your life sooo much easier - that method took 2 minutes to remove valves - 2 hours to put htem back :!!!
btw - did we figure out Intake/Valve Exhaust/Valve diameter?
will 2.3L valves seat in a 2.5L head - because then perhaps we can use 2.3L Cams
Old 05-27-2013, 08:55 AM   #14
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
I completely stripped the 2.5 and my 2.0 head last night. I highly recommend the OTC 4572 Large Valve Spring Compressor, it made the valve removal a piece of cake, and the way it locks will make the assembly easy too.
The valves measure exactly the same for the 2.0 and the 2.5. (rounded to the nearest tenth)
Exhaust: 30mm x 104.7mm
Intake: 35mm x 103.4mm
There are two more differences I found between the heads: the head temperature sensor and the spark plugs. After much cross-referencing I believe the Mazdaspeed 3 plugs will work. One step colder than stock plugs for the MS3 are the Denso (5340) ITV22 Iridium, which are very well reviewed by the MS3 guys.
6M8G-12405-BB (2.5 Escape) vs Autolite 103 (from my 2.0)
Autolite 103 comes up short in the 2.5 head: (yes it's filthy. It's a salvage head and I haven't cleaned it up yet)
The 2.5 has a shorter temperature sensor. I'm honestly not sure why. The depth of the hole in the 2.5 is the same as the 2.0, and the 2.0 sensor fits fine in the 2.5 head.
Old 05-29-2013, 07:43 AM   #15
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
My updated plan at the moment is:
1) Drill a new oil feed down into the first intake cam area
2) Tap the existing 2.5 feed port and block it off to keep oil from draining to nowhere (against the head gasket and just sit there)
3) Use Crower valve springs 68195-16
4) Use Crower steel retainers (instead of titanium) 87085S-16
5) Use stock 2.0/2.3 cams, valves and valve cover
6) Denso Iridium (5342) ITV27 plugs (3.5 steps colder than stock Mazdaspeed 3, which runs lower compression than this motor)
When I get all my pieces together I'll start a new turbo build thread with all details.
If you want photos of anything let me know now, before it all goes together.
Old 05-31-2013, 12:06 PM   #16
xr4ti
Fan#: 115267
What I Drive: 1989 White XR4Ti
FF Reputation: 1 xr4ti Good Standing Member
Hi Sporadic, i'd like to know how far along you are with this swap.. Are you just attempting to swap the 2.5 head to the 2.3 block to take advantage of the larger inlet ports or are you swapping the complete 2.5 engine into your car?..
xr4ti is offline
Old 05-31-2013, 12:19 PM   #17
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
I'll be putting the 2.5 head on a built 2.0 block. I got as far as I needed at the moment with measurements and analysis. I see nothing preventing me from moving forward, I just don't want to buy everything at one time when I have no particular deadline to meet. I'll finish up the short block in the next couple weeks and then come back to the 2.5 head. If I get ambitious I'll go ahead and order the valve springs and assemble the head sooner.
The end result should be something like this:
- 2.0 block
- supertech 10.4:1 pistons, forged H-beam rods, clevite H bearings, ARP main/head studs
- GT2871r turbo
- custom log manifold
- custom 3" exhaust
- 2.5 head with stock cams and crower springs/retainers
- 60lb injectors, stock fuel pump (going to try and stay within the limits of the stock fuel pump. It will give me something to do next year...)
- Cosworth flywheel, SPEC stage 4 clutch, Torsen LSD
I'll update this thread and likely start a new one as I move forward. I'm also doing home renovations and it's running season (5/10K's) so that takes up time also.
Old 06-01-2013, 11:23 AM   #18
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
Great thread and awesome info! I'm excited to see how this turns out!!!!
Is the bolt pattern the same for the intake manifold? i.e. would the Cossie IM bolt up to the 2.5 head?
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 06-02-2013, 01:05 PM   #19
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
Yes the bolt pattern is the same, and while the Cossie IM port/flange area is larger, I can't measure it while on my car. Chances are good the stock D-shaped gaskets will not fit and a custom gasket will have to be made.
I also confirmed the 2.0 injectors and fuel rail fit the 2.5 head. The injectors protrude just a bit further (maybe a couple mm) into the intake ports than the 2.0.
Old 06-05-2013, 02:17 PM   #20
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Fantastic I want to do the same but with my 2.3 block, r u gonna use ur 2.0 cams? Or the 2.5? U think because of te 2.5 head is gonna be a higher compression?
- 2.0 block
- GT2871r turbo
- custom 3" exhaust
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
