auto trans fluid change - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-05-2004, 02:14 PM   #1
robr
Fan#: 16327
FF Reputation: 1 robr Good Standing Member
i need to change my auto trans fluid and i need to know a few things...where is the drain plug for the transmision??and how do i fill it up?i got everything to do it just wanna know where to look so i can get the job done quick without having to freeze my arse to much out in the driveway searching....even a pic of the underside of a focus would be good....incase it matters my car is a 01 ZTS sedan i think those have the dohc engine...anyone please help..
robr is offline
Old 12-05-2004, 03:12 PM   #2
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
1. Raise and support the vehicle.
2. WARNING: When releasing the transaxle cooling system fluid pressure, cover the fluid hose with a thick cloth to prevent the possibility of scalding. Failure to follow this instruction may result in personal injury. CAUTION: Whenever the fluid cooler hoses are disconnected from the fluid cooler, the outlet and inlet ports must be plugged to prevent the ingress of foreign material. Disconnect the return hose from the transmission fluid cooler.
o Allow the fluid to drain into a suitable container.
3. Attach a length of suitable drain hose to the transmission fluid cooler return hose.
4. Lower the vehicle.
5. Insert the drain hose into a calibrated 10 liter (10.5 quarts) container.
6. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. NOTE: If the fluid return rate is less than 0.95 liters (1.0 quart) in 30 seconds , or if the return hose pulsates, check for restrictions at the pump, cooler or cooler lines. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
7. Switch OFF the engine.
8. Remove the fluid level indicator from the fluid level indicator tube.
9. Add 3 liters of automatic transmission fluid to the transaxle.
10. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. NOTE: If the fluid return rate is less than 0.95 liters in 30 seconds , or if the return hose pulsates, check for restrictions at the pump, cooler or cooler lines. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
11. Switch OFF the engine.
12. Add 3 liters (3.17 quarts) of automatic transmission fluid to the transaxle.
13. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
14. Switch OFF the engine.
15. Raise and support the vehicle.
16. Detach the length of suitable drain hose from the transmission fluid return hose.
17. NOTE: Remove the plug from the transmission fluid cooler return port. Connect the return hose to the transmission fluid cooler.
18. Lower the vehicle.
19. Add 3 liters (3.17 quarts) of automatic transmission fluid to the transaxle.
20. Install the fluid level indicator to the fluid level indicator tube.
21. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. Run the engine.
22. Check the automatic transmission fluid level and fill if necessary.
Lil PZEV is offline
Old 12-05-2004, 04:01 PM   #3
DePue
Fan#: 2476
What I Drive: '01 ZX3
FF Reputation: -1 DePue Poor Behavior Needs Improvement
As you can see from the above post, this is no quick and easy oil change. There is no drain plug to open, it's just not that simple. The above post misses one important thing, dropping the pan to be able to change the filter. You don't 'have to' change the filter but why do something half way? and... getting a good look at the contents of the pan gives you great insight into the health of the tranny.
My suggestion: take it to a tranny shop and let them do it. They'll flush the system and change the filter too.
DePue is offline
Old 12-05-2004, 04:22 PM   #4
robr
Fan#: 16327
well i give up i just wanted to change the fluid before the car is sold/trashed what ever comes first ...the car is a 01 no rust underneath but it's to weak to jack up i tried the jack points they bent and buckled my fender out a bit so i tried the frame and it twisted a bit so thats not and option...i honestly don't think there another car in this world built worse/cheaper...
i'm so frusterated with ford.
robr is offline
Old 12-05-2004, 10:32 PM   #5
robr
Fan#: 16327
one more question how do i know which hose is the proper to unhook out of the both of them??
robr is offline
Old 04-27-2005, 08:34 PM   #6
zeteclover
Fan#: 2167
What I Drive: 2000 SE with Zetec
FF Reputation: 1 zeteclover Good Standing Member
The Automatic change regimin
No a tranny shop usually only changes the oil by a purge and refill method. Mine had 150K and still had factory seals on pan.
The filter was disgusting.
No there is not a way in car to drain the TC with the pan off. The method above drains all of the oil and replaces it, but with the pan off it is not doable.
Hpw much is the right amount for the refill if you do not empty the TC?
zeteclover is offline
Old 05-02-2005, 07:35 PM   #7
Adkhunter
Fan#: 22430
What I Drive: 2000 ZX3 and 2005 ZX4
FF Reputation: 1 Adkhunter Good Standing Member
Does my 2005 Duratec 20E have the same transmission?
Adk
2000 ZX3 -Forest green, 99k, drive on dirt all the time- 16 miles of dirt to work daily
2005 ZX4- White, 215 miles, the "becareful" car!!
Adkhunter is offline
Old 05-03-2005, 07:02 AM   #8
vanace
Fan#: 350
What I Drive: 2005 ST
FF Reputation: 1 vanace Good Standing Member
then do the flush.. that is the best. Then drop the pan and change the filter. That is manditory.
ST crew #18
vanace is offline
Old 06-06-2005, 06:51 PM   #9
floflooo
floflooo's Avatar
Fan#: 14716
What I Drive: 2000 Green ZX3
FF Reputation: 1 floflooo Good Standing Member
Hi guys!
My Focus has an orange signal lighting on on the dashboard after a few minutes on the highway. The manual says: "Multifunction: automatic transaxle/cooling system blablabla... Have your vehicle serviced blablabla..."
Does it mean I have to change my automatic transmission fluid?
floflooo is offline
Old 06-07-2005, 06:38 AM   #10
vanace
Fan#: 350
______
Then your doing something wrong. If there is no rust you car will jack up with no problems or bending.
ST crew #18
vanace is offline
