Keeping oil from coking up the intake valves on our DI engines - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-05-2013, 09:15 PM   #11
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,426, Level 97
Points: 26,426, Level: 97 Points: 26,426, Level: 97 Points: 26,426, Level: 97
Level Up 8% Completed
FF Reputation: 9 TORQUERULES Good Standing Member
Originally Posted by Aron@Injected View Post
Have you measured vacuum pressure at the intake?
I'm not sure there is a free port on the intake to attach a gauge to. I could try to see if I get a reading on the OBD2 scan tool.
TORQUERULES is offline
Old 05-05-2013, 09:15 PM   #12
TORQUERULES
The Professor
Fan#: 1083
Originally Posted by FocusTi View Post
Wouldn't the fuel being injected right into the cylinder help keep the valves clean? If you are using good fuel that it.
DI engines have no fuel in the intake ports.
Old 05-05-2013, 09:16 PM   #13
Aric@Injected
FF Affiliate
Aric@Injected's Avatar
Fan#: 113187
What I Drive: '13 Sonic Blue test pig
Points 12,833, Level 73
Points: 12,833, Level: 73 Points: 12,833, Level: 73 Points: 12,833, Level: 73
Level Up 96% Completed
FF Reputation: 10 Aric@Injected Great Standing Member
Direct Injection engines are known for acumulating carbon on the intake valves.
Aric@Injected is offline
Old 05-05-2013, 09:18 PM   #14
TORQUERULES
The Professor
Fan#: 1083
Thumbs up
Makes sense. Let me know if you wanna try that maintenance we spoke about.
Sent you a PM. Thanks!
Old 05-05-2013, 09:18 PM   #15
TORQUERULES
The Professor
Fan#: 1083
Direct Injection engines are know for acumulating carbon on the intake valves.
Yep. Kills your head flow and power...
Old 05-05-2013, 09:30 PM   #16
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
FF Reputation: 2 Brabs_Weather Good Standing Member
Originally Posted by TORQUERULES View Post
Oil can get into the intake from two sources. 1. The valve cover/cam cover breather system which I have just separated from the air intake and the PCV system which I am using h catch can for.
Most of it is from the PCV system, but the valve cover/cam cover breather gets some too.
The breather tube for the valve cover is mostly an emissions control system. Old engines, and racing engines, use an open breather here (many did not/do not even use a PCV system---on my Mustang I use a vacuum pump). The EPA does not want oil fumes into the air. Thus the tube I eliminated.
My buddy put a oil separator from the valve cover to intake air line and had not one drop of oil. It is possible oil vapors are far less. The main area is from the crankcase behind the manifold. James Baron Racing has detailed pictures of this.
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 05-05-2013, 09:44 PM   #17
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 932, Level 16
Points: 932, Level: 16 Points: 932, Level: 16 Points: 932, Level: 16
Level Up 32% Completed
Forum Activity 2%
FF Reputation: 5 novus Good Standing Member
Oh hell yeah. Look at Audi owners.
http://www.audizine.com/forum/showth...ad-for-RS4-4-2
And they were seeing it as low as 30k.
(Flap in the intake mani)
novus is offline
Old 05-05-2013, 10:07 PM   #18
Aric@Injected
FF Affiliate
Fan#: 113187
From what I've seen they require maintenance every 15k miles. This isn't my thread, but we will have a offering to help guys encountering this problem.
Old 05-05-2013, 10:09 PM   #19
TORQUERULES
The Professor
Fan#: 1083
I said the main source is from the PCV system. The valve cover breather is just extra insurance. And I did find oil film in he tube that connected it to the air inlet tube.
This is common practice in the Mustang, Lightning, etc. world for instance. No catch can is really needed there unless you have a lot of blow-by.
Now between the PCV valve and the intake, that is another story. A oil separator/catch can is a must.
Btw, if you engine is in good condition, your can won't collect a lot of oil in a short period of time. If it does, then you have problems. If you can empty it at oil change time and get maybe a table spoon or two, then you are fine. Hopefully less.
F/I engines usually collect more than N/A engines for obvious reasons.
Old 05-05-2013, 10:28 PM   #20
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2014 Tuxedo Black SE Sport
Points 1,604, Level 23
Points: 1,604, Level: 23 Points: 1,604, Level: 23 Points: 1,604, Level: 23
Level Up 4% Completed
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
FF Reputation: 5 StingRay Good Standing Member
This reminds me I need a catch can still.
StingRay is offline
