Just bolt ons! - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-17-2013, 03:01 AM   #41
2011 FOCUS SE
2011 FOCUS SE's Avatar
Fan#: 108409
What I Drive: 2011 FORD FOCUS SE
FF Reputation: 1 2011 FOCUS SE Good Standing Member
So even if the compression ratio is the same i can change the thickness of the gasket to thicker and lower compression ration i want to lower it not to turbo just to utilize nos.
2011 FOCUS SE is offline
Old 05-17-2013, 03:05 AM   #42
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
You could, but I don't know why you would want to lower the compression ratio for NOS?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 05-17-2013, 03:09 AM   #43
2011 FOCUS SE
Fan#: 108409
Well just want to run nos and not blow my motor
Old 05-17-2013, 03:41 AM   #44
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
Then you need a built bottom end depending on how much you want to use. Also a good tune to go with it.
Moderator for
Technical Chat
Old 05-17-2013, 04:17 AM   #45
2011 FOCUS SE
Fan#: 108409
All i have now is a typhoon intake and straight pipe exhaust. My plan is to order lower mm and then obx header then get the sct programmer then eather stick with my head and get cams or get a 2.3 head and get cams. I am planning to eather way arp stud the head and add nos.. Just need tips on which way is better head wise with using nos instead of turbo.. I only want to put 25 to 50 shot of nos.?.?.?
Old 05-17-2013, 04:44 AM   #46
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
I would skip the NOS and go with the 2.3 head and cams. You'll have more power (not more than a hit of NOS but it will be up there) and have it all the time.
Moderator for
Technical Chat
Old 05-17-2013, 10:42 AM   #47
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,746, Level 76
Points: 13,746, Level: 76 Points: 13,746, Level: 76 Points: 13,746, Level: 76
Level Up 24% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
This^^^^^^^^^^^^^ Its no good to run out of nos, when you need it.
felixthecat is online now
Old 05-17-2013, 11:06 AM   #48
streetfocus
streetfocus's Avatar
Fan#: 5768
What I Drive: 2004 Black Focus SVT
Points 2,551, Level 30
Points: 2,551, Level: 30 Points: 2,551, Level: 30 Points: 2,551, Level: 30
Level Up 68% Completed
FF Reputation: 2 streetfocus Good Standing Member
A 25 or 50 shot is fine for the stock motor. Anything above a 75 shot would warrant a built bottom end. Quick question: why all the hunger for power, but you start with an automatic transmission? There are plenty here in the community with the ATX, but they usually fall more into the "show" category than the "go" category.
05 ZX3: Steeda intake, 67mm TB, custom 2.5 Magnaflow exhaust, Tom's Tune.
New: 04 SVT : K&N panel filter, 3 performance motor mounts, Taylor wires, orp, 67mm TB, Tom's Tune.
streetfocus is offline
Old 05-17-2013, 12:32 PM   #49
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Points 1,688, Level 23
Points: 1,688, Level: 23 Points: 1,688, Level: 23 Points: 1,688, Level: 23
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 3 replica81 Good Standing Member
If your expectations are to get above about 170whp, I'd consider moving on to a different car.
A thinner head gasket will raise the compression, but just barely. There's nothing "bad" about using nitrous on a high compression motor, it will make more power per amount of nitrious used, but it will need to be monitored closer.
SR #272
Beer and Metal.
replica81 is online now
Old 05-17-2013, 08:24 PM   #50
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
A 170whp on a duratec is way easier than trying to get there with a zetec. With a 2.3 head swap and cams it should be close if not there. With a Cossie intake manifold, tb, and intake should put you around 180-190hp.
Moderator for
Technical Chat
