How to: wire your stock pump for return fuel, the easy way - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-04-2013, 07:12 PM   #1
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
Points 13,460, Level 75
Points: 13,460, Level: 75 Points: 13,460, Level: 75 Points: 13,460, Level: 75
Level Up 53% Completed
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
I thought I'd share a bit of info that I came across while doing my motor swap. Everywhere I looked for wiring just said to run new wires back to the pump. This is what I found.
Take this wire here, the second black wire on the plug, and run it straight to a ground. Its the pumps ground wire and that is what the system uses to kill the pump. Therefore you get to keep the switched power, fuse, and relay. The green/orange is the power wire.
This pic is from an 04 tank. Wiring colors may be different for other years, but should be the same in position on the plug. If you are unsure, pull the pump and follow the wiring.
And if you are not using the stock pumps or tank, you can still use the power wire and keep the stock fuse and relay.
04 ZX3 Mostly Stock ["Best Non-SVT" FITF '12][3/13 ROTM][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 05-04-2013, 09:10 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,717, Level 94
Points: 23,717, Level: 94 Points: 23,717, Level: 94 Points: 23,717, Level: 94
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 11%
Nice work. It's not even something I thought about yet. I guess the fuel pumps on these are PWM based on the input from the fuel rail pressure sensor? Instead of allowing the computer to control ground, you're just running the pump continuously with key-on. Nice.
mikebontoft is offline
Old 05-04-2013, 09:30 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,525, Level 100
Points: 52,525, Level: 100 Points: 52,525, Level: 100 Points: 52,525, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
This isnt a good idea , if you noticed the wires were twisted together this means they go direct to the ECU if you have a voltage spike you will kill the fuel pump driver and ECU , THIS IS A VERY BAD IDEA
You also run the fuel pump at 100 + % all the time even at idle which is going to cause issues at the Injectors as there going to be running at a lower more unregulated pulse width and a lot more , I wouldnt do this , I tried it back in 2000 and found all kinds of issues that you are not even thinking about
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-04-2013, 11:31 PM   #4
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 11%
yes 100% duty. Fortunately for us, Focus computers need not apply.
What other focus applications would use a return fuel system though?
Old 05-05-2013, 05:16 AM   #5
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 15,079, Level 79
Points: 15,079, Level: 79 Points: 15,079, Level: 79 Points: 15,079, Level: 79
Level Up 46% Completed
Forum Activity 5%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
What about doing this trick with a surge tank?
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 05-05-2013, 08:15 AM   #6
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,159, Level 91
Points: 21,159, Level: 91 Points: 21,159, Level: 91 Points: 21,159, Level: 91
Level Up 62% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
a surge tank is no different than running a separate fuel cell. it is just a small one that is fed by the stock fuel system
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 05-05-2013, 03:05 PM   #7
disciplerocks
Fan#: 59330
This.
And how would you wire a return system with the Focus ECU? I am interested to know. If you are keeping the stock power supply, then how would that not prevent a spike?
Old 05-05-2013, 03:29 PM   #8
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
tom uses a fuel cell.
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 05-05-2013, 05:39 PM   #9
disciplerocks
Fan#: 59330
That doesn't explain anything
Old 05-05-2013, 08:20 PM   #10
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
this is on your v8 car i take it?
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
