Keeping oil from coking up the intake valves on our DI engines - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-05-2013, 08:22 PM   #1
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,652, Level 97
Points: 26,652, Level: 97 Points: 26,652, Level: 97 Points: 26,652, Level: 97
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 9 TORQUERULES Good Standing Member
Thumbs up Keeping oil from coking up the intake valves on our DI engines
Ford is doing some things with their DI engines to minimize this, but oil still gets in there through the intake because of the PCV/breather system and there is no fuel hitting the intake valves to keep them clean.
Sooooo, a budget-minded two phase plan. Phase 1 finished (edit: gonna go a different route):
Phase 2 coming:
TORQUERULES is offline
Old 05-05-2013, 08:48 PM   #2
TORQUERULES
The Professor
Fan#: 1083
The catch can/separator is for the PCV side of the equation.
Old 05-05-2013, 08:55 PM   #3
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 880, Level 15
Points: 880, Level: 15 Points: 880, Level: 15 Points: 880, Level: 15
Level Up 80% Completed
FF Reputation: 3 amoosenamedhank Good Standing Member
Whose can is that? Never seen that one before.
You saw it cuz I tapped it
What's that?? You'd like an eco-tune...
amoosenamedhank is offline
Old 05-05-2013, 08:59 PM   #4
TORQUERULES
The Professor
Fan#: 1083
Oil can get into the intake from two sources. 1. The valve cover/cam cover breather system which I have just separated from the air intake and the PCV system which I am using h catch can for.
Most of it is from the PCV system, but the valve cover/cam cover breather gets some too.
The breather tube for the valve cover is mostly an emissions control system. Old engines, and racing engines, use an open breather here (many did not/do not even use a PCV system---on my Mustang I use a vacuum pump). The EPA does not want oil fumes into the air. Thus the tube I eliminated.
Old 05-05-2013, 09:00 PM   #5
TORQUERULES
The Professor
Fan#: 1083
eBay. Has to be modified.
Old 05-05-2013, 09:01 PM   #6
Aric@Injected
FF Affiliate
Aric@Injected's Avatar
Fan#: 113187
What I Drive: '13 Sonic Blue test pig
Points 12,833, Level 73
Points: 12,833, Level: 73 Points: 12,833, Level: 73 Points: 12,833, Level: 73
Level Up 96% Completed
FF Reputation: 10 Aric@Injected Great Standing Member
Have you measured vacuum pressure at the intake?
Aric@Injected is offline
Old 05-05-2013, 09:11 PM   #7
TORQUERULES
The Professor
Fan#: 1083
If you look at the tube coming from the cam cover you will find traces of oil. It doesn't take much to leave deposits on the valves.
The main culprit is the PCV system. I will work on that next.
Old 05-05-2013, 09:12 PM   #8
TORQUERULES
The Professor
Fan#: 1083
Nope. I am just trying to do some preventive stuff here.
I am sure it is not a huge issue, but I am it taking chances. Lots of Audi owners spend a lot of money getting their valves cleaned. I have seen build up on non DI engines, so...
Old 05-05-2013, 09:14 PM   #9
Aric@Injected
FF Affiliate
Fan#: 113187
Makes sense. Let me know if you wanna try that maintenance we spoke about.
Old 05-05-2013, 09:14 PM   #10
FocusTi
FocusTi's Avatar
Fan#: 102567
What I Drive: Black 2012 Ford Focus Titanium
FF Reputation: 1 FocusTi Good Standing Member
Wouldn't the fuel being injected right into the cylinder help keep the valves clean? If you are using good fuel that it.
Current Mods: Snorkel Delete with ITG Filter and newmission intake, Rear Sway-Bar, Magnaflow Exhaust, RMM and Hitch
Future Mods: Coilovers, End-Links, Tune, and Brakes
FocusTi is offline
