Still Fighting Crazy IAT Temps - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Focus Tuning Chat
Old 05-05-2013, 06:27 PM   #1
Telly
Fan#: 101320
What I Drive: 03 IR SVT
Points 225, Level 4
Points: 225, Level: 4 Points: 225, Level: 4 Points: 225, Level: 4
Level Up 50% Completed
FF Reputation: 1 Telly Good Standing Member
I've been trouble shooting high and low IAT temps when data logging. Temps like to hang around -30's but can shoot from -168 to +168. When the real outside air drops bellow about 38 (+/- 3 deg) there's a huge performance lose (feels like a limp home mode).
Tom, last time I talked to you (several months ago) I think we both thought it was likely was a wire intermittent short/ground/open thing.
I think I'm convinced it's not a wire/connection issue, after a lot of inspections and tests.
Last voltage test, same reading at MAF and PCM, (60 deg out)
4.8 Vdc on Input ACT (White/Violet)
4.6 Vdc on Return (Brown/White)
Thinking of replacing PCM, but really don't want to without good reason.
Any Ideas what else to look at?
Telly is offline
Old 05-05-2013, 10:23 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,269, Level 85
Points: 18,269, Level: 85 Points: 18,269, Level: 85 Points: 18,269, Level: 85
Level Up 84% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Return voltage seems high. As in the heater isn't working at all.
According to Ford, you should see between 1.7 and 3.5 volts on the signal return (ground).
iminhell is offline
Old 05-05-2013, 11:46 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 50,944, Level 100
Points: 50,944, Level: 100 Points: 50,944, Level: 100 Points: 50,944, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
You have a few options
1) get a junkyard MAF or a buddy with a SVT Focus or any 2000 to 2004 Zetec and plug his in , you wouldnt even need to start the car just plug it in and see if the temps are correct
2) get a 2 wire temp sensor from something and remove the wires from the 6 wire MAF plug in and see if you get a correct temp with the key on
3) hate to say buy a MAF because there is nothing more I hate but to throw parts at something with out knowing its bad , I would try option 1 or 2 first
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-06-2013, 10:29 PM   #4
Telly
Fan#: 101320
Points 225, Level 4
Would a bad (high) voltage on the Return cause noticeable problems with any of the other sensors tied to it? (I'll try data logging them tomorrow)
I replaced the MAF couple months ago with no change, but that was before fixing a major engine ground problem.
I'm getting a good 12Vdc at the Green/Red into the MAF, And a good ground on the Black/Orange.
Whats the trick to removing the pins in the MAF connector? Popped the lock block up, but couldn't finagle the pins to release.
Is a non-SVT focus MAF the same?
Telly is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
