fuel pressure regulator? i think... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-04-2004, 09:50 PM   #1
focalpoint0
Fan#: 15177
What I Drive: 2001 Red ZX3
FF Reputation: 1 focalpoint0 Good Standing Member
help me out? what is the sensor that plugs into the left side of fuel rail. there is a quick realse on the fuel line then it attachs to this sensor. but im cant find what it is called or what part # it is. all the #'s engraved on it dont work on the ford websites. and id also like to know where to buy one, when i find out the exact name and part #. help me out so i can get it back running.
thanx much
focalpoint0 is offline
Old 12-05-2004, 01:32 AM   #2
focalpoint0
Fan#: 15177
nobody knows this. if i had my haynes manuel which is on order id find it. hopefully nobody else needs this part, becuase with all the info im getting people would be screwed.
Old 12-05-2004, 09:06 AM   #3
slammedfoci
slammedfoci's Avatar
Fan#: 2137
What I Drive: 2000 Bright Amber Metallic ZX3
FF Reputation: 1 slammedfoci Good Standing Member
The fuel pressure regulator plugs into the left side of the fuel rail on a zetec, but it does not have a sensor on it just a vacum hose. Is it An spi or zetec? It could be the Electronic pressure sensor if you have a spi.
PERFORMANCE:Aem cai, Aem air bypass valve, Autolite double platinum plugs,Ford Racing 9mm plug wires, Full magnaflow cat back exhaust, Fc race header, Focus Central Flex Pipe, Fc 65mm throttel body ,Fc strut brace, Prothane lower mount inserts, Prothane front and rear swaybar bushings and rear endlink kit, Fc spark plug cover
EXTERIOR: Aerospeed lowering springs, Sidemarkers, Svt upper grill, 03 Grey Headlights, Flat Black Stock 15s, APC Gen. 2 Mirrors, Euroglow Xenon Headlights
INTERIOR: Fc short shifter, Auto meter duel a-piller guage pod, Auto meter phantom oil pressure and Volt gauges, Ford racing tach w/shift light, SVT alum. pedals, Rear seat removed
slammedfoci is offline
Old 12-05-2004, 09:16 AM   #4
WagonHO
WagonHO's Avatar
Fan#: 14540
What I Drive: 06 Frontier V6; 09 V-Strom 650
FF Reputation: 1 WagonHO Good Standing Member
Why are you so desperate to change out this part - just symptoms or is it visibly fu'd?
Looking for a Focus... selling a Bandit 1250S
WagonHO is offline
Old 12-05-2004, 08:17 PM   #5
focalpoint0
Fan#: 15177
I NEED THE PART BECAUSE IT CRACKED WHERE THE FUEL HOSE CONNECTS INTO IT. THERE IS A SENSOR THAT PLUGS INTO THE BACK OF IT. IM NOT SURE WHAT IT IS CALLED THOUGH. I DIDNT GET A MANUEL WITH MY CAR. I HAVE A 2001 ZX3. I DO NOT THINK IT IS A SPI. BECAUSE THEY DONT HAVE dohc DO THEY?
Old 12-05-2004, 08:27 PM   #6
slammedfoci
Fan#: 2137
You don't have to SHOUT. It would say DOHC Zetec on the valve cover. The SPI is a single cam.
Old 12-05-2004, 09:05 PM   #7
focalpoint0
Fan#: 15177
yeah its a DOHC, there are two cams on the side. i know what i have i just cannot find this pieces' name. look on the metal rail behind your engine. it may be called the fuel injector rail? not sure but after that little coil looking hose with the silver disc, ther is a black plastic sensor which is bolted to the rail. and i wasnt shouting, i forgot i had it in caps because im on the comp at work.
Old 12-05-2004, 09:19 PM   #8
slammedfoci
Fan#: 2137
Thats cool. I looked at it and i can not find it anywere in my hanyes manual. I am shure it has something to do with the pressure. Try asking for a Electronic pressure sensor and see what you come up with. That may be what you need.
Old 12-06-2004, 12:03 AM   #9
focalpoint0
Fan#: 15177
thanx i appreciate the input. when i go into work 2morrow ill ask one of the Ford mechanics what exactly it is, just for my own knowledge. plus so i can order it from a local dealer.
Old 12-06-2004, 07:33 AM   #10
slammedfoci
Fan#: 2137
Let us know what it is when you find out. Please
