scan xl professional script editors - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-14-2013, 05:09 PM   #1
mgs41987
Fan#: 93412
What I Drive: 02 blue 1.6 zetec
FF Reputation: 1 mgs41987 Good Standing Member
turning off a check engine light i noticed script editor, so i chose to import scripts as im going through it im noticing that this version of scan xl i have you can import and edit export the the scripts back to the ecu, so as you can edit them i thought i would have a gander see what values it gives you, i have three scripts from ecu
1 for fuel flow rate showing current ratios,
2 Instantaneous Fuel Economy and
3 boost pressure (air flow)
not being trained or not looked into it much further i thought i would ask you guys as the values can be changed and exported back to ecu to gain a bit more power or economy and these are what the scripts look like
SCRIPT 1
function GetRequiredPids()
Obdii.AddRequiredPid("SAE.LAMBDA");
Obdii.AddRequiredPid("SAE.MAF");
var AirFuelRatio = 14.64; // For gasoline vehicles
var FuelDensityGramsPerLiter = 720; // For gasoline vehicles
var CommandedEquivalenceRatio = Obdii.GetPidValueEnglish("SAE.LAMBDA");
if (CommandedEquivalenceRatio != null)
AirFuelRatio *= CommandedEquivalenceRatio;
var FuelFlowGramsPerSecond = Obdii.GetPidValueMetric("SAE.MAF") / AirFuelRatio;
var FuelFlowLitersPerSecond = FuelFlowGramsPerSecond / FuelDensityGramsPerLiter;
var FuelFlowGallonsPerSecond = FuelFlowLitersPerSecond * 0.26417;
Obdii.PidValue.English = FuelFlowGallonsPerSecond * 3600; // Convert to gallons per hour
Obdii.PidValue.Metric = FuelFlowLitersPerSecond * 3600; // Convert to liters per hour
SCRIPT 2 (LOOKS THE SAME)
Obdii.AddRequiredPid("SAE.VSS");
var FuelFlowGallonsPerHour = FuelFlowGallonsPerSecond * 3600; // Convert to gallons per hour
var FuelFlowLitersPerHour = FuelFlowLitersPerSecond * 3600; // Convert to liters per hour
if (FuelFlowLitersPerHour == 0 || FuelFlowGallonsPerHour == 0)
Obdii.PidValue.Metric = "N/A";
Obdii.PidValue.English = "N/A";
else
Obdii.PidValue.Metric = Obdii.GetPidValueMetric("SAE.VSS") / FuelFlowLitersPerHour;
Obdii.PidValue.English = Obdii.GetPidValueEnglish("SAE.VSS") / FuelFlowGallonsPerHour;
SCRIPT 3
Obdii.AddRequiredPid("SAE.MAP");
Obdii.AddRequiredPid("SAE.BARO");
// Script for scaling -15 to +20 PSI Boost Gauge
var ManifoldRelativePressurePSI = Obdii.GetPidValueEnglish("SAE.MAP") / 2.04; // inHg to PSI
var BarometricPressurePSI = Obdii.GetPidValueEnglish("SAE.BARO") / 2.04; // inHg to PSI
//var BoostPSI = ManifoldRelativePressurePSI - BarometricPressurePSI - 14.70; // Zero at atmospheric
var BoostPSI = ManifoldRelativePressurePSI - BarometricPressurePSI; // Zero at atmospheric
Obdii.PidValue.English = BoostPSI;
Obdii.PidValue.Metric = BoostPSI / 14.50; // PSI to Bar
mgs41987 is offline
