Pending p0351 - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-14-2013, 11:56 AM   #11
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 945, Level 16
Points: 945, Level: 16 Points: 945, Level: 16 Points: 945, Level: 16
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 3%
FF Reputation: 3 CotyM Good Standing Member
Have you tried rockauto?
http://www.rockauto.com/
+-FORD
+--2003
+---Focus
+----2.3 DOHC
+-----Ignition
+------Ignition coil
They have a few options there... They have motor craft for $82 and "ULTRAPOWER" for $21 as well as a few other in-between... Probably best if you don't want to hassle with ebay and whether or not the ebay one will work...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
Old 05-14-2013, 12:03 PM   #12
dardack
Fan#: 114151
What I Drive: 2003 Red SE Wagon PZEV 2.3L engine
Points 656, Level 13
Points: 656, Level: 13 Points: 656, Level: 13 Points: 656, Level: 13
Level Up 12% Completed
FF Reputation: 3 dardack Good Standing Member
Thanks. I see delphi there and airtex. So I may check ebay for those specifics. I don't mind ebay hassle normally. I've bought tons of parts over the years and not had problems. Even an ignition coil pack for the 00 Focus. And that's still running mad years later.
So I don't know. Just normally you can see brand names on there, with these COP's never heard of them. At least rockauto is selling the delphi/airtex.
Not even sure I need new ones yet. Going to try the cleaning/checking/replacing plugs and go from there. Like I said it's still pending. Not sure how many times it needs to happen to actually throw the code and how many times it needs to NOT happen to clear itself.
Just like to do research a head of time.
dardack is offline
Old 05-14-2013, 12:13 PM   #13
CotyM
CotyM's Avatar
Fan#: 85558
Forum Activity 3%
Yep, Personally I'd clear the code myself and see how long it takes to come back of at all, could have just been a one time deal caused a bit of moisture or something... heck you could have ran over the tooth fairy
Hatch Nation #32
CotyM is offline
Old 05-14-2013, 12:24 PM   #14
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
What I Drive: 2003 Liquid Grey ZX3
Points 2,453, Level 30
Points: 2,453, Level: 30 Points: 2,453, Level: 30 Points: 2,453, Level: 30
Level Up 2% Completed
FF Reputation: 1 03FocusZX3 Good Standing Member
Yah at 87k and 10 years old i would replace the spark plugs and wires and what not lol. The job is easier than easy, lol. I would say it could be the plugs and wires. Just being really optimistic lol.
When I die, I want to go peacefully like my grandfather did, in his sleep, not screaming, like the passengers in his car.
03FocusZX3 is offline
Old 05-14-2013, 12:29 PM   #15
CotyM
CotyM's Avatar
Fan#: 85558
Forum Activity 3%
^ Well he doesn't have plugs, he has the 2.3 dura, so he has 4 independent ignition coils that sit directly on top of the spark plugs... It's really BS if you ask me, because you might gain what, 2 hp? I don't think econoboxes should have high end things like that from factory, but.. whatever... Just a way for them to make more money when something fails
Hatch Nation #32
CotyM is offline
Old 05-14-2013, 03:04 PM   #16
dardack
Fan#: 114151
Yeah supposedly it's also better for the environment or some crap. I agree it's to make more money. 1 coil pack for my 00 cost me $70 i think, new, motorcraft. Motocraft COP for dura is $80+ and you need 4.
Once I replace spark plugs/clean the boots I'll probably reset code. See if it goes into pending in a week or 2.
Anything recommend to clean the boot/COP bottom part that goes over plug?
dardack is offline
Old 05-14-2013, 04:36 PM   #17
dardack
Fan#: 114151
BTW anyone know how much torque I remove by adding anti-seize?
dardack is offline
Old 05-14-2013, 04:52 PM   #18
dardack
Fan#: 114151
Like I said going to clean it replace sparks. If pend code, I'll try replacing boots/springs first. Heard that can be problem over just the electronic part that sits on top.
dardack is offline
Old 05-14-2013, 04:54 PM   #19
CotyM
CotyM's Avatar
Fan#: 85558
Forum Activity 3%
None, it isn't as much of a lubricant as it is an anti-seizing agent, so just torque it down to the same spec you would as if it wasn't there... Just try no to get any on anything but the threads and go easy on it...
EDIT: also, I recommend nickle based anti-seize cs copper since it will have to put up with allot of heat...
Hatch Nation #32
CotyM is offline
Old 05-14-2013, 04:58 PM   #20
dardack
Fan#: 114151
I know about going easy. I have the big container with the brush. But I never used a torque wrench until recently. Trying to do things right now instead of just by feel. Although just by feel has gotten me by for almost 20 years now. But I heard that you may need to remove like 20% when adding anti seize.
Eh. I'll go easy. Thanks again.
BTW called another auto parts store here, they have that Wells C1453, they want $90 per. That ebay listing is for same exact part #. for like $14. Maybe I'll buy 1 and bring it to the store and see if it's the same. If so instead of paying $5 per boot, just pay the $14 per. Keep the electronic part stored incase.
dardack is offline
