SPI Issue. - Focus Fanatics
Old 05-05-2013, 11:49 AM   #1
swagfocuswagon
swagfocuswagon's Avatar
Fan#: 103591
What I Drive: '00 Focus wagon, 96 Cutlass Supreme
FF Reputation: 1 swagfocuswagon Good Standing Member
SPI Issue.
Hey guys!
Basically when i go to start the car in the morning (or cold) it fires right up with no problem. I go to make a trip and the engine warms up. After about 5minuts i go back to the car after my trip. Engine is completely warmed up by now. Car starts, but fumbles. Almost like its gonna die. It does this for about 15 seconds. Then it runs fine. If I have a load on it sometimes it stalls. If i give it some gas it runs fine but as soon as I let off it starts running really rough for that 15 or so seconds.
This car is making me nuts.
I have replaced the alternator several times. Battery is still good. Wiring is good. Added a few grounds, ect. I cant seem to figure out whats wrong with it.
If anyone can chime in, please do. I can give more info if needed.
Thanks, Patrick.
I hate the word swag.
swagfocuswagon is offline
Old 05-05-2013, 11:52 AM   #2
swagfocuswagon
Fan#: 103591
Also I got this weird glitch when its idling it will "miss" for a second and will do it intermittently. Also when driving especially on take off it when I give it gas it will act like its running on 2 cylinders. If I let off the throttle a little bit it stops and then runs fine. Im afraid this thing is gonna get me killed lol
Old 05-06-2013, 10:43 AM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
FF Reputation: 28 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat" so you can get better answers for your questions.
zetecDon is offline
Old 05-07-2013, 08:02 AM   #4
swagfocuswagon
Fan#: 103591
Okay thanks!
Old 05-07-2013, 08:53 AM   #5
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Check your coil. They are known to crack and let in moister and will run like crap. Also pull out your pcv valve and see if it rattles if it does than its good but if not replace it as well as the tube going to it look for any cracks that may be causing a vacuum leak. That would be your two easiest and cheapest fixes.
After that look at idle air control valve, and throttle postion sensor.
Btw go with motorcraft coil it never hurts to keep it with a stock ford parts.
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is offline
Old 05-10-2013, 01:16 PM   #6
swagfocuswagon
Fan#: 103591
I replaced the coil when I did my tune up for that reason. Its not a MotorCraft but it does the job. I dont doubt its defective though.
This car is been nothing but a living hell. Its a nice ride and all but its making me nuts.
But I will look at those things. Thanks for the suggestions.
I fixed my batt. light. A wire on the alternator pig tail was broken in half (corrosion) so I crimped and heat shrank it.
Old 05-10-2013, 04:15 PM   #7
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
FF Reputation: 3 Kodyston Good Standing Member
First thing that popped into my head was the idle air control valve/sensor and the throttle position sensor. I would definitely check those.
Kodyston is offline
Old 05-10-2013, 05:44 PM   #8
esmith2039
Fan#: 54755
What I Drive: 2002 Focus LX
FF Reputation: 1 esmith2039 Good Standing Member
I wouldn't count on it. My aftermarket coil went bad 2 months after installing. Put the motorcraft back in and was fine. Mine was cutting out typically in the cooler weather and was fine when it got warmed up. Ran alot smoother with the newer coil when it was missing though!!
02 Focus LX 114k - auto
04 Escape XLT 132k
esmith2039 is offline
Old 05-10-2013, 05:50 PM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 270 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Have u done a compression test? Do you know about the SPI issues? A lack of compression might explain why it acts different warm than cold.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 05-10-2013, 05:58 PM   #10
amc49
Fan#: 96610
FF Reputation: 21 amc49 Great Standing Member
Odds are though, if coil changed and problem stayed the same, then not coil.
Check the PCV hose in BACK of motor where it goes into the intake, commonly sucks a hole to do just what you describe.
A PCV valve can rattle and still be bad. The rattle is the poppet rattling around in the bigger orifice, there can be a smaller one that gets stopped up but valve will still rattle. Rattle means the valve works fine at high speed but it may not work fine at idle. Depends how valve made inside............I don't like to change PCV valves, the one in motor is commonly metered finer than ones you buy, I always throw the valve in acetone for a day or two to soften deposits and then blow the daylights out of it with compressed air. Haven't bought one in like 30 years now.
amc49 is offline
