MK1 Rear Wheel Cylinder? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-16-2013, 10:06 AM   #1
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Can someone verify my fluid dynamics 101 is correct?
Foci built before mid 2001 had a different WC then after. The early ones had a smaller bore (20.6mm) than the later (22.24mm).
So, to increase braking pressure in the rear one (me) would want to ensure they have the smaller diameter bore WC's, correct?
(believe I understand hydraulic theory)
iminhell is offline
Old 05-16-2013, 10:38 AM   #2
cpalz
Fan#: 105682
What I Drive: 2002 Zx5 Focus, 2005 Zx4 Focus
FF Reputation: 1 cpalz Good Standing Member
You would want the bigger bore. That would give you a larger surface area (piston) for the fluid to work against. Hydraulic formula is F (force) divided by P (pressure) x A (area). A smaller bore willnot give you more pressure. Pressure is resistance to flow. Both are dead ends, so pressure remains constant. So in your situation, if you have 1000 psi, (not sure if that is really what it is) you would multiply it times the area available for the fluid to work on. Your would need to find the area of the cylinder. Say the wheel cylinder is 2 inches long. converting the cylinder size to inches it would be .811 (20.6mm) inches and .875 inches (22.24mm) x .8754 x 2= 1.41. area of smaller cyl or 1.53 in area of larger cyl. Then multiply by pressure to find your force is 1410 lbs. for smaller cyl or 1530 lbs. for larger cyl.
Sorry for the long windedness, and this is probably much more than your are after, but it helps explain why the bigger one is better for force.
cpalz is offline
Old 05-16-2013, 12:32 PM   #3
YellowJellyBean
Love CA / Hate CARB
YellowJellyBean's Avatar
Fan#: 69030
What I Drive: MÜSTÄRD
FF Reputation: 13 YellowJellyBean Great Standing Member
Viscosity is resistance to flow. Pressure is an omnidirectional force exerted over an area due to the momentum of fluid particles.
He's right, though—same pressure on a larger area means more force.
"My yellow, in this case, is not so mellow" -Jimi Hendrix
Focus Fanatics
Extremely helpful people
I made a haiku
YellowJellyBean is offline
Old 05-16-2013, 08:24 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
Guess I'll return my little ones for the big ones tomorrow.
Thanks guys.
iminhell is offline
Old 05-19-2013, 02:20 AM   #5
amc49
Fan#: 96610
Points 3,376, Level 36
Points: 3,376, Level: 36 Points: 3,376, Level: 36 Points: 3,376, Level: 36
Level Up 18% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
There is no momentum in a closed in system that is pressure maintained, the particles are under pressure but not moving. Pressure in that case would indeed be resistance to flow.
Bigger wheel cylinder has more force since more area to work on with whatever force coming from M/C.
amc49 is online now
