Compression Ratio Help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-17-2013, 10:15 PM   #1
MainiaxMotorsports
Fan#: 84528
What I Drive: 2002 Rally-Spec SVT w/ 2.5L swap
Points 1,049, Level 17
Points: 1,049, Level: 17 Points: 1,049, Level: 17 Points: 1,049, Level: 17
Level Up 49% Completed
FF Reputation: 2 MainiaxMotorsports Good Standing Member
Hey team - i am the rally racer needs 2.3L / 2.5L swap help. Good news is we are almost built and the motor should go back in the buddy on Sunday / Monday. I broke a head bolt - yes, reused TTY bolts - paid the price, got new bolts - back to work on her tomorrow - but in my downtime was playing with Combustion Ratio this 2.5L Block/Piston/Crank motor will have with a 2.3L head.
Here is the thread
http://www.focusfanatics.com/forum/s...68#post4729168
Here is my Calculation - where did i mess up>? 11.03:1 seems possible
MainiaxMotorsports is offline
Old 05-17-2013, 10:42 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,459, Level 75
Points: 13,459, Level: 75 Points: 13,459, Level: 75 Points: 13,459, Level: 75
Level Up 53% Completed
Forum Activity 99%
Well, the decimal point is off for the displacement... If you move it over one digit that works out OK. (248 cc sounded a bit small)
That would give about a 56cc calc. chamber volume, sounds about right with the dished piston.
Real "Stroker" of an undersquare motor, with a 100mm stroke and only 89mm for the bore...
What was the volume of the 2.5 head??
Cheers!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 05-17-2013, 11:00 PM   #3
MainiaxMotorsports
Fan#: 84528
The problem at present is i have to use the 2.3L head - not the 2.5L from the donor - on account of the VCT. We are working on an VCT delete solution....but have a few races to run - so, put the 2.3L head on - which i actually think ups the compression - but at the cost of decreased flow - the head on the 2.5 is wide open vs. the 2.3L
Motor build should be done this weekend - so, shall see next week on a few shakedown roads we will take her out on.
Cheers !!
Old 05-17-2013, 11:32 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
I was just wondering if you had a 2.5 chamber volume handy to compare compression ratio's - extra volume there would lower it a bit as you're guessing.
You might be surprised by the flow from the 2.3 head, folks who've tried to improve it from stock haven't found any gains there. Some have tried porting & polishing with no gain on the flow bench or dyno.
Good Luck on the shake down & rallies!
"Rubber Side Down"
sailor is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
