Interesting HID question.. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-19-2013, 08:41 PM   #1
WTFbeast
Fan#: 114833
What I Drive: 08 Edge SEL 11 Focus SE 88 Stang GT
FF Reputation: 1 WTFbeast Good Standing Member
Hi all.
I ordered a xentec HID H13 bi-xenon kit for my 2011 Focus. This is the second car i've put bi-xenons on, the first being a 2010 mustang. Everything is all hooked up correctly. But for some reason the hi beams are the only beams that light up, regardless of which wire input configuration I have. Meaning; I got the kit that uses only one side of the headlight input connectors to tell the HIDs what to do, and there are 3 wires from the factory harness, and 3 wires to the hi/low switch. It doesn't matter which configuration I have these wires (believe me, i've tried them all), the only time the bulbs light up is if I have the brights switched on. I can hear the switch 'ticking' when I switch the brights on and off, but nothing will light up when the switch is off.
I'm at a loss.. Any ideas? Is there something i'm missing about these cars? Some shut off sensor or something?
WTFbeast is offline
Old 05-19-2013, 09:16 PM   #2
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,239, Level 19
Points: 1,239, Level: 19 Points: 1,239, Level: 19 Points: 1,239, Level: 19
Level Up 39% Completed
Forum Activity 4%
FF Reputation: 1 popwarhomie Good Standing Member
Xentec.... Thats the problem. You get what you pay for.
Im glad they don't work. Your blinding everyone from the glare of your plug and play hids.
Retrofit projectors or keep the stock halogen bulbs.
2010 Focus SE coupe 5 speed
Pioneer 80prs/AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/Projector retrofit/LED tails/ Walled with 2 DC 18"s
94 Lightning
A lot of mods.
popwarhomie is offline
Old 05-20-2013, 01:06 AM   #3
WTFbeast
Fan#: 114833
Lol.. thank you for both the warm welcome and constructive response. Neither of which pertained to my question, but I guess I was asking for it, right? I don't blind anyone. If I can't aim the beam down enough to not blind myself when I test them, I uninstall them. I read the HID sticky before posting, and I was under the assumption my question wouldn't be met with such pointless replies. I'm well aware of the idea that HIDs are frowned upon, thank you. I personally have not experienced a set of HIDs to be annoying while driving, maybe I just have less sensitive eye sight. I don't particularly care if I'm honest, it's not my business what people do and don't do to their cars. I just wanted to ask for help with my electrical problem.
WTFbeast is offline
Old 05-20-2013, 05:53 AM   #4
popwarhomie
Fan#: 94974
Forum Activity 4%
Thats what everyone with plug and play hids say.
Everyone uses the "they don't glare" "i aimed them down"
It doesn't matter what you do they will glare because the headlights are not designed for that bulb.
Im sure it doesnt matter and your still going to keep them but I hope you went with a 4300-5000k bulb and dont have some avatar blue headlights.
Sorry for not welcoming you. I don't check post count before replying to things..
94 Lightning
A lot of mods.
Old 05-20-2013, 12:26 PM   #5
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
got a volt meter handy?
im not sure to which kit you have or how it wires in. there are two types from what ive seen. one uses a solenoid to pull the bulb into position and the other uses a halogen bulb for the high beam.
there needs to be a diode on the ballast wiring to keep the ballast energized when switching to highbeam due to the ignition and warm up period of the xenon. hopefully they have built this in or you will need to pick up a h13 relay harness...
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
