A/C does not start up when on auto.... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-04-2013, 04:42 PM   #1
tdo
tdo's Avatar
Fan#: 2591
What I Drive: '13 Focus Sedan TI Performance Blue
Points 375, Level 7
Points: 375, Level: 7 Points: 375, Level: 7 Points: 375, Level: 7
Level Up 50% Completed
FF Reputation: 2 tdo Good Standing Member
Question A/C does not start up when on auto....
right away that is.
When I start the car and have the Climate on Auto, and its warm in the car, the a/c still takes 15 to 30 seconds to start blowing air. NOT cold air, ANY air.
And then if it is warm inside, it does not increase the fan speed, or lower the speed when it cools down.
If it is warm inside, I have to push the max air to get it come on right away.
Conversely, my 2008 F350 immediately starts blowing cold air on high speed with a very warm interior truck temp, and automatically adjusts fan speed down when it cools down inside.
Is this normal for the Focus?
Is the fan speed NOT controlled in auto setting (or am I missing something in the set up, I just push auto)?
Other than this, the car has been very good.
tdo is offline
Old 05-04-2013, 07:53 PM   #2
Rogerschro
Rogerschro's Avatar
Fan#: 90661
What I Drive: '12 FFE Frosted Glass
Points 901, Level 16
Points: 901, Level: 16 Points: 901, Level: 16 Points: 901, Level: 16
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 2%
FF Reputation: 3 Rogerschro Good Standing Member
I do believe there is a setting for this, but you'll have to read the manual, as I don't recall how you set it. I think there is a delay after starting the car for the motor to settle in or something like that before to compressor will kick in and activate the blower. It's a much lower horsepower motor than your truck so it needs to be running for a bit before the added load of the compressor kicks in.
Rogerschro is offline
Old 05-04-2013, 08:30 PM   #3
sekazi
sekazi's Avatar
Fan#: 114026
What I Drive: 2013 Ford Focus Ti Tux. Sedan
FF Reputation: 1 sekazi Good Standing Member
This is how Auto works in any vehicle I have ever used it in. I am in Florida and if the AC decided to blow right after the car started I would get a car full of hot air. It waits until it is able to blow cold air before blowing it. The same thing with hot air. It waits for the hot air then blows. If you adjust the fan speed auto will be turned off so you have to turn auto back on for the fan speed to adjust automatically.
The fans usually never will blow max. It also usually will use the floor more than the upper vents.
My previous car was a Mazda 6 and worked identically.
sekazi is offline
Old 05-04-2013, 08:59 PM   #4
F35-JSF
F35-JSF's Avatar
Fan#: 102775
What I Drive: 13' Tuxedo Black ST3, 08' ZZR-600
Points 571, Level 11
Points: 571, Level: 11 Points: 571, Level: 11 Points: 571, Level: 11
Level Up 43% Completed
Forum Activity 9%
FF Reputation: 2 F35-JSF Good Standing Member
This..
The Escape's auto climate works the same way. Instead of blowing the air out at temps you likely don't want, it waits till it can produce cold or hot air before blowing it on you. If you want the fan to blow max anyway, set it on full low or full high.
TB is not a color, it's a part time job.
Originally Posted by MoncefA33 View Post
:lol:Modding is whatever you define it as. Some people wanna boost, some people need 10 TVs, and some of these homos feel compelled to LED their cars front to back.
F35-JSF is offline
Old 05-05-2013, 02:18 AM   #5
PandT
Fan#: 110640
What I Drive: 2013 Titanium Hatch 18" Plat White
FF Reputation: 2 PandT Good Standing Member
So far, my experience is a little different, don't know if it will help.
Set Temp: 68 F - Automatic Mode - Dual Zone (both set the same)
Got in car, outside temp 75 F
A/C kicked in, I shut it off manually - Display still says Auto.
Now, A/C never kicks in but fans came on at full one day and I manually set it lower.
Now, Fan never goes above that.
It always says it's in Auto but it seems to have my settings overriding the Automatic program.
I suspect that this is a manual override/limit but I haven't yet tried to defeat it.
Maybe tomorrow I will try it but I have several other things to look at and do.
I haven't seen anything posted here about it yet but there are several 'quirks' that I am experiencing that haven't been posted yet - i.e about 2 or 3 minutes after starting my volume drops and then recovers, I asked but nobody seems to be having the same issue, it repeats but I haven't timed it yet for interval.
2013 Titanium HB - Handling pkg. - Platinum White
PandT is offline
Old 05-05-2013, 02:28 AM   #6
PandT
Fan#: 110640
[RANT]
Why do manual settings for the climate control (While in Auto Mode) stick while it can't keep the backup camera settings just from shifting into reverse?
[/RANT]
PandT is offline
Old 05-05-2013, 07:49 AM   #7
tdo
tdo's Avatar
Fan#: 2591
Points 375, Level 7
Thanks for the input. I plan to use the remote start more to give it a chance to get the air going before I have to get in.
I will test out the auto feature, and see if it will adjust the fan speed automatically, by turning it off then on auto, and leave the controls alone.
Oh, and Rogerschro, got any pictures of the 67 Galaxie? It's my favorite year. I have a 67 Country Sedan.
tdo is offline
Old 05-05-2013, 10:28 AM   #8
sekazi
sekazi's Avatar
Fan#: 114026
Originally Posted by PandT View Post
[RANT]
[/RANT]
Dual Zone maybe the cause of the problem. Turn it off and see how it goes. I almost never use the dual zone.
As for the remote start feature when I have used it the blower was on Max when I got in. The AC also switched from 75 to LO. As soon as I started the car the blower turned down and switched to the floors and the temp went back to 75.
sekazi is offline
Old 05-06-2013, 02:28 PM   #9
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,388, Level 36
Points: 3,388, Level: 36 Points: 3,388, Level: 36 Points: 3,388, Level: 36
Level Up 26% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
I will test out the auto feature, and see if it will adjust the fan speed automatically, by turning it off then on auto, and leave the controls alone...
Hi tdo,
Keep us posted on how things go with your Focus. If you need me to assist, just send me a note via PM. :)
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 05-20-2013, 03:48 PM   #10
tdo
tdo's Avatar
Fan#: 2591
Points 375, Level 7
A good day. It got up to the upper 80's, the car was sitting in the sun (sun shield in windshield). Started the car by remote and after a couple minutes went to get in.
I had set the climate to auto this morning. When I opened the door this afternoon, the A/C was on and blowing hard. All on auto. All by itself.
As I drove it the fan speed adjusted depending on the temp inside, up, down, up, down. Excellent. Just what I wanted it to do.
Still a very happy owner. Very glad I don't have to take it in.
tdo is offline
