SVT MAF require a MAFia on a zetec with 12lbs or less? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-08-2013, 10:39 PM   #11
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,548, Level 100
Points: 52,548, Level: 100 Points: 52,548, Level: 100 Points: 52,548, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
Are you sure you understand how the MAFia works , the MAF doesnt tricks , fool or change the max count limits in the ECU
Say you have 4.99 volts and you set the MAFia to 2 lets say is 20% then your voltage to the ecu is +/- 3.99 volts it just lowers the voltage that the ECU sees not change anything the ECU does or does it raise the limit of the ECU it just changes the voltage the ECU now sees
I would NEVER use the failed MAF tables , or the over voltage tables this is a HUGH mistake
The problem with a large MAF tube and cnamging the MTF is you always want to end your build and tuning around the 900 count range and you limited on choices of tubes to use 2.5 , 3 , 3.5
MAFia just works so well
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-08-2013, 11:40 PM   #12
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
I worded that wrong I guess.
The the ECU bases Counts off differential voltage from the reference voltage. That is a percentage from 5v. 1v return is 1/5, 204.6 counts.
When you raise the reference you can also raise the produced voltage from Mass Flow. but the differential stays the same. Lets say reference voltage is now 10v. Then you can have 2v at the MAF, still 204.6 counts.
The problem is the higher flow isn't measured. It's simply assumed to be there based on the voltage seen at the MAFia. The MAFia is handling the fueling and the tune is scaled for each setting.
That scaling is the same thing (in process) as you'd do with a large MAF tube.
I do understand that idle can be troublesome with large tubes though. Slow flow is a PITA.
iminhell is offline
Old 05-08-2013, 11:54 PM   #13
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
have uhad idle problem with 3 inch maf tube ?
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 05-09-2013, 12:22 AM   #14
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,172, Level 91
Points: 21,172, Level: 91 Points: 21,172, Level: 91 Points: 21,172, Level: 91
Level Up 65% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
as long as it is tuned with the 3" tube then there should be no difference in idle. but just changing the location or clocking of your maf can affect it and the tune would need to be looked at to make corrections
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 05-09-2013, 12:27 AM   #15
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
yea ive found that out in the past. taking pipe off and re installing with the maf turned slightly and is tarted it and was like TOM WTF DID I DO lol.
FF MODERATOR
RIFF CREW
Old 05-12-2013, 06:15 PM   #16
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 2%
FF Reputation: 3 paulg127 Good Standing Member
When the mafia scales the signal, what happens when the stock MAF would read 5v? What would the mafia read? 20% lower (if set on 2) means 4v, but is that the max??
How does this help?
And with a mafia don't you need to adjust the main FNMAF2Volts (MTF) transfer function anyway?
Iminhell - where did you get your knowledge on this subject?
Counts are used for digital MAFs, voltage for analog, SVTs are analog, not sure when most Foci were changed to digital MAFs.
paulg127 is offline
Old 05-12-2013, 07:09 PM   #17
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 10%
Count = Voltage
iminhell is offline
Old 05-13-2013, 08:50 AM   #18
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
*If you hit 5 +/- volts with the stock MAF you will hit a fuel cut , the ECU isnt set to go past the 5 volt setting
*With the MAFia set to setting 4 you will still have the full range and issues of 0-5 volts , you just add more range
How does this help?
*With a MAFia set to 4 you can make 4.8 volts +/- and make 400HP where with stock MAF even in a 3 inch tube you wouldnt get to 4100+/- rpm and you would be out of MAF
*Depends on whoos tuning it and how they want to do things , keep in mind your still on the stock MAF electronics
Hope that helps
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
