throttle body to IM issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-04-2013, 10:57 PM   #1
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
so did a vac leak test today and theres LOTS of air coming from where the tb spring is to the intake manifold. I found out the top two screws for the tb to the IM aren't tightening all the way as well. wich could be the culprit for this. any ideas on how to fix this? italo and I have been back and forth all day I got two studs in so far but the issue still is there. driving home from my fathers the damn car bucks real bad when cruising
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 05-05-2013, 09:21 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,841, Level 100
Points: 51,841, Level: 100 Points: 51,841, Level: 100 Points: 51,841, Level: 100
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
If you have a tune and please done take this wrong , tell your tuner there is no Vac leaks the tune can adjust over the Vac leak (which can cause other issues) then when you find and fix a Vac leak it changes the fueling and can cause driveability issues , it just needs an adjustment in the fueling
Almost all TB leak some around the shaft they stopped putting good seals in the years ago so that is part of the calculation thats built into even the stock trims on a stock car , the bolts on the other hand not tightening up are an issue
Maybe tonight you can give me a call and I can better understand whats wrong and try to help
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 05-05-2013, 12:08 PM   #3
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
I had a feeling my mis fires were being caused by vac leaks wich was why I spent all day yesterday trying to fix everything. the throttle body screws I believe are what causing itto leak since its not sealing all the way down to the manifold then
FF MODERATOR
RIFF CREW
Old 05-06-2013, 12:42 AM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 31%
I dont know if I think it is but we will see , either way needs to be fixed
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-06-2013, 01:08 AM   #5
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
sent log just cruising
FF MODERATOR
RIFF CREW
Old 05-06-2013, 08:56 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
What manifold?
iminhell is offline
Old 05-06-2013, 09:04 PM   #7
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
oem one
FF MODERATOR
RIFF CREW
Old 05-06-2013, 09:52 PM   #8
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,981, Level 91
Points: 20,981, Level: 91 Points: 20,981, Level: 91 Points: 20,981, Level: 91
Level Up 27% Completed
Forum Activity 12%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
are you using stock tb bolts? are they to long and bottoming out before they are tight?
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
Old 05-06-2013, 10:10 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
OEM is screws. Ever overtighten one? Strips the damn plastic right out.
Stupid design; and you can't do much to fix it.
I haven't looked but, can you drill through and use a bolt from the bottom with a nut on top? (kinda cumbersome but secure)
iminhell is offline
Old 05-06-2013, 10:57 PM   #10
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
you cant really drill through and put a nut a the bottom, right now the top two I put studs. it holds down but not the absolute super tightest. I figured out as well the aftermarket tb for our oem manifolds some reason don't like to fit absolutely 100% wich ahs been causing my leak, so I rtv the shit out of it along the outer edge
FF MODERATOR
RIFF CREW
