2001 Hatch: Loose rear Uncontrollable swaying over bumps - Rear Alignment issues - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2013, 07:45 PM   #11
herenow
Fan#: 105707
What I Drive: 2001 red zx3
Points 315, Level 6
Points: 315, Level: 6 Points: 315, Level: 6 Points: 315, Level: 6
Level Up 30% Completed
FF Reputation: 1 herenow Good Standing Member
Thank you, I'll will check these and respond. I'll try and take pics too.
herenow is offline
Old 05-10-2013, 08:44 PM   #12
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
My bad, I meant shocks of course, I have pretty much moved away from using the word shock and it is obvious. There for a long while I called struts shocks and kept getting corrected then too.
amc49 is offline
Old 05-20-2013, 04:37 PM   #13
herenow
Fan#: 105707
Points 315, Level 6
I replaced the Bushings this weekend. From AutoZone, They seemed to be the the same as the Napa ones. The pricing was the same.
After the repair, the Rear End still swings from "LEFT, then to the RIGHT", when I hit a bump.
It was good i replaced the bushings.. they were completely shot & warn down.
I'm wondering if I should check the left shock.. in case it needs repair.
I replaced the (front) struts like 4 weeks ago.
herenow is offline
Old 05-20-2013, 05:34 PM   #14
herenow
Fan#: 105707
Points 315, Level 6
From the blue sway bar pic, that was posted earlier, I replaced the Rear, bushings, at the ends of the sway bar. They needed replacement, but it didn't resolve the issue. What else do you suggest I attempt to replace?
herenow is offline
Old 05-20-2013, 05:52 PM   #15
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,863, Level 74
Points: 12,863, Level: 74 Points: 12,863, Level: 74 Points: 12,863, Level: 74
Level Up 4% Completed
Forum Activity 99%
Look at the suspension arm bushings (Lower)
If the rubber is shot on any of them, toe of the rear wheels can change at any time, result is like a shopping cart wheel wiggling!
The feeling is looseness, with rear end wandering when going straight. When turning it might turn more or less than desired - maybe even change between the two in one corner.
Fixing Sway links gives better "roll" control, but don't help control where the wheels are pointing...
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 05-22-2013, 12:23 PM   #16
JerryHD1
Fan#: 114941
What I Drive: 2010 Gray outlander
FF Reputation: 1 JerryHD1 Good Standing Member
Smile Similiar Rear Noise Issues
The car in question is a 2007 Focus. When driving on highway, the rear tire on one side seems to bounce. I've replaced both shocks couple of months ago. I did notice that the tires on the rear are cupped on the inside tread of passenger side and outside tread on drivers side. I plan on getting new tires, but I want to make sure nothing else is causing the cupping and bounce. I'm reading where there is no Camber adjustment on stock Focus, read where some said replacing sway bar end bolt and bushing helped with noise. Just not sure where to go from here. Berring assembly was also changed on the rear.
JerryHD1
JerryHD1 is offline
Old 05-22-2013, 12:40 PM   #17
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,630, Level 23
Points: 1,630, Level: 23 Points: 1,630, Level: 23 Points: 1,630, Level: 23
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
There is camber adjustment but it is very, very small. The camber is adjusted with a centric bolt and washer.
anarchy0392 is offline
Old 05-22-2013, 04:21 PM   #18
herenow
Fan#: 105707
Points 315, Level 6
I've replaced the rear SwayBar end bushings. This didn't resolve the issue. Do you suggest i replace the Rear Lower Controll Arm? or a diff, part that has bushings or multipule parts with bushings?
herenow is offline
Old 05-22-2013, 06:08 PM   #19
JerryHD1
Fan#: 114941
Not being a mechanic, could you point me in the right direction of this camber adjustment bolt?
JerryHD1 is offline
Old 05-22-2013, 11:46 PM   #20
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
if your suspension is stock, then it doesn't exist. It's an aftermarket kit you gotta purchase and install. It's a frequent topic of conversation here; use the forum search box and you'll find more info on it than you have time to read.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
