Coil continuity test = no beep. Should I have a beep? (with picture) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-06-2013, 07:54 PM   #1
Phacade
Chronic Curmudgeon
Phacade's Avatar
Fan#: 32246
What I Drive: '03 EAP SVTF
FF Reputation: 11 Phacade Great Standing Member
Buy-Sell-Trade Rating: (7)
Prods on newly installed MSD coil itself = beep (where the pigtail lead would plug in). Prods on pigtail that goes on coil = no beep. Should there be a beep? Key is off.
I mock your cheese danish and all it stands for!
Phacade is offline
Old 05-06-2013, 08:24 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,708, Level 94
Points: 23,708, Level: 94 Points: 23,708, Level: 94 Points: 23,708, Level: 94
Level Up 36% Completed
Forum Activity 14%
why are you continuity testing the harness?
mikebontoft is online now
Old 05-06-2013, 08:33 PM   #3
Phacade
Chronic Curmudgeon
Phacade's Avatar
Fan#: 32246
Long story short, my car isn't starting. It sat for a while (4 months) and the battery went dead, so I jump started it and it ran immediately. I let it run for about 15 minutes and then shut it down to see if it'd start on its own again. Nothing. Put a fresh battery in. Nothing. Treated fuel and added fresh. Nothing. Tested for spark, didn't see any. Replaced coil and spark plug wires. Still nothing. All electrical seems to be working and starter turns, but no fire. I can hear fuel pump coming on.
Phacade is offline
Old 05-06-2013, 08:45 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
No.
Did you check the ignition fuse?
iminhell is offline
Old 05-06-2013, 09:11 PM   #5
Phacade
Chronic Curmudgeon
Phacade's Avatar
Fan#: 32246
Originally Posted by iminhell View Post
No.
At the risk of sounding...whatever, I wasn't aware there was one. Is it under the hood or inside the car? What fuse number?
Phacade is offline
Old 05-06-2013, 09:49 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 10%
Huh. There isn't a fuse. It's direct to the ECU.
Check the Crank Sensor though.
iminhell is offline
Old 05-06-2013, 10:10 PM   #7
Phacade
Chronic Curmudgeon
Phacade's Avatar
Fan#: 32246
Is B43 and B41 located in the fuse box under the hood in the little box next to the air filter, inside the car, or someplace yes?
Phacade is offline
Old 05-06-2013, 10:12 PM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 10%
Those are the physical sensors, on the block and on the head.
iminhell is offline
Old 05-06-2013, 10:48 PM   #9
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
MSD tech support will tell you what the resistance across that coil should test at.
Here, if this is the right part number:
http://www.msdignition.com/product.aspx?id=5083
Turns ratio: 83:1
Primary resistance: .53 OHMs
Secondary resistance: 13.7K OHMs
Inductance: 3.9mH
elsolo is offline
Old 05-07-2013, 04:13 AM   #10
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
And if you keep trying to send power to the ECU like in the pic you are going to suffer some serious grief, a definite no-no, why the other guy asked why you were doing that. Test the coil NOT the harness, or harness while unplugged from ECU. In certain places the voltmeter has enough power to short out the ECU.
Kindergarten kids look for beeps, you should be looking for actual values (numbers). Meaning you need to know ahead of time what they should be, why the last guy gave them to you. Your asking if you should be getting beeps means nothing to us.
amc49 is offline
