Radio Install Question - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 05-05-2013, 05:05 PM   #1
tsmigs619
Fan#: 114341
What I Drive: 2010 Blue Flame Metallic Focus SES
FF Reputation: 1 tsmigs619 Good Standing Member
Hey guys. Long time lurker, finally took the plunge and signed up. Got a question about aftermarket radio install. I wired up a JVC Double-Din to my 2010 Focus SES with the premium sound system, and couldn't figure out which wire to hook the remote turn on wire to. Tested most of the wires with a multimeter to see which ones got power when the key turned on and none of the ones i tested did. Got it temporarily wire to a toggle switch lol. Thanks for the help if anyone can.
tsmigs619 is offline
Old 05-05-2013, 05:33 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,095, Level 50
Points: 6,095, Level: 50 Points: 6,095, Level: 50 Points: 6,095, Level: 50
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
FF Reputation: 22 freemind Great Standing Member
Buy-Sell-Trade Rating: (22)
Have you tried the Violet/Red wire?
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 05-05-2013, 06:07 PM   #3
tsmigs619
Fan#: 114341
The only violet/red wire was attached to a seperate plug on the back of the factory radio, and i tested it and got less than .3 volts when the key turned on (all the other wires got 0) so idk whats up with that. i read about that violet red wire elsewhere, too, so that was the first one i tried lol
Old 05-05-2013, 06:35 PM   #4
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 53%
Remote turn on wires do not put out much. They don't need to.
That's your wire man.
Hatch Nation #140
Old 05-05-2013, 06:54 PM   #5
tsmigs619
Fan#: 114341
Thanks, freemind. I'll have to try that one out then. I thought they had to be the full 12 volts, but I'll check it out. Thanks again!
Old 05-07-2013, 09:39 AM   #6
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,470, Level 42
Points: 4,470, Level: 42 Points: 4,470, Level: 42 Points: 4,470, Level: 42
Level Up 60% Completed
FF Reputation: 9 Kipp Good Standing Member
the remote turn on from the headunit is meant to turn on a aftermarket amp. it doesn't connect to anything in the vehicle harness unless you have a factory sub you are trying to reuse.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 05-07-2013, 12:06 PM   #7
tsmigs619
Fan#: 114341
There is also a wire on the aftermarket head unit that tells the head unit to turn on when the vehicle comes on. i'm 100% sure on this because i have that particular wire hooked up to a toggle switch and it's functional lol
Old 05-07-2013, 12:17 PM   #8
Kipp
Kipp's Avatar
Fan#: 31300
ok. that's the headunit accessory wire. there is no acc wire in the factory headunit harness since new vehicles are turned on by a data signal. you'll either need a harness that will provide it's own acc output or you need to wire it to the acc wire in the ignition switch or down towards the fuse box.
Midwest Crew #22
Kipp is offline
Old 05-07-2013, 12:19 PM   #9
tsmigs619
Fan#: 114341
ahhh ok. i was wondering why the wiring harness diagram said that the factory unit was turned on by a data network. you cleared it up for me thanks! ill try to find a fuse then, i have a few extra of those fuse adapter things
Old 05-08-2013, 08:54 AM   #10
Kipp
Kipp's Avatar
Fan#: 31300
if you can't get it figured out let me know. i live in KC so i could help ya out with it and I'm a professional installer.
Midwest Crew #22
Kipp is offline
