Contour valve cover HELP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-09-2013, 06:30 PM   #1
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,634, Level 23
Points: 1,634, Level: 23 Points: 1,634, Level: 23 Points: 1,634, Level: 23
Level Up 34% Completed
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
I have a 96 contour valve cover. I got the spacer things that came with it and I got this gasket then I went to the store and go m10x25x1.0 bolts and it didn't work. When I put it on it was torqued down right and in the right order but it didn't seal right at all. It kinda sprayed oil every where under the hood. What did I do wrong?
anarchy0392 is offline
Old 05-09-2013, 06:31 PM   #2
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 9 drunkyoda Good Standing Member
pictures would help. did you make sure the gasket was in the slot?
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 05-09-2013, 06:58 PM   #3
anarchy0392
Fan#: 102873
I don't have pic's of it I took it off and cleaned it up being mad and didn't think to get pic's. But yes the gasket was seated properly, the O-ring things around the spacers are new an fit right.
Old 05-09-2013, 07:04 PM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,154, Level 74
Points: 13,154, Level: 74 Points: 13,154, Level: 74 Points: 13,154, Level: 74
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
The proper bolts for the Contour valve cover are the 6mm x 30mm x 1.0. Also when tightening down the bolts you need to go in a pattern from the inside and work your way to the outside bolts. Standard torque on it is 60 inch-lbs per bolt. That is about 5-7 ft-lbs if you don't have an inch-lb torque wrench.
zetecDon is offline
Old 05-09-2013, 07:19 PM   #5
anarchy0392
Fan#: 102873
I did the proper pattern an I have both types of torque wrenches I did 60 inch pounds an its 6mmx30x1.0 well that might be my problem then. But just to be clear this is going on my 2002 FoFo Zetec.
