need advice/member of droped valve seat - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-09-2013, 05:28 PM   #1
Lannie
Fan#: 113324
What I Drive: 2003 Ford Focus
FF Reputation: 1 Lannie Good Standing Member
2003 se focus. replaced piston number 3, rod and rings. New head and gaskets, cleaned out egr and intake. Car has been running about 2 weeks. Started having problems starting. It will start out slow then catch up and start and run fine. 3 days ago it died at stop sign. Got it started and home. Noticed coolant was low. Added some, then check compression. Pulled valve cover off and discovered i have coolant in the oil. Used haynes manual to tear down and rebuild. any ideas
Lannie is offline
Old 05-30-2013, 08:51 PM   #2
p58ff
p58ff's Avatar
Fan#: 25247
What I Drive: 2010 Red 4-Door SES
Points 1,535, Level 22
Points: 1,535, Level: 22 Points: 1,535, Level: 22 Points: 1,535, Level: 22
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 p58ff Good Standing Member
My first guess would be a head gasket not sealing. Any white exhaust smoke?
p58ff is offline
Old 05-31-2013, 02:35 PM   #3
ImBillT
Fan#: 114943
What I Drive: 2001 Red SPI
Points 105, Level 2
Points: 105, Level: 2 Points: 105, Level: 2 Points: 105, Level: 2
Level Up 10% Completed
FF Reputation: 1 ImBillT Good Standing Member
From Toyota forums I have picked up that only factory and fel-pro head gaskets can be trusted, and even then the Fel-pro head gaskets were getting mixed reviews. Most people there had problems with erisitic gaskets, domestic gaskets, and a few I don't remember. They said the rest of the gasket kits were fine, just not the head gaskets. I assume you used new head bolts, ran a tap into the bolt holes in the block, cleaned the holes, LIGHTLY oiled the bolt, and used a head which had been properly checked or remachined.
ImBillT is offline
