Svt focus low compression cyl#1 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-05-2013, 10:52 AM   #1
yzdude250f
yzdude250f's Avatar
Fan#: 70569
What I Drive: 2004 sonic blue svt focus
FF Reputation: 2 yzdude250f Good Standing Member
2004 svt focus owned since 52,000 miles i just hit 91,000 car is in a1 shape but i need advice on how to handle this situation, this car being an svt and being some what hard to get parts (engine etc) for i need advice and a source on where to get parts if i decide to keep my svtf.
For starters the past month i have been chasing a mis-fire on cylinder one,It wasn't very apparent until the past week and has gotten progressively worse, its worse on a cold start very choppy exhaust note etc when warm the car seems to run more efficient but the issue is still there. an occasional pop every 15-20 seconds in the exhaust note vs a machine gun.
I have replaced the following before i did a compression test to rule out the obvious:
plugs motor craft sp487 20k ago and two days ago put in sp524 (this replaced the 487) per Steve at tousley ford
wires
coil pack
coil pigtail
intake mani couplers
misc vacuum hose
pcv valve
my testing method was unplug the coil and hold wot crank till the gauge read no higher 3-5 seconds
my compression results on a cold motor are the following
5 min of idle 15min of idle
cylinder 1 20psi cold 50 psi 70 psi
cylinder 2 120 psi
cylinder 3 125 psi
cylinder 4 120 psi
all other cylinders stayed consistent as i warmed the motor they went up 2-5 psi
All plugs seemed to be oil free on the first compression test (white/tan colored) when i pulled cylinder one for my second test after five min of idle it was moist, but had no fuel smell and was not oil, i wiped it off checked compression and it was 30 psi higher, ran the car an additional 10-15 min pulled cylinder one again clean plug and 70 psi car runs much smoother at this point.
I have noticed if i hold the engine in higher rpm under the hood and watch the coolant tank i get transfer from the top two coolant hoses with bubbles in them could i have a bad head gasket or the beginning of a head gasket starting to let go.
i have it eliminated to rings, but it not smoking kinda makes me want to rule that out
bad valves seats or a head gasket but once again im at a loss with this car.
Any help would be appreciated, Pm me for a phone number if you have experience in rebuilding or are a svtf guru with these motors and know where to source parts etc.
2004 svt focus sonic blue, Build number 1041
Aem intake Cfm throttle body
Oz racing record 18's
Rs steering wheel Euro grille
Yellow fog lights Fswerks rear stress bar
yzdude250f is offline
Old 05-05-2013, 10:15 PM   #2
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
What I Drive: 2001 ZTS, 2002 SVTF Turbocharged
FF Reputation: 6 svtf1417 Good Standing Member
Buy-Sell-Trade Rating: (6)
did you ever try a "wet" compression test?
[#1417] 2002 Sonic Blue SVT Focus
Born on June 25, 2002
2001 Silver ZTS Sedan - "Ol' Reliable"
svtf1417 is offline
Old 05-06-2013, 12:38 PM   #3
84572
Fan#: 84572
What I Drive: focus
FF Reputation: 1 84572 Good Standing Member
With bubles in your coolant tank it sounds like it may be the head gasket. But I wouldn't think that would cause a steady miss. Remove the valve cover and pressurize the #1 cyl. with air and see if any air is coming from a valve or bubbles in the coolant tank.
84572 is offline
Old 05-10-2013, 11:44 PM   #4
amc49
Fan#: 96610
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Could easily be a burned valve.
amc49 is offline
Old 05-11-2013, 01:06 AM   #5
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
I had bubbles before. it was a leak in the head gasket, y head bolts were stretched and I bought new gasket and arp head studs and now I got great compression and no air bubbles
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 05-13-2013, 09:01 PM   #6
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,550, Level 42
Points: 4,550, Level: 42 Points: 4,550, Level: 42 Points: 4,550, Level: 42
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
Get a cyc leak down tester,cheap and easy
NJSVTGUY is online now
Old 05-13-2013, 11:27 PM   #7
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
if you do that make sure its at tdc and have someone with an 18mm socket on the crankshaft pulley so that when you force air into the motor the valve wont open up and let air escape prematurely
FF MODERATOR
RIFF CREW
Old 05-14-2013, 08:20 AM   #8
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
If thats your compression there is no need in more testing you have a problem with Cyl 1
Pull the head and see what you find make sure you check the piston good before replacing the head
How many miles on this engine ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-14-2013, 07:40 PM   #9
yzdude250f
yzdude250f's Avatar
Fan#: 70569
There is 90k on the car, i did a wet test and the results were about the same the head is coming off tomorrow (per mechanic) who is a family friend and an ase ford master tech, hes pretty sure its a burnt valve and has seen one due this before and with my work schedule im unable to due the repair, seven 10 hour shifts does not leave me much time to do the work myself i would much rather but dont have a chioce
Old 05-14-2013, 07:52 PM   #10
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
a burnt valve causing low compression?
FF MODERATOR
RIFF CREW
