zetec bottom end help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-18-2013, 12:10 AM   #1
focused0713
Fan#: 105658
What I Drive: 2001 yellow zx3
FF Reputation: 1 focused0713 Good Standing Member
I have a 2001 zx3 zetec and im upgrading the internals gettin ready for boost. I have a massive head and cometic head gasket but i need to do somethin with the bottom end. Looking for options and also never installed bottom end components before so im wondering if any machine work has to be done to the block when i switch pistons. What is the best compression for boost?? Thanks guys for ur help
focused0713 is offline
Old 05-18-2013, 11:12 AM   #2
sdaddy
sdaddy's Avatar
Fan#: 105173
What I Drive: Green 2002 Birkin w/2L Zetec
FF Reputation: 1 sdaddy Good Standing Member
There are a few threads that talk about zetec bottom ends. One, Stroker Kit Co-Op" is one that I'm watching
One post from Tom outlines the costs of a quality rebuild.... about $1,800. I believe Tom might sell quality rebuilt short blocks as well for not much more than this.
Weight: 1200 lbs ...and planning to add more lightness.
sdaddy is offline
Old 05-18-2013, 10:25 PM   #3
JFrye
JFrye's Avatar
Fan#: 54896
What I Drive: 2000 ZX3, 99 Dodge 3500 w/Cummins
Points 1,684, Level 23
Points: 1,684, Level: 23 Points: 1,684, Level: 23 Points: 1,684, Level: 23
Level Up 84% Completed
Forum Activity 30%
FF Reputation: 3 JFrye Good Standing Member
Buy-Sell-Trade Rating: (6)
Not to hijack a thread, but how much will the Zetec block hold, power wise? I was always under the impression that for the high end numbers, you would need to look into a CGI block.
00 Silver ZX3. Zetec, ATX w/3.90 gears. 14" orange steelies. Eibach Sportlines, Massive Strut Bar, BBK 65mm TB, 4 to 1 Header followed by 2.5" into 3" exhaust.
Hatch Nation #31
JFrye is offline
Old 05-20-2013, 12:54 AM   #4
amc49
Fan#: 96610
Points 3,277, Level 35
Points: 3,277, Level: 35 Points: 3,277, Level: 35 Points: 3,277, Level: 35
Level Up 52% Completed
Forum Activity 12%
You pretty much MUST at least bore the block for new oversize pistons. Using standard size new pistons on a standard bore worn block is a mistake when looking for more performance.
No one answer to the compression question, the compression is based on what boost you will be running, the two are locked together. Less boost=more needed compression.
amc49 is offline
Old 05-20-2013, 08:57 PM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,413, Level 61
Points: 8,413, Level: 61 Points: 8,413, Level: 61 Points: 8,413, Level: 61
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
a built block in good condition with factory mains will take you to about 400-450 WHP to my understanding. if you want more then you need billet mains and can take you to 500+. a CGI block is more insurance. i belive there are many "stock" blocks doing 350+ HP on regular mains.
You do need good balancing, good bearings, H or I beam rods, and a good piston.
There are only a few options for pistons on the Zetec I would say go slightly lower compression. if you need to lower it further you can go with a different or if you want to rise it you can go with a slightly thinner head gasket. also you can raise the compression back up by decking the head. Dont worry to much about the compression, if your going FI then I would just go lower. dont think you can go to low and run into problems on the zetec unless you do some serious modifications.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 05-20-2013, 09:46 PM   #6
JFrye
JFrye's Avatar
Fan#: 54896
Forum Activity 30%
Thanks for the information. I found it helpful, and hopefully other people will too.
Hatch Nation #31
JFrye is offline
Old 05-20-2013, 09:59 PM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
another great thing to do is to view all the build threads out there and read through most of it and for those that are finished most people go to the dyno for tuning of the cams so can show you the numbers they are pushing.
Hatch Nation #42
Old 05-21-2013, 03:18 PM   #8
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
remember the lower the compression the better for boost. I am running stock head with oem head gasket and je pistons and eagle rods with clevite bearings.
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
