Keeping oil from coking up the intake valves on our DI engines - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-13-2013, 07:01 PM   #51
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,723, Level 94
Points: 23,723, Level: 94 Points: 23,723, Level: 94 Points: 23,723, Level: 94
Level Up 38% Completed
Forum Activity 13%
one of my coworkers performed a walnut service on a BMW a few weeks back. he took before and after pics of the valves. I'll see if I can find those for you guys.
And if you're wondering what a walnut service is, it's like glassbeading but the crushed walnut shells are degradable in the engine. still requires removing the Intake manifold though.
mikebontoft is offline
Old 07-14-2013, 02:16 PM   #52
Arco-Zakus
Arco-Zakus's Avatar
Fan#: 101658
What I Drive: 2014 SGM SE Sport Pkg Sedan 5sp-man
Points 748, Level 14
Points: 748, Level: 14 Points: 748, Level: 14 Points: 748, Level: 14
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 12%
FF Reputation: 12 Arco-Zakus Great Standing Member
You're welcome but PandT found it first
Originally Posted by jcw122 View Post
Thank you!
You're welcome, but PandT gets the credit for finding that article. (After I posted the link to it for you, I went back into my notes to recall where I got it from originally. It was in post #21 of this very thread.) I also had read a bunch of stuff on VW and Audi forums, since they've got many years more experience with gasoline direct injection (GDI) engines, but I don't recall any of it that made this stuff any clearer than that article does.
Slightly off topic, but another issue related to GDI engines you'll probably be interested in, if you haven't already run into it, is "fuel dilution". (That's a misnomer because it isn't the fuel that gets diluted, but the oil in the crankcase that gets diluted by the fuel.) I read a comment in some FocusFanatics thread about engine lubricants and change intervals to the effect: "... as everyone knows, direct injection engines have a problem with fuel dilution ...". I didn't know that, but researching that is what lead me to this topic.
From what I had read about GDI allowing more precise metering and timing of fuel delivery than port injection does, that came as a surprise to me. I set out to find evidence that would refute that statement, but found that it actually supported it. The reasons may have made sense to me at the time, but I decided it's easier to drive in a way that minimizes the problem and change oil often enough than to carry all that stuff around in my head.
GDI has been adopted despite its higher complexity and manufacturing cost because it (along with the higher compression ratio it allows) results in more power and better fuel economy. Those benefits could be offset by higher maintenance cost, as discussed in this thread. I've also been wondering about how the reliability and cost to repair GDI components (injector nozzles, pumps, lines) will compare to port injection systems. That could easily offset any savings from better fuel economy. Time will tell.
Arco-Zakus is online now
Old 07-14-2013, 02:41 PM   #53
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
What about what I would do on my MOPAR's a sealed breather that has the hose attachment one on each cover hose goes to reed valve's at an angle in the collector of the headers so exhaust pulses would pull out vapors and burn in hot exhaust? Would also auto lube the muffler bearing....
Seminoles is offline
Old 07-14-2013, 03:32 PM   #54
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Every used oil analysis I've seen for this engine shows that fuel dilution is basically a non-issue.
Hatch Nation #90
TboneZX3 is offline
Old 07-23-2013, 03:24 AM   #55
Arco-Zakus
Arco-Zakus's Avatar
Fan#: 101658
Forum Activity 12%
Good news
That's good news.
I still can't understand why VW-Audi has had a problem with it. It makes sense that not spraying fuel into the port would prevent the additives in the fuel from cleaning the valves, but not that the more precise metering and timing with direct injection would cause more, rather than less, fuel to get into the crankcase.
In any case, the end result is more important than the theory, so thanks for that info. Maybe Ford's designers learned about some mistake VW-Audi had made with theirs and did it better.
Old 07-23-2013, 10:25 AM   #56
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
It makes sense that not spraying fuel into the port would prevent the additives in the fuel from cleaning the valves, but not that the more precise metering and timing with direct injection would cause more, rather than less, fuel to get into the crankcase..
Timing and metering of the injector pulses are certainly factors in fuel dilution. My understanding is that, typically, the issue in DI is that the injector spray wets the cylinder walls more than port injection, and thus the fuel is more likely to wash past the rings into the crankcase. With port injection, the fuel is in more of a gaseous state after it passes the intake valves, and isn't wetting the cylinder walls as directly.
The Ti-VCT seems to be an oil-tight engine with low consumption, so the ring seal must be fairly good. Typically it is turbocharged DI engines that see more fuel dilution, I believe, due to the higher pressures involved.
The UOAs that have been posted here show fuel dilution to be less than 0.5% in this engine, and some of those OCIs have been extended.
Hatch Nation #90
TboneZX3 is offline
Old 07-24-2013, 09:39 AM   #57
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
Points 1,383, Level 20
Points: 1,383, Level: 20 Points: 1,383, Level: 20 Points: 1,383, Level: 20
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 Borski Good Standing Member
Originally Posted by Aron@Injected View Post
One of these has 1200 miles on it and the other has 9k on it
Aron, I should be down it ATL in early September with around 50k miles. I could swing by the shop and you could throw the BS in there if we're still looking at this issue.
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
Old 07-24-2013, 10:29 PM   #58
ScooterCT70
Fan#: 98691
What I Drive: 2012 Ingot Silver Titanium Focus
FF Reputation: 1 ScooterCT70 Good Standing Member
Yup, I had a UOA by Blackstone and your exactly right. Anyone know how I can upload the pdf they sent me of the UOA?
ScooterCT70 is offline
Old 07-25-2013, 08:01 AM   #59
XlarXlar
XlarXlar's Avatar
Fan#: 111735
What I Drive: 2013 PB Ford Focus
Points 246, Level 4
Points: 246, Level: 4 Points: 246, Level: 4 Points: 246, Level: 4
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 2 XlarXlar Good Standing Member
I'm not sure if you can. The instructions are here: http://www.focusfanatics.com/forum/f...eading_posting
But when I look I cannot see the option and at the bottom of this thread there is a box labeled posting rules which states that "you may not post attachments." Now this could just be me so it's worth looking.
The other option that I can think of is to take a screenshot of the pdf and post that instead. If anyone has a better suggestion, let me know.
XlarXlar is offline
Old 07-25-2013, 08:13 AM   #60
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Take a screenshot, save as .jpg, and edit out your personal information.
That's how I did this one:http://www.focusfanatics.com/forum/showthread.php?t=317340
Hatch Nation #90
TboneZX3 is offline
