Aftermarket speakers review - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-11-2013, 09:15 AM   #11
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
Forum Activity 3%
FF Reputation: 17 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
Moved to "Car Audio, SYNC, MyFord Touch & Electronics"
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 05-16-2013, 11:34 AM   #12
Chris26
Fan#: 97846
What I Drive: 2013 Sterling Gray SE 201A 5 speed
Points 255, Level 5
Points: 255, Level: 5 Points: 255, Level: 5 Points: 255, Level: 5
Level Up 10% Completed
FF Reputation: 1 Chris26 Good Standing Member
I've never done an audio upgrade in any car I've ever owned but I'm looking to upgrade my '13 SE. I have a couple of questions about this setup.
I have the 6 speaker setup in my car. Since this is a 4 channel amp, can I just hook up the 4 main door speakers to this and continue to run the tweeters out of the stock head unit? Would this create a big negative effect in sound quality?
Chris26 is offline
Old 05-17-2013, 06:13 PM   #13
atahmission
Fan#: 112489
What I Drive: 2013, white, SE
FF Reputation: 1 atahmission Good Standing Member
Hi Chris,
The stock wiring is split, sending signal to the woofer and tweeter, though it's though a single channel. If you go with a component like mine, you install a crossover so only the proper signals are passing through the tweeter. With a coaxial, the crossover is built in. All this to say you're already running out of a 4 channel stock amp, so you're golden. The amp gave a real sonic boost, and I love how easy it is to set up. It's a huge improvement over stock, but the DSP still hampers the sound. The next step is a signal processor. If you need help with the setup, I've tore the car apart numerous times, so I'm glad to share whatever wisdom i may have stumbled across.
atahmission is offline
Old 07-12-2013, 10:16 PM   #14
jcw122
jcw122's Avatar
Fan#: 111081
What I Drive: 2014 Race Red SE 201A Hatch - MTX
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 2 jcw122 Good Standing Member
Originally Posted by atahmission View Post
The verdict: I'm very, very pleased with the performance of both the speakers and the amp. The Infinities are my 4th set, and I'm finally content after some swings and misses. My first venture into aftermarket speakers was the coaxial version of the component Infinities I'm now running. Next the JL Audio TR600-CXi, and finally the JL Audio C2-525X before moving onto the components. Long story short, I wasn't thrilled with any of the speakers. One reason I went with the Infinity component is the particularly low sensitivity rating; low sensitivity equals better efficiency, requiring less energy to drive the cone. My initial setup was simply the 4 speakers being run off the head unit, but the marginal increase in sound didn't seem fitting of what's realistically a pretty pricey speaker. I wanted more power, but I didn't want to install a traditional amplifier by running 12V through the firewall and on back to the hatch, so the little power pack Alpine makes really piqued my interest. The installation was a breeze (easier than the speakers, nearly), and the sound improvement was immense. I'd considered a sub, but now I'm not certain. Sound reproduction is excellent. Mids and highs are incredible. Lows, too, are impressive, at least for a mid-woofer. Next I'm considering a signal processor to really get the most out of the system. I'll be working on a write up over the next few days, detailing how to install both, if anyone is interested.
The amp is installed in front the head unit, and slightly below. I used the attached mounting brackets to screw the amp to the surrounding plastic, after first laying down a layer of foam against the brackets, and against the head unit.
Did you also have the amp with the initial 3 sets of speakers? Or was the most recent setup the only one to have an amp?
And won't you need a second amp if you add a sub? If you do, do you feel like having a 5-channel amp to begin with would have been cleaner in the first place? Thanks.
2014 SE in Race Red, 201A, Winter Package, Moonroof. Manual Transmission. e-Focus RMM. Snorkel Delete Mod. Love it!
jcw122 is offline
Old 05-15-2014, 12:05 PM   #15
eturk
Fan#: 163602
What I Drive: na
FF Reputation: 1 eturk Good Standing Member
OP: "My initial setup was simply the 4 speakers being run off the head unit..."
Does sound like all sets of speaker tests were done off the stock head unit, no aftermarket amp. Do clarify.
If so, the stock HU would be low wattage and high distortion compared to the Alpine amp. May have saved a ton of money running the amp on the first set of Infinity.
Infinity makes 2ohm (nearer 3ohm) speakers to "lessen the effect of the thin guage stock speaker wires" (which add resistance). More importantly, stock cheap speakers are often 2ohm already so a low watt head unit can be installed by car company. Adding an amp to infinity speakers really gets the most out of an amp compared to most aftermarket speakers, which are 4ohm.
To OP: where did you place the tweeters? That's the biggest benefit over coax. High frequencies (tweeters) are line of sight so having them point to the ears, as opposed to coax pointing at the legs, makes a huge difference in SQ.
eturk is offline
Old 10-04-2014, 09:19 AM   #16
rramach8
Fan#: 141961
What I Drive: 2009 FordFusionSEL 120A Tux Black.
Points 59, Level 1
Points: 59, Level: 1 Points: 59, Level: 1 Points: 59, Level: 1
Level Up 18% Completed
FF Reputation: 1 rramach8 Good Standing Member
co-ax w/o amp
This is a nice installation. So, i got a pair of DB651s on my 14' SE w/ 6sp audio. Installed them in the front door. Left the stock tweeter as is. These speakers are supposed to be very good (atleast according to Crutchfield), however, I lost bass, which is kind of understandable. Now, when you mention that you could have just added an amp with the Co-ax at first, would it sound close to the components? The reason I ask is I recently recieved the DB6501 components and debating on the install. As of now, no amp (I would refer not to add an amp, unless no after market speakers can sound good with stock HU). So, if I leave the co-axs in the front and add an amp, will it sound good? What about rears? Thanks much! I am also debating on returning the Polks to get the Infinities. Polks sound a little muddy to my ears (maybe its just me :) ).
THanks much!
_______________________________________________________________________________
2009 Ford Fusion SEL Tux Black, 2.3L Auto w/ 120A Equip Grp
2014 Ford Focus SE Tux Black, 5Sp w/ Sport Pkg
rramach8 is offline
Old 10-04-2014, 03:58 PM   #17
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,600, Level 53
Points: 6,600, Level: 53 Points: 6,600, Level: 53 Points: 6,600, Level: 53
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 47%
Activity: 47% Activity: 47% Activity: 47%
Buy-Sell-Trade Rating: (23)
To get better response, you need an amp. Also, you MUST seal up the access holes in the doors to prevent cancellation(the rear wave and front wave of the speaker meeting). that will greatly improve your midbass response
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 10-04-2014, 07:04 PM   #18
rramach8
Fan#: 141961
Points 59, Level 1
Sorry, this question may be lame, but When you say access holes, are you referring to the speaker cut out? Should I get a Dynamat kit or something for this? Any pic or reference you have will greatly help so I can do based on your suggestion. I did buy a Dynamat kit to put around the bracket but since I reused the factory braket (by cutting out the old speaker), I couldnt find a right way to install the Dynamat.
rramach8 is offline
Old 10-05-2014, 06:46 PM   #19
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 47%
Pics are worth a thousand words. My album, http://www.focusfanatics.com/forum/a...hp?albumid=433
Hatch Nation #140
Old 10-06-2014, 11:55 AM   #20
rramach8
Fan#: 141961
Points 59, Level 1
Indeed. you sir, have a wealth of patience. Great job. If not the whole car, I will atleast get the front doors 'DYNAMAT'ed. Thank you!
rramach8 is offline
