P1237 Fuel Pump Secondary Circuit Malfunction - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 12-04-2004, 01:15 PM   #1
xn85turbo
Fan#: 16269
FF Reputation: 1 xn85turbo Good Standing Member
I got this ODBII error on a 2000 focus. Does anyone know where this is so I can fix it. I called Ford and they said it's wiring not a relay, is this correct?
xn85turbo is offline
Old 12-05-2004, 07:44 AM   #2
slammedfoci
slammedfoci's Avatar
Fan#: 2137
What I Drive: 2000 Bright Amber Metallic ZX3
FF Reputation: 1 slammedfoci Good Standing Member
Yeah, A circuit would be refurring to wires. You may have a wire loose or a ground thats not grounding good. As to were it is, I do not really know. You will have to start looking around the fuel pump and go along those wires looking for cuts or something of that nature.
PERFORMANCE:Aem cai, Aem air bypass valve, Autolite double platinum plugs,Ford Racing 9mm plug wires, Full magnaflow cat back exhaust, Fc race header, Focus Central Flex Pipe, Fc 65mm throttel body ,Fc strut brace, Prothane lower mount inserts, Prothane front and rear swaybar bushings and rear endlink kit, Fc spark plug cover
EXTERIOR: Aerospeed lowering springs, Sidemarkers, Svt upper grill, 03 Grey Headlights, Flat Black Stock 15s, APC Gen. 2 Mirrors, Euroglow Xenon Headlights
INTERIOR: Fc short shifter, Auto meter duel a-piller guage pod, Auto meter phantom oil pressure and Volt gauges, Ford racing tach w/shift light, SVT alum. pedals, Rear seat removed
slammedfoci is offline
Old 12-06-2004, 07:42 AM   #3
soffiler
Registered User
soffiler's Avatar
Fan#: 372
What I Drive: '03 ZX3 PZEV 5-spd Twilight Blue; '97 F-250 4x4 w/ 351 V8 & AT
FF Reputation: 1 soffiler Good Standing Member
Okay, here ya go. This is straight from a web forum for professional technicians called iATN. It is a subscription-only site.
P1237=Fuel Pump Secondary Circuit (Fuel Pump Driver Module)
Electronic Returnless Fuel Systems (ERFS) utilize a Fuel Pump Driver Module (FPDM) to control fuel pressure. The PCM uses a Fuel Rail Pressure Sensor (FRP) for feedback. The PCM outputs a duty cycle to the FPDM to maintain the desired fuel rail pressure. During normal operation, the PCM will output a FP duty cycle from 5% to 51%. The FPDM will run the fuel pump at twice this duty cycle, e.g. if the PCM outputs a 42% duty cycle, the FPDM will run the fuel pump at 84%. If the PCM outputs a 75% duty cycle, the FPDM will turn off the fuel pump.
If the FPDM does not out any diagnostic signal, (0 or 100% duty cycle), the PCM sets a P1233 DTC. This DTC is set if the FPDM loses power. This can also occur if the Inertia Fuel Switch is tripped.
If the FPDM outputs a 25% duty cycle, it means that the fuel pump control duty cycle is out of range. This may occurs if the FPDM does not receive a valid control duty cycle signal from the PCM. The FPDM will default to 100% duty cycle on the fuel pump control output. The PCM sets a P1235 DTC.
If the FPDM outputs a 75% duty cycle, it means that the FPDM has detected an open or short on the fuel pump control circuit. The PCM sets a P1237 DTC.
soffiler is offline
Old 12-06-2004, 07:02 PM   #4
ModemJunki
ModemJunki's Avatar
Fan#: 10639
What I Drive: '02 Red on Black SVTF - tuned by Hypnotic
FF Reputation: 3 ModemJunki Good Standing Member
Props to soffiler for the detailed answer. I'm filing that one away.
Keep the revs up!
ModemJunki is offline
Old 03-21-2006, 09:59 AM   #5
mdillian3690
Fan#: 33404
FF Reputation: 1 mdillian3690 Good Standing Member
P1237
I have this code on my 1999 Mystique 2.5l build date 7/99. I replace the fuel pump and now even with the key in the on position, the pump runs forever. I will state a guy a work, jump the two ground wires at the connector (to the fuel pump) together. Could this be causing the CEL? Thanks!
mdillian3690 is offline
Old 03-21-2006, 05:02 PM   #6
ModemJunki
ModemJunki's Avatar
Fan#: 10639
Wow, old thread!
You'll find a lot more experience with the Contour/Mystique here:
http://www.contour.org/
Sorry I can't be more helpful.
Keep the revs up!
Old 08-10-2014, 05:01 PM   #7
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
FF Reputation: 2 700whpfocus Good Standing Member
Buy-Sell-Trade Rating: (11)
i am having this error code. p1237. wold this also be casing the pump not to turn on
700whpfocus is offline
Old 08-10-2014, 11:02 PM   #8
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 67 sailor Excellent Standing Member
Read the code in this thread & also here:http://www.focusfanatics.com/forum/s...ad.php?t=59286 for more description.
Fuel pump or it's wiring is the fault being reported.
"Rubber Side Down"
S.R. #275
sailor is online now
